Anyone into R/C?
Discussion in 'Sports, Hobbies & Interests' started by A.D., Feb 7, 2009.
  1. Apr 20, 2014 at 4:55 AM
    Slimwood Shady
    Slimwood Shady I love your mom!
    Linwood
    San Antonio, TX
    '23 TRD Pro Tundra; 996TT; '16 Odyssey
    #nomods
  2. Apr 20, 2014 at 6:09 AM
    JimBeam
    JimBeam BECAUSE INTERNETS!! Moderator
    JB
    2015 Tundra
    www.hobbyking.com
  3. Apr 20, 2014 at 9:29 AM
    logoris
    logoris Member
    Id say reedy or crc and towerhobbies.com or amainhobbies.com
    Also make sure you get a good charger too
  4. Apr 20, 2014 at 10:30 AM
    Upsblaine
    Upsblaine member
    Blaine
    Mills, HI
    2012 MGM DC 4x4 TRD SPORT
    Pelfreybilt color matched front bumper, Baja Designs S8, TRD supercharger w/ URD pulley, King coilovers w/compression adjusters, King Resi shocks w/Dakar leaf pack, Total Chaos Uniball UCA, Wheelers Superbumps, ToyTec flip kit, CMC, SnugTop supersport w/BedRug, Murano Retrofits (ambiguous) + Vled V3 switchbacks Amber/Amber, Frontrunners rack, red extended brake lines (OCtaco), 16x8 SCS SR8 wheels w/ 285/75/16 Goodyear MTRs + spare, AFE CAI + (Coupe) cover, TRD catback exhaust, TRD Pro Grille, TRD Japan Oil cap, TRD Radiator cap, TRD shift knob, Pelfreybilt battery tray + Diehard 31M, Fumoto qwikvalve, Viair10007 Constant Duty OBA, Redline hood struts, Rigid SRM + B.A.M.F mount, WeatherTech DigitalFit & Deflectors, BlueSea fuse panel mod, Ottraw switches, (ImMrYo) mirror bracket, (Matt123) recovery shackle bracket, B.A.M.F bolt on sliders, Wet Okoles, Factor55 Hitchlink, Rigid Sr-Q, Diff Breather Mod, pop&lock pl8521, 2013 touchscreen head unit, (BeeRadd) PRO kit, (Mattgecko) Bedlight kit. Hilift w/ ATO mount, V2W Flyzeye, BlackVue DR600GW-HD, Kleinn Train Horn, IAS 10lbs CO2 tank. Coming Soon. ..Speedhut gauge, PLX gauges, ARB compressor
  5. Apr 20, 2014 at 11:31 AM
    logoris
    logoris Member
    you should enjoy your blitz, it is the efirestorm chassis its very light, and works well at any speed, mines built for top speed but it was great on lower speed too
  6. Apr 20, 2014 at 11:38 AM
    Fink
    Fink Motorboatin' SOB
    Orlando, FL
    2013 Regular Cab 4x4
    WeatherTechs, 265/75-16 DuraTracs, ATX Mojave Teflon Wheels, ARE V-Series Shell
  7. Apr 20, 2014 at 9:09 PM
    JimBeam
    JB
    2015 Tundra
    Started the tear down of Hunter's old bruiser today
    Body is in good shape, motor is good. Doesn't look like the servos/receiver saw much water but haven't been able to test them yet
    Frame/springs and a few small metal parts have some rust on them, and there is a LOT of grime and mud built up
    Currently soaking metal parts in a vinegar bath to loosen up some of the surface rust and caked on crap...
    I hope I can remember how it all goes back together :anonymous:
    I will need to replace the bumpers, and some of the rubber parts like shock boots and a couple of bushings and I gotta put new shock oil in the shocks and it's gonna need new tires
    Outside of that, I'm probably gonna upgrade the electronics and move away from the resistors and MSC and put in a new ESC and 2 new servos and call it a day.
    I may see about pushing new bearings into the axles and hubs, but the current stuff seems to be working ok and spinning pretty smooth
  8. Apr 20, 2014 at 9:27 PM
    littledvl
    littledvl ride BMX!
    Eric
    Saint Leonard MD
    08 taco dc 4x4 / 15 tundra dc 4x4
    Too many to list
    Got all moved into my new house this weekend :D
    Snapped a pic of the r/c's, had the "nicer" stuff in the back seat..
  9. Apr 21, 2014 at 1:36 AM
    mjbtaco
    mjbtaco low and slow
    Michael
    Montclair , so cal
    Turbo'd 95.5 extra cab and 2013 Silver DCSB TRD Sport
    PERFORMANCE Custom Turbo Setup FRONT SUSPENSION Drop Spindles by Aaron Carswell 01-04 Swaybar Endlinks Energy Suspension Endlink Bushings Cando Upper Control arms QA1 coilovers with 8" spring Custom 4 pot Brembo BBK Modified lower control arms with mjbfab qa1 mounting plates and Poly bushing sleeves REAR SUSPENSION Chasis Tech drop leafs QA1 adjustable shocks weld in drop notch Gas tank cross member bridge 3" angled blocks 2013 Double Cab Short Bed TRD Sport Eibach Pro Truck Shocks front and rear Lifted to the 3rd setting on the front shocks
    ridiculous lol
  10. Apr 21, 2014 at 1:41 AM
    mjbtaco
    Michael
    Montclair , so cal
    finally put a lipo in my radio.
  11. Apr 21, 2014 at 1:47 AM
    mjbtaco
    Michael
    Montclair , so cal
    also painted this for one of my drivers.
  12. Apr 21, 2014 at 5:18 AM
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig... 4-link long travel
    Cool videos Fink. I can't believe you got 20 minutes of flight time.
    2 servos?
    dagum! :eek:
    I see that all of the time. other than not having to buy new AAs ever again, is there another advantage to the LiPos in transmitters?
    How do you do the little dots?
  13. Apr 21, 2014 at 5:19 AM
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
  14. Apr 21, 2014 at 5:39 AM
    mjbtaco
    Michael
    Montclair , so cal
    lipos are better cuz they last longer lol. just easier and cheaper.
    and the dots are done with magic! :p
    stencils.
  15. Apr 21, 2014 at 7:26 AM
    JimBeam
    JB
    2015 Tundra
    yup
    it currently has 3
    1 for mechanical speed controller
    1 for steering
    1 for shifting gears (3 speed tranny)
    removing the MSC and resistors and replacing them with an ESC will eliminate 1 servo
    I could eliminate a 2nd and have it locked into low gear, but I don't particularly feel like digging into the tranny right now
  16. Apr 21, 2014 at 7:41 AM
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Gotcha. didn't know it had a 3 speed, and i've never seen a mechanical speed control for an electric vehicle.
  17. Apr 21, 2014 at 7:58 AM
    SMKYTXN
    SMKYTXN If it can't be overdone it's not worth doing Vendor
    Nathan
    Houston
    11, 4dr, TRD Sport, 6sp
    DCFB
  18. Apr 21, 2014 at 8:00 AM
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    I take it you saw the like mike posted on facebook? i feel like that's a good way for me to spend every last penny i have lol.
  19. Apr 21, 2014 at 8:04 AM
    SMKYTXN
    Nathan
    Houston
    DCFB
    Sure did. But man does that look like fun. Quad copter for stable filming, then full on high speed fixed wing shots.
  20. Apr 21, 2014 at 8:13 AM
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    if you're ok ahveing a transmitter for each flight mode, it'd be pretty easy to acomplish.
