Anyone into R/C?
Discussion in 'Sports, Hobbies & Interests' started by A.D., Feb 7, 2009.
  1. Jan 15, 2020 at 6:25 PM
    Scoobarooo
    Scoobarooo Well-Known Member
    Casey
    Brooksville, FL
    '02 DCSB TRD OR
    3" OME/Bilstein, Retrofits, Custom Bed rack/Toolbox, Amsoil Everything, tons of others.
    SuperShafty axles installed!
  2. Jan 15, 2020 at 6:59 PM
    20tacoma17
    20tacoma17 Well-Known Member
    2017 DCLB Sport AT
    Kings, 275/70/17, a few custom items, lots of Meso mods.
    That turned out great.
  3. Jan 15, 2020 at 8:58 PM
    Scoobarooo
    Casey
    Brooksville, FL
    '02 DCSB TRD OR
    Thanks! I wish I could say I’m done. I am for now, because of the move. Ill be back though!
    20tacoma17[QUOTED] likes this.
  4. Jan 16, 2020 at 12:47 AM
    SliMbo4.0
    SliMbo4.0 Well-Known Member
    Rick
    Colorado Front Range
    07 Tacoma DCSB TRD offroad
    BP51, BAMF hangers, BruteForce HC, SCS, Vagabond Drifter
    Anyone in need of some stadium truck bodies?
    Edit:First pic is actually the Proline Toyota SR5 front half
  5. Jan 17, 2020 at 7:14 AM
    Tundra2Play
    Tundra2Play Well-Known Member
    2003 Tundra Limited 4x4 AC 4.7 ltr
    Camburg UCAs, 5100’s, OME 885 up front, fox 2.0’s with 2” aal in rear. SCS F5’s wrapped in 315/75 Maxxis Buckshots
    Anyone in/near TX, the registration has been opened for the rc rock bouncing comp in Bridgeport Tx, for the Central Rock Racing Series. It’s a 1:1 rock bouncer and SXS event, that they’ve added 1/10 rock bouncers as an official event. Event is sponsored by some big names in RC and only going to get bigger from here!
    Hairy Taco, Bigpat_ca, Egnaro and 2 others like this.
  6. Jan 18, 2020 at 3:37 PM
    Red18Taco707
    Red18Taco707 Well-Known Member
    Richi
    Nor Cal
    Red 18 TRD POOR
    Mocking up my special ops team :infantry:
    C23703D7-37AF-40AB-8DD7-74EB4D60DA02.jpg DAA8C83A-C2FC-4639-9F2A-7EAEF31C2867.jpg
    Suprajim54, jeff b, SliMbo4.0 and 3 others like this.
  7. Jan 20, 2020 at 5:55 PM
    odomandr
    odomandr Well-Known Member
    Andy
    Fort Collins, CO
    2010 DCSBTRDOR silver streak mica 2023 T4R Ltd blizzard pearl
    Icon, SPC,, ARB, BAMF, Warfab, SCS, Michelin, Leer Stock
    I added a few upgrades to the grave digger truck. I finally swapped over to the optional 16t pinion. I put some axial lockouts and c hubs as well as axial universal axles and lower link mounts.
    I need to find an extra sway bar for the front and a pair of knuckles. It pulls a wheelie across the yard and is much better. I don't know if I want to do wheels and tires or not but I may pull the VO trans from the origin and get me a vfd.... Gotta wait on the portal axles off center but that case will eventually make it's way into the digger
    NABeast, 20tacoma17 and ian408 like this.
  8. Jan 24, 2020 at 11:22 AM
    Luke-Maine
    Luke-Maine Well-Known Member
    Luke
    15' White 2wd Access cab, 5 lugger
    Led Reverse Lights, Hitch, Foglights, K&N Air Filter.
    whats the body setup? Id love to build that
  9. Jan 24, 2020 at 3:09 PM
    chuymoreno
    chuymoreno Well-Known Member
    El Paso, Texas
    Tacoma SR5
    So I’m thinking about going back to this hobby...
