Anyone into R/C?
Discussion in 'Sports, Hobbies & Interests' started by A.D., Feb 7, 2009.
  1. Jan 30, 2018 at 5:48 AM
    AJH387
    AJH387 Well-Known Member
    AJ
    Pittsburgh, PA
    '19 TRD OR DCLB
    Just the antenna. The Futaba receivers that I use have a long wire-antenna. On my 1/8 I tuck it in the receiver box and run a little shorty post (you can't even see it on the truggy, it's under the body). But I couldn't find anywhere to route it on the 22 4.0SR, so I just ran a post.
  2. Jan 30, 2018 at 3:09 PM
    t4daddy
    t4daddy Well-Known Member
    North Alabama
    2008 PreRunner Double Cab
    I was being facetious, I just haven’t seen a full length antenna tube.
  3. Jan 30, 2018 at 3:18 PM
    AJH387
    AJ
    Pittsburgh, PA
    '19 TRD OR DCLB
    I sorta figured but just giving an explanation. I just didn't want the wire in the way, tucked inside (with so little room on this model). I try to do it if I can but in this case, I thought the antenna was the best route.
  4. Feb 2, 2018 at 2:17 PM
    trd_kevin
    trd_kevin Well-Known Member
    Kevin
    2017 White Tacoma TRD 4x4
    Too much
    yeah, I have an axial scx10 II
  5. Feb 2, 2018 at 3:01 PM
    Brake Weight
    Brake Weight But it hasn't rained in weeks...I'll make it.
    Deep South near the Third Coast
    Taco pulling 33s and a B6 pushing 33psi
    Weld on sliders, fiberglass shell, 12k winch in an Elite Offroad bumper, front Aussie Lunchbox
    That’s the kit I’ve got, too. A $5 ESC from fleaBay would be enough.
    I need a servo, motor mount, drive shaft to the transfer case, longer shocks, and upper links. LOL. Not much left to do.
    https://www.ebay.com/ulk/itm/282821985949
    Jim Bob likes this.
  6. Feb 4, 2018 at 6:28 AM
    Brake Weight
  7. Feb 4, 2018 at 8:34 AM
    Silverspool
    Silverspool Come at me Bro!
    Frank
    DFW
    18T4RORP 17GT350
    Anyone seen my wallet?
    Brake Weight[QUOTED] likes this.
  8. Feb 6, 2018 at 9:16 AM
    10tacosr5
    10tacosr5 Well-Known Member
    Washington Twp, South NJ
    2010 Tacoma SR5 DCLB
    5100s/Headstrong Coils/Deaver AAL/Level8 MK6/FalkenWildpeakAT3
    Just found this thread. Built this scx 10 from the ground up. Made the mistake of bringing iit on the beach with me amd never cleaned it off. Time for a rebuild i guess! The boat is a blackjack 26, been so long i forget what motor esc combo i have in it, but i clocked it at 60mph+...the trailer i custom built out of aluminum and old coil springs and shocks from a onroad racer i had.
  9. Feb 6, 2018 at 9:19 AM
    Brake Weight
    Surprised it’s still going.
  10. Feb 6, 2018 at 9:23 AM
    10tacosr5
    Both drive shafts are locked up, this thread made me go out and spray penetrating oil on them, hoping to free them up, if not guess ill be ordering another set of mip driveshafts, lol. Axles seem to be free and motor and trans are ok. ill clean up the rust and never bring it on the beach again, haha.
    TXpro4X4 likes this.
  11. Feb 6, 2018 at 11:00 AM
    Egnaro
    Egnaro Watch this
    Brett
    AZ
    16 Inferno DCSB Offroad 4x4
    Ricochet full skids, Mobtown rear with swing-out, toytec boss 2.0, OV tuned
    Can you show some closeups of that trailer? I want to try to build one
  12. Feb 6, 2018 at 11:04 AM
    10tacosr5
    its not pretty by any means but it gets the job done and is solid, lol. let me know what angles you want...
  13. Feb 6, 2018 at 11:28 AM
    Egnaro
    Egnaro Watch this
    Brett
    AZ
    What did you use for axles
  14. Feb 6, 2018 at 11:29 AM
    Silverspool
    Frank
    DFW
    18T4RORP 17GT350
    I think he used axles
    TXpro4X4 and Egnaro[QUOTED] like this.
  15. Feb 6, 2018 at 11:39 AM
    Brake Weight
    If the oil doesn't help I have a suggestion. Pull them off and soak them in a tall glass with a mix of tablesalt and water. All the saltwater to fill the female side of the slip and let it sit for 10-20 minutes. Once they free up a good rinsing in fresh water followed by a blow gun and some more oil. Some "Hair of the Dog" of sorts.
  16. Feb 6, 2018 at 11:53 AM
    10tacosr5
    its actually brake line. 5/16th maybe? i forget. but then i put a rod through sticking out on each end that was the same inside diameter of the wheel. works fairly well, never had them lock up on me.
  17. Feb 6, 2018 at 11:54 AM
    10tacosr5
    will deffinetly try that! thanks! so far the rear driveshaft is starting to move some, front is still pretty solid.
  18. Feb 8, 2018 at 3:21 PM
    Silverspool
    Frank
    DFW
    18T4RORP 17GT350
    You guys heard of LC Racing? Got one of em today, thing looks damn cool and has losts of metal. 1/14 scale ARTR for 205 shipped to door with a clear body.
    Dont have any basher now that im mostly racing or crawling but this should be fun on and off the track.
  19. Feb 8, 2018 at 3:39 PM
    SCRunner12
    SCRunner12 Tundra Troll
    Robert
    Santa Cruz, CA
    2006 Tundra DC, TRD, 4wd
    Ok finally bit the bullet. Got a Vaterra Twin Hammers rtr with 3800mAh battery. Seemed like the best of both worlds (crawl and speed) and the daughter will be stoked.
  20. Feb 8, 2018 at 3:50 PM
    Micatom33
    Micatom33 Under the Truck with Beer!
    Santa Cruz,CA
    2008 BSP DCSB
    This is my Losi nightcrawler. Had some fun times with this one around camp at night.
