Anyone into R/C?
Discussion in 'Sports, Hobbies & Interests' started by A.D., Feb 7, 2009.
  1. Apr 28, 2013 at 6:01 PM
    #9621
    Taco42
    Taco42 Well-Known Member
    Jeff
    St. Louis Area
    '12 TRD DCSB Off Road 4x4
    OME lift w/Nitrocharger Sports, 885 coils, Dakar leaf pack, carrier bearing drop, 5mm driver side spacer (no more Taco Lean), Light Racing UCAs, TRD Beadlock 16" wheels, Cooper S/T Maxx 265/75R16s, TRD Exhaust, TRD skid plate, AntennaX shorty, AFE Drop-In dry filter, Custom Axleboy light bar w/PIAA 520 fogs, Custom black leather seats
    That looks bad ass!
  2. Apr 28, 2013 at 8:17 PM
    #9622
    mjbtaco
    mjbtaco low and slow
    Michael
    Montclair , so cal
    Turbo'd 95.5 extra cab and 2013 Silver DCSB TRD Sport
    PERFORMANCE Custom Turbo Setup FRONT SUSPENSION Drop Spindles by Aaron Carswell 01-04 Swaybar Endlinks Energy Suspension Endlink Bushings Cando Upper Control arms QA1 coilovers with 8" spring Custom 4 pot Brembo BBK Modified lower control arms with mjbfab qa1 mounting plates and Poly bushing sleeves REAR SUSPENSION Chasis Tech drop leafs QA1 adjustable shocks weld in drop notch Gas tank cross member bridge 3" angled blocks 2013 Double Cab Short Bed TRD Sport Eibach Pro Truck Shocks front and rear Lifted to the 3rd setting on the front shocks
    I know I'm pretty excited about it lol
  3. Apr 29, 2013 at 8:30 AM
    #9623
    Gear Head
    Gear Head Well-Known Member
    Jacob
    Winston Salem, NC
    96 Tacoma
    fj60 front, fj80 rear, full hydro, 5.29's, welded, twin sticked 2.28/4.70 duals, 39.5's, inboarded 63's
    Pros and cons of a mini 8ight vs. mini e revo? Wanting to pick up one. Leaning towards the mini 8ight.
  4. Apr 29, 2013 at 3:25 PM
    #9624
    littledvl
    littledvl ride BMX!
    Eric
    Saint Leonard MD
    08 taco dc 4x4 / 15 tundra dc 4x4
    Too many to list
    Never had a mini e-revo but i do have a mini 8ight, the mini 8ight handles awesome for its size and is fast as hell on 3s I would imagine its not as good of a basher as the e-revo but I have flipped mine countless time and have only broken little stuff that can be beefed up easily.
    What do you plan to run on? The mini 8ight is good for onroad and track like surfaces, the mini e-revo has much more suspension and can handle offroad much better.
  5. Apr 29, 2013 at 8:09 PM
    #9625
    littledvl
    littledvl ride BMX!
    Eric
    Saint Leonard MD
    Too many to list
    Did a little work on my trekker
  6. Apr 29, 2013 at 8:28 PM
    #9626
    Gear Head
    Jacob
    Winston Salem, NC
    96 Tacoma
    Wanting it mostly for the track since I can't afford an 1/8 scale buggy haha. I've heard the mini 8ight's are very good bashers too. Obviously ground clearance would be an issue with that but I don't really run my rc's in grass, besides my wraith. Mostly run at the track. Big dirt lot with some ditches there to mess around with too. People tend to look at me funny when I give my slash hell through the ditch and the gravel then hop right on the track and try to clear big triples that always turn out bad. I'm not afraid to really run my stuff haha. I've actually only broken 2 parts in over a year of beating the snot out of my slash. 1 rear bearing carrier and 1 front a arm. I tell you this to give you insight to how I drive. I've heard the erevo needs a lot of upgrades to be reliable. The only problem I've heard with the mini 8ights are the shock ends.
  7. Apr 29, 2013 at 8:36 PM
    #9627
    littledvl
    littledvl ride BMX!
