Anyone into R/C?
Discussion in 'Sports, Hobbies & Interests' started by A.D., Feb 7, 2009.
  1. Dec 23, 2011 at 5:31 AM
    #1141
    SACTOWN
    SACTOWN Well-Known Member
    Greg
  2. Dec 23, 2011 at 6:44 AM
    #1142
    FearNothing321
    FearNothing321 You gonna eat that taco?
    Tony
    Knoxville, TN
    2019 Audi S3
    more careful maintenance than anything. Just remember you are going to need a ESC with a low voltage cutoff, to use LiPo batteries
  3. Dec 23, 2011 at 9:27 AM
    #1143
    t4daddy
    t4daddy Well-Known Member
    North Alabama
    2008 PreRunner Double Cab
    No, 7.2 volts is 7.2 volts. To increase speed, you increase volts. Now your runtimes can increase by quite a bit (depending on mah). The best thing about li-po is there discharge rate, it's nice and linear, vs a ni-cad, ni-mh, whose dicharge has a bigger curve. You know how hot a ni-cad, ni-mh battery is for the first minute or so, then fades until the battery is dead. Li-po have almost the same rate of discharge from beginning to end. Another advantage of li-pos are there weight, much lighter, (from this aspect alone you may see faster speeds). Now sure, when you drop a new li-po in a model you've been running older tired out ni-cads, or ni-mhs in, there will be a increase in power/speed, but there would be as well with new ni-cads, ni-mhs.
  4. Dec 23, 2011 at 10:20 AM
    #1144
    FearNothing321
    Tony
    Knoxville, TN
    2019 Audi S3
    also speed of the vehicle can depend on the pinion/spur gearing, as well as how many turns are in the motor (i.e. a 4.5T motor is a lot quicker than a 17.5T motor)
  5. Dec 23, 2011 at 10:41 AM
    #1145
    JStradaXR
    JStradaXR Well-Known Member
    Chuy
    Ontario CALI
    06 X Rated
    Everything but boost =[
  6. Dec 23, 2011 at 10:45 AM
    #1146
    FearNothing321
    Tony
    Knoxville, TN
    2019 Audi S3
    Kyosho, much better quality, plus there are aftermarket parts for it as well
    EDIT: the Kyosho buggy is more of a 1/10 scale vehicle, it shares a lot of parts with the Ultima SC truck
  7. Dec 23, 2011 at 10:53 AM
    #1147
    FearNothing321
    Tony
    Knoxville, TN
    2019 Audi S3
  8. Dec 23, 2011 at 11:55 AM
    #1148
    JStradaXR
    Chuy
    Ontario CALI
    06 X Rated
    theres probably a conversion kit too say if i have the sc truck
  9. Dec 23, 2011 at 12:04 PM
    #1149
    FearNothing321
    Tony
    Knoxville, TN
    2019 Audi S3
    you probably would only need the chassis, body mounts and a few odds and ends to convert it
  10. Dec 23, 2011 at 1:25 PM
    #1150
    SACTOWN
    Greg
    Thanks guys helps a lot
  11. Dec 23, 2011 at 1:31 PM
    #1151
    FearNothing321
    Tony
    Knoxville, TN
    2019 Audi S3
    no problem :thumbsup:
  12. Dec 23, 2011 at 1:37 PM
    #1152
    SACTOWN
    Greg
    Guess I am going to have to get the slash4x4 when I get money to have my speed. :)
    One for crawling and one for speed. Lol
  13. Dec 23, 2011 at 1:57 PM
    #1153
    Fiveology
    Fiveology Well-Known Member
    MD
    11 DC TX PRO 4X4
    3" Lift OME 885's with a top plate spacer in front, Toytec AAL in rear, OME Nitrochargers, DWreck/FamousFab bolt on sliders, 255/85R16' KM2's
    Not true, a lipo cell has a nominal voltage of 3.7, so a 2 cell (2s) lipo has a nominal voltage of 7.4. The sub-c cells used to make NiCD and NiMH packs have a nominal voltage of 1.2, that is why you see 6 (7.2 volts),7 (8.4 volts), and sometimes even 8 (9.6 volts) cells in a pack. There is no such thing as a 7.2 volt lipo. Stepping up to a 3 cell (3s) lipo gives you a nominal voltage of 11.1. So yes a lipo, even a little 2s, will provide more power then a 7.2 NiCD or NiMH battery. And that is just nominal voltage, most lipo cells fully charged are more like 4.2 volts/cell, so a fully charged 2s lipo is really 8.4 volts or exactly equal to a 7 cell NiCD/NiMH pack. Yes all the other benefits you stated are true, but the fact is lipos are more powerful then NiCD and NiMH packs per cell.
  14. Dec 23, 2011 at 2:12 PM
    #1154
    Tacomanator
    Tacomanator Well-Known Member
    Clam Slammer
    Southern Cali
    King 2.5" extended travel coilovers with compression adjusters, Camburg UCA's, King 2.5" rear shocks, TRD 1st gen CAI.
    x2!
    A fully charged NiMH will also have a higher voltage than what it's rated at. The 8.4v that came with my Slash is well over 10v when it's fresh off the charger, but ot quickly fades.
  15. Dec 23, 2011 at 2:38 PM
    #1155
    SACTOWN
    Greg
    Nice thanks again!! Learned more in this thread about lipos then I have read in the last 24 hours on the web.
  16. Dec 23, 2011 at 2:41 PM
    #1156
    Fiveology
    MD
    11 DC TX PRO 4X4
    Exactly, and that is where a lipo's better discharge rate comes into play. If you ran a 2s lipo compared to your 7 cell NiMH, your truck would be faster initially with the NiMH, but within a few minutes the NiMH would drop below 8.4v, while the lipo would hold near that 8.4 volts almost the entire run time. So as your 7 cell NiMH pack keeps getting slower and slower, the lipo continues to provide similar performance to that first pull on the throttle. This is of course assuming similar MaH ratings.
    Does your Slash have the Velineon brushless in it? If so you really need to try a 3s lipo in it. I run a Velineon on 3s in one of my modified SCX-10s and it is pretty crazy.
  17. Dec 23, 2011 at 2:42 PM
    #1157
    Fink
    Fink Motorboatin' SOB
    Orlando, FL
    2013 Regular Cab 4x4
    WeatherTechs, 265/75-16 DuraTracs, ATX Mojave Teflon Wheels, ARE V-Series Shell
    Finally opened the box for my SCX10 and lipos - I'm so stoked!
    Unfortunately, that's as far as I've gotten...
    Fink
  18. Dec 23, 2011 at 2:47 PM
    #1158
    Tacomanator
    Clam Slammer
    Southern Cali
    Yeah, there's no comparison when it comes to lipo. My 2s 40c blows my NiMH out of the water in every way. Plus, you can find them cheaper than NiMH.
  19. Dec 23, 2011 at 2:55 PM
    #1159
    SACTOWN
    Greg
    So what is a good company that makes lipos?!?!
  20. Dec 23, 2011 at 2:58 PM
    #1160
    Fink
    Orlando, FL
    The two Gens Ace batteries I got from HobbyPartz.com seem like great quality so far. I have yet to actually use them though. :mad:
    Fink