    I recently pick up a nitro stampede for free, the truck was pretty much in pieces but I managed to put it back together.
    The thing is that the transmitter and receiver are missing and the servo motors are stuck so I came to the conclusion that it may be cheaper to get a new one (I think electric would be better).129739DF-B79A-4450-9655-45C06AD47087.jpg
    I wanted to ask you guys if you could recommend some RCs that won’t break the bank <300$. When I was in this hobby the only brand I knew was Traxxas.
    i want to use on the desert so maybe 4x4 would be better
  10. Jan 24, 2020 at 5:41 PM
    odomandr
    Andy
    Fort Collins, CO
    I wouldn't touch much sub 300. That's right about where I find 4wd good electronics and arrma losi or traxxas
    chuymoreno likes this.
  11. Jan 24, 2020 at 6:26 PM
    Tundra2Play
    Agreed. Save up another 100-200 and you will have much better equipment. Or consider finding used on FB groups, etc.
  12. Jan 24, 2020 at 8:40 PM
    Brake Weight
    Brake Weight But it hasn't rained in weeks...I'll make it.
    Deep South near the Third Coast
    Taco pulling 33s and a B6 pushing 33psi
    Weld on sliders, fiberglass shell, 12k winch in an Elite Offroad bumper, front Aussie Lunchbox
    FlySky Tx and Rx for sub $100. New servo for sub $50 and that nitro would be off and running.
  13. Jan 24, 2020 at 10:47 PM
    chuymoreno
    El Paso, Texas
    Tacoma SR5
    what do you think about redact racing ? Would it be like putting spacers instead of a king/ fox suspension ?
  14. Jan 24, 2020 at 10:51 PM
    chuymoreno
    El Paso, Texas
    Tacoma SR5
    Is FlySky the brand?
    Can I use a different brand For the tx and rx ? Because I was thinking about using jbweld for the servo motors at least just to try it out.
    The piston was stuck but I used w-40 and it worked it seems like it still has compression
  15. Jan 25, 2020 at 4:40 AM
    odomandr
    Andy
    Fort Collins, CO
    I'd take it apart and clean it in denatured alcohol then re assemble. Red cat isn't bad but part support is hit or miss in local shops
    Tundra2Play and chuymoreno like this.
  16. Jan 25, 2020 at 4:44 AM
    DawsonDestroyer
    DawsonDestroyer Well-Known Member
    Dawson
    Oklahoma City, Oklahoma
    2002 Tacoma Prerunner Double Cab
    Welded a rear cage for my baja rey :welder:
    Egnaro, Bigpat_ca, Hairy Taco and 8 others like this.
  17. Jan 25, 2020 at 8:37 AM
    Brake Weight
    FlySky is the brand of a cheap but good transmitter and receiver. For servo replacement, can’t really go wrong with Traxxas replacements. I’m not quite sure what the JBWeld is for.
  18. Jan 25, 2020 at 8:50 AM
    chuymoreno
    El Paso, Texas
    Tacoma SR5
    I will order one from Amazon to try it out. i was going to use the jbweld for the mounting tabs of the servo since I connected them to a microcontroller and they seem to be working now, but I think it better to get new ones
  19. Jan 25, 2020 at 8:57 AM
    Sparky.
    Sparky. Bought, built, totaled
    Dawson
    Enumclaw Washington
    ‘14 AC 6MT -R.I.P, ‘08 cummins
  20. Jan 25, 2020 at 2:16 PM
    odomandr
    Andy
    Fort Collins, CO
    Wrapped inside the lexan. Got my xr10 wraith bomber and now the Capra all with my topographic rips design. Going to talk to them about a sheet for me to use inside fenders and where not on a truck body
    NABeast, Scoobarooo and 20tacoma17 like this.