    Eric
    Saint Leonard MD
    Too many to list
    Yeah first 2 times breaking my mini 8ight were shock ends.. first 3 months with my shash i snapped 3 driveshafts, 2 a-arms, bent the shit out of a shock, so im not too easy on my stuff, i try to break it at times so i have something to buy/do.. But in my opinion id say go with a mini 8ight, you will have alot of fun with it even on 2s which is what i mainly run.
  8. Apr 29, 2013 at 9:04 PM
    #9628
    Gear Head
    Jacob
    Winston Salem, NC
    96 Tacoma
    Yeah I think I will. Idk how I haven't snapped a driveshaft yet... I ran 3s for a while with a fully tightened slipper and still didn't break one. My shock shafts stay bent so I don't really count them as broken haha. Although I did break down and rebuild them all the other day with new shafts, 45w in rear, 50w in front, and linear rate losi springs. Now just gotta wait for the track to dry up to test out the new suspension.
  9. Apr 29, 2013 at 9:46 PM
    #9629
    littledvl
    littledvl ride BMX!
    Eric
    Saint Leonard MD
    Too many to list
    This was happening everytime out, went with some pl powerstrokes, never had another issue and they work soo much better.
  10. Apr 30, 2013 at 6:56 PM
    #9630
    Gear Head
    Jacob
    Winston Salem, NC
    96 Tacoma
    Holy shit that's way worse than anything I've done. That's including bombing around on 3 cell. Most I've gotten is a slight banana and I beat the shit out of mine. You can get hardened shafts for the stock shocks but they are $10/ pair. Stock is only $3. The pl shafts might be a bigger diameter which would def help.
  11. May 2, 2013 at 1:28 PM
    #9631
    05tundra13
    05tundra13 Well-Known Member
    Devin
    Simi Valley
    05 tundra doublecab
  12. May 2, 2013 at 2:33 PM
    #9632
    Dmonkey
    Dmonkey Well-Known Member
    Branden
    NorCal
    VZN159L (2002 DC)
    Eibach height adjust shocks in front, KYB monomax shocks in the back. Stock springs front and back. Level 8 MK6 10mm offset wheels on Cooper ATP tires (stock size)
    This may not be your issue but every time I've seen that happen a lot as you describe, the shocks have been mounted too tight, not allowing them to freely rotate. You may want to upgrade to aluminum bodied shocks at some point as well
  13. May 2, 2013 at 5:14 PM
    #9633
    Shiftin2Sixth
    Shiftin2Sixth Well-Known Member
    Curt (kûrt)
    Utah
    2021 MGM TRD-OR DCSB 4WD
    I know its pretty lame but I switched up my T4.1 & GT2 to the T4.2 front ends. I just like the look.
  14. May 2, 2013 at 6:36 PM
    #9634
    mjbtaco
    Michael
    Montclair , so cal
    Lol the guy right above you would agree on the looks.
  15. May 2, 2013 at 8:31 PM
    #9635
    mjbtaco
    Michael
    Montclair , so cal
    Should be getting my twice repaired rx8 for this on saturday.
  16. May 2, 2013 at 10:08 PM
    #9636
    Shiftin2Sixth
    Curt (kûrt)
    Utah
    I was down at Pegasus a few weeks ago, maybe month or so, and saw you racing your truck. Nice job!
  17. May 2, 2013 at 10:32 PM
    #9637
    mjbtaco
    Michael
    Montclair , so cal
    Thanks man! haha was i in last?? lol Say whats up next time you're out there! I wont be working weekends pretty soon so I'll probably be there almost every Friday and Saturday haha.
  18. May 2, 2013 at 10:34 PM
    #9638
    mjbtaco
    Michael
    Montclair , so cal
  19. May 2, 2013 at 11:27 PM
    #9639
    Shiftin2Sixth
    Curt (kûrt)
    Utah
    Very cool!! I haven't raced in over ten years. I'm thinking about getting back into it. Last time I raced was at m&m raceway in corona and before that the ranch pit shop in Pomona.
  20. May 3, 2013 at 1:12 AM
    #9640
    mjbtaco
    Michael
    Montclair , so cal
    Nice! I never made it to those tracks lol im too new to the rc community.
