Anyone into R/C?
Discussion in 'Sports, Hobbies & Interests' started by A.D., Feb 7, 2009.
  1. Dec 19, 2015 at 3:14 PM
    Z50king
    Z50king DCLBOR4X4FTW
    Eric
    Southern California
    2016 DCLB Off Road 4x4 Super White
    Stock and loving it
    Get MIP CVDs
    Dajeepman likes this.
  2. Dec 19, 2015 at 6:18 PM
    Hairy Taco
    Hairy Taco Jungle of Love
    North of Hell
    08 TRD
    I really like the Twin Hammers platform, it is a solid unit. I assume you are running the stock 78T spur? How many teeth on your pinion?
  3. Dec 19, 2015 at 6:22 PM
    Deathbysnusnu
    Deathbysnusnu Work is just a daily detour to happy hour.
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    28T pinion and yes 78T spur. Seems just a bit too fast in low gear too. I haven't had it outside yet, just carpet cruising for now but it could use some more low end. In high gear at full throttle, the tires get real skinny, so I think it will have plenty of top end. :p
  4. Dec 19, 2015 at 6:24 PM
    Deathbysnusnu
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    The kit came with slightly taller rubber that the rtr does so that may have something to do with the gearing. The 28T was suggested in the kit to start with.
  5. Dec 19, 2015 at 6:31 PM
    Hairy Taco
    North of Hell
    08 TRD
    That must be a quick motor. How many kv?
  6. Dec 19, 2015 at 6:36 PM
    Deathbysnusnu
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    3300. It was the mid range choice offered by Horizon Hobby for hop ups.
    The thing runs super smooth and quiet, absolutely no cogging at low speeds. I just think it would benefit from a smaller pinion.
    If the TX had ARC control setting, I think I could use it as is. But it doesn't.
  7. Dec 19, 2015 at 6:40 PM
    Brake Weight
    Brake Weight But it hasn't rained in weeks...I'll make it.
    Deep South near the Third Coast
    Taco pulling 33s and a B6 pushing 33psi
    Weld on sliders, fiberglass shell, 12k winch in an Elite Offroad bumper, front Aussie Lunchbox
    Can you gear down just the low side of the tranny?
  8. Dec 19, 2015 at 6:51 PM
    Deathbysnusnu
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    I don't think so, or I'm not aware if I'm able too.
    Maybe you guys know more about this...
    With my old Airtronics MX-3 it has a setting called ARC, which reduces the throttle input (and steering if needed) for the first 1/4 trigger squeeze, makes it more of a fine control, then goes into regular acceleration for the rest of the throttle curve. Extremely helpful for taming toys that have an abundance of power. The Savage has this setting almost maxed out so it doesn't do backflips by just bumping the trigger. I can actually run it at slow speeds without having an egg between my finger and the trigger.
    For the next half of my explanation...
    The new DX4C has EXPO, which I am familiar with for helicopters. It does the same thing as ARC, softens the controls around center, leaves a little finer control.
    Using this setting only leaves me with a dead spot at the initial throttle, then goes right into acceleration....
    I have calibrated the ESC per the instructions, maybe I need to re-calibrate after setting the EXPO so the ESC recognizes it???
    Thoughts?
  9. Dec 19, 2015 at 6:57 PM
    Hairy Taco
    North of Hell
    08 TRD
    Not to my knowledge. Unless there is an aftermarket gear for the tranny
    Personally, if I wanted crawler precise low end, I would go sensored brushless, or get a nice brushed system.
  10. Dec 19, 2015 at 7:04 PM
    Deathbysnusnu
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    Agreed.
    Not really needing the fine crawl control, I already have a stupid slow brushed crawler (65 turn) that will move dining room chairs on it's own..:p
    I'll know more when I open it up in the street tomorrow. I'm not really interested in super high speeds, I just want it to be a nice mix of both. I'm betting a smaller pinion will do it, at the sacrifice of some high speed.
  11. Dec 19, 2015 at 7:22 PM
    Hairy Taco
    North of Hell
    08 TRD
    In your case, a smaller pinion sounds like a good idea to me too. I am planning to put a slighter higher teeth count in my TH to gain some speed as I am a bit on the slow end of things.
    Did you put the sway bars on? It sounds like you will definitely need them.
  12. Dec 19, 2015 at 7:27 PM
    Deathbysnusnu
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    Only in the rear. The front seems to have good stability. It came with 3 different levels of sway bar too, so using the mid range for now.
    I may remove it later on but for now it may save me from a roll over.
  13. Dec 19, 2015 at 7:35 PM
    Hairy Taco
    North of Hell
    08 TRD
    The rollovers without it may come too easy. It sounds like you have quick rig there.
    There is a nice little rear axle truss out there that alters the geometry of the rear linkage. It seems to help temper the rollover somewhat.
  14. Dec 19, 2015 at 7:39 PM
    Deathbysnusnu
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    Yep, I've seen that and already have it on a mental list of mods to come. :)
  15. Dec 19, 2015 at 7:45 PM
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    Which way did you go with the expo? Sounds like you went the opposite way. I have expo and triple rates dialed in all my planes. On my futaba air TX negative expo gets the results you're after, but I know different manufactures are opposite.
  16. Dec 19, 2015 at 7:49 PM
    Deathbysnusnu
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    I tried both ways. One direction leaves a dead space in the beginning, the other direction just gives it more punch on the trigger.
  17. Dec 19, 2015 at 7:53 PM
    Squeaky Penguin
    Brett
    Not familiar with Dynamite ESC's, but do you have computer programmable throttle curves? Was always playing with those on my old Castle setup on my 8ight-T.
  18. Dec 19, 2015 at 7:56 PM
    Deathbysnusnu
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    Not computer programmable, my first time with Dynamite too.
    It has 4 start modes and I have it in the slowest mode.
  19. Dec 19, 2015 at 9:52 PM
    Z50king
    Eric
    Southern California
    Stock and loving it
    Calibrate the esc with the EPA set to 100. Then crank down the EPA to 20 and see how the low speed control is. That will tell you if it's the controller or the esc and engine setup
  20. Dec 19, 2015 at 9:53 PM
    Z50king
    Eric
    Southern California
    Stock and loving it
    You do, do you? I have one for sale...
