Anyone into R/C?
Discussion in 'Sports, Hobbies & Interests' started by A.D., Feb 7, 2009.
  1. Apr 13, 2015 at 5:58 AM
    mjbtaco
    mjbtaco low and slow
    Michael
    Montclair , so cal
    Turbo'd 95.5 extra cab and 2013 Silver DCSB TRD Sport
    PERFORMANCE Custom Turbo Setup FRONT SUSPENSION Drop Spindles by Aaron Carswell 01-04 Swaybar Endlinks Energy Suspension Endlink Bushings Cando Upper Control arms QA1 coilovers with 8" spring Custom 4 pot Brembo BBK Modified lower control arms with mjbfab qa1 mounting plates and Poly bushing sleeves REAR SUSPENSION Chasis Tech drop leafs QA1 adjustable shocks weld in drop notch Gas tank cross member bridge 3" angled blocks 2013 Double Cab Short Bed TRD Sport Eibach Pro Truck Shocks front and rear Lifted to the 3rd setting on the front shocks
    dirt was just that tacky lol
  2. Apr 13, 2015 at 5:58 AM
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig... 4-link long travel
    pretty looking track. indoor/covered?
  3. Apr 13, 2015 at 6:07 AM
    mjbtaco
    Michael
    Montclair , so cal
    yup indoor.
  4. Apr 13, 2015 at 6:16 AM
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
  5. Apr 13, 2015 at 6:22 AM
    mjbtaco
    Michael
    Montclair , so cal
    lol same here. the video i posted is a perfect example of what they are talking about. Only thing is that all racers are now accustomed to these high bite highly groomed tracks so trying anything less than that leads to a bunch of bitching. i started driving on some super loamy dirt and i had a ton of fun. I wouldnt mind doing it again.
  6. Apr 13, 2015 at 6:39 AM
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    sounds like the track in Houston that I always went to (the one that your team driver went to). always loose dirt, dust, and chunks of hardened dirt all over the track, but it was always a blast. Those crappy track conditions combined with my 2wd trucks/buggies are the only reason I ever learned throttle control. would still be gunning it everywhere if I only ever went to the perfectly groomed clay track at Mike's.
  7. Apr 13, 2015 at 6:46 AM
    SMKYTXN
    SMKYTXN If it can't be overdone it's not worth doing Vendor
    Nathan
    Houston
    11, 4dr, TRD Sport, 6sp
    DCFB
    Colin, if you can't get enough weight into the keel with lead shot you can try tungsten. That's what I used to use in my pinewood derby cars.
  8. Apr 13, 2015 at 7:08 AM
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    I should have more than enough with the scuba weights. I was actually thinking about using tungsten putty, which would have zero air voids, but when I looked further into it, the "putty" portion brought the density way down.
    if I join a race league around here, i'll just go all out and cast a custom bulb anyway
  9. Apr 13, 2015 at 7:12 AM
    SMKYTXN
    Nathan
    Houston
    DCFB
    Yup, the putty isn't near the weight of solid tungsten. What are the dimensions of the bulb? I could machine one, that is if the cnc ever starts working at the shop. Acutally, I could probably turn one on the lathe if it's symmetric.
  10. Apr 13, 2015 at 7:28 AM
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    the stock one is symmetric, but if I were to cast an aftermarket one, I would either do a winged bulb, or a flattened one. either will give better tracking while heeled over, than a symmetrical one.
    it's probably about 8-9'' long, and an inch in diameter at the largest point.
    even if it were turned on a lathe, you'd have to mill out the "key-way" where the bottom of the keep fits in the bulb to keep it straight.
    i'll see how it sails first though, before getting too deep into keel design. that's a lot of hydrodynamics that I haven't even thought about in the last 5 years.
  11. Apr 14, 2015 at 11:12 PM
    mjbtaco
    Michael
    Montclair , so cal
    Latest stadium truck.
  12. Apr 15, 2015 at 10:05 AM
    Brake Weight
    Brake Weight But it hasn't rained in weeks...I'll make it.
    Deep South near the Third Coast
    Taco pulling 33s and a B6 pushing 33psi
    Weld on sliders, fiberglass shell, 12k winch in an Elite Offroad bumper, front Aussie Lunchbox
    My stable now.
  13. Apr 15, 2015 at 12:22 PM
    cgchambers93
    cgchambers93 Well-Known Member
    Christopher
    Houston
    14 Tacoma SR5 4x4
    Wheels and tires, Billstein suspension
    Nice!
  14. Apr 15, 2015 at 4:51 PM
    Brake Weight
    Put a winch on the brodozer with a redneck engineered fairlead made from a chrome 3mm LED mount.
    Now I need a real/scale fairlead and some scale cable and a scale hook.
  15. Apr 15, 2015 at 4:53 PM
    Hairy Taco
    Hairy Taco Jungle of Love
    North of Hell
    08 TRD
    Your work is sharp man!
  16. Apr 16, 2015 at 12:36 AM
    mjbtaco
    Michael
    Montclair , so cal
    thank you very much!
  17. Apr 18, 2015 at 7:31 PM
    bvrc
    bvrc Well-Known Member
    Buena Vista, CO
    09 DCSB supercharged
  18. Apr 18, 2015 at 7:33 PM
    BMOC
    BMOC Well-Known Member
    Paden
    Phoenix, AZ
  19. Apr 19, 2015 at 11:54 PM
    mjbtaco
    Michael
    Montclair , so cal
    Buggy body for a local electronics (motors) company owner
  20. Apr 20, 2015 at 5:21 AM
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    no running shots or videos yet, but here's after rigging up at the lake. sailed beautifully.
    modifications made:
    -25% more weight than required in the keel
    -All rigging has been completely redone with no stretch synthetic line.
    -Plastic anchor points on hull have been replaced with metal fittings.
    I still need to tune the sails a little, but other than that, it's running about flawlessly.
