Anyone into R/C?
Discussion in 'Sports, Hobbies & Interests' started by A.D., Feb 7, 2009.
  1. Dec 9, 2024 at 11:50 AM
    Roody
    Roody Well-Known Member
    Ross
    SW CT
    GX460
    That looks awesome!!! Enjoy it, let us know how you like it
    Kwikvette[QUOTED] likes this.
  2. Dec 9, 2024 at 2:16 PM
    but why tho
    but why tho Well-Known Member
    1991 Pickup
    These Injora driveshafts are beefy! Unfortunately I stripped a grub screw while trying to take the old shafts off. Had to disassemble everything, pull the transmission and drill the screw out. Thankfully everything went back together fine.
  3. Dec 9, 2024 at 4:54 PM
    Deathbysnusnu
    Deathbysnusnu Work is just a daily detour to happy hour.
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
  4. Dec 9, 2024 at 5:34 PM
    NABeast
    NABeast Un-Sub’d
    Paul
    Florida
    '08 4wD
    ImMrYo mirror bracket. A/C, P/W, Tilt, Cruise, AM/FM CD
    My IFS G speed build. It actually does pretty well.
  5. Dec 9, 2024 at 6:38 PM
    Deathbysnusnu
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    Amain has a 10% off store wide Green Monday sale.
    GREENMON24 >
    WrecklessAbandon likes this.
  6. Dec 9, 2024 at 6:59 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    So, it's pretty damn fun!
    However, in the amount of time I've played with it all over the house (along with my 1.5 year old chasing it everywhere) I can say this -
    There's some noticeable driveline slop. Whenever I'm stopped, if I want to get moving in a smooth fashion, I really have to slowly come on the throttle otherwise I get a sudden jerk-reaction. I'm guessing some play somewhere between the diffs and/or driveshafts.
    The turn signals, I just run them as flashing hazards. Not wanting to open her up to unplug them so I'll do that once upgrades come.
    The ability to climb, even on tiny tires is freaking nuts! It flexes pretty damn good although I'll have to undo the rear spare since it gets caught up on steep climbs.
    The tires. They feel small for a rig like this. But that could also be due to the fact that the rig sits so high so I'll need to upgrade to larger wheels and tires, as well as bringing down the ride height. The tires already rub on full lock so the body will need trimming as well.
    For $99 though, holy shit it feels like a steal.
  7. Dec 9, 2024 at 7:16 PM
    odomandr
    odomandr Well-Known Member
    Andy
    Fort Collins, CO
    2010 DCSBTRDOR silver streak mica 2023 T4R Ltd blizzard pearl
    Icon, SPC,, ARB, BAMF, Warfab, SCS, Michelin, Leer Stock
    I'd bet that driveline slop is related to motor and esc.
  8. Dec 9, 2024 at 7:55 PM
    but why tho
    1991 Pickup
    Mirror is on!
  9. Dec 9, 2024 at 8:42 PM
    Deathbysnusnu
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    I love this little guy. It truly crawls like an ant. I get about 20-30 minutes run time out of a 2s 200mah battery. I did order a pair of smaller single cells for it that will tuck in tighter, but now I'm not sure I want to bother changing them out. I cut off the wire clips on the transmission and that let these batteries sit better. Wire and shit is just gonna show no matter what at this scale. I've shortened everything but the servo cable.
    If you check out the Furitek brushless rtr, it's packed tight too.
    Ordered 5mm longer dual spring shocks for it. See if I can increase the 23mm of wheel travel. :D
  10. Dec 9, 2024 at 10:08 PM
    but why tho
    1991 Pickup
    That looks so awesome! You're not helping my itch to get the short course/desert truck.
    Deathbysnusnu[QUOTED] likes this.
  11. Dec 10, 2024 at 4:37 AM
    Dr. Doom Says
    Dr. Doom Says Well-Known Member
    SE TN
    2019 TRD OR
    I think it is drivetrain slop on the FCX's. It's like tolerance stacking in the portals/diffs/transmission, you can rock the truck back and forth with the power off considerably. You get used to it, but it does take some of the control out of going over obstacles.
    a2lowvw, Bikinaz and Deathbysnusnu like this.
  12. Dec 10, 2024 at 5:50 AM
    Bikinaz
    Bikinaz It wasn't me!
    Hey You!
    Phoenix, AZ
    2014 Regular Cab 4x4 5MT
    Pelfreybuilt Skids. ModCo wheels. Sliders. Cruise Control. Intermittent Wipers. Fog Lights.
    I concur. All my experiences with portal rigs have been the same. Lots of play in the drive train but I really don't notice it on the run.
    Dr. Doom Says[QUOTED] likes this.
  13. Dec 10, 2024 at 5:55 AM
    Dr. Doom Says
    SE TN
    2019 TRD OR
    I should start crawling with mine again.
    One of my favorite things was ripping donuts with the LGRP Grippers would make a distinct howl like real tires.
    SliMbo4.0, Hafaday and Deathbysnusnu like this.
  14. Dec 10, 2024 at 6:45 AM
    Bikinaz
    Hey You!
    Phoenix, AZ
    I wonder how these would do with a smaller tire and lowered bit. They look like they're a little top heavy?
  15. Dec 10, 2024 at 7:17 AM
    Dr. Doom Says
    SE TN
    2019 TRD OR
    I think a lot of the height comes from the portals. FMS had a "crappier" version a few years ago with straight axles and a lower ride height.
    I think they have also come out with a straight axle FCX that may have compatible axles or outer axle pieces. Might be a pretty easy swap and just need to reverse motor direction.
    Bikinaz[QUOTED] likes this.
  16. Dec 10, 2024 at 7:17 AM
    Deathbysnusnu
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    I see FMS has started using counter rotating shafts. I wonder if it makes a difference?
    That Camel Trophy Land Rover is looking pretty good. Looks to have plenty of fender room for bigger tires.
    Those things were $150 a couple years ago with brass bushings in place of bearings, all plastic gears
    Now $99, bearings throughout, metal gears, with an upgraded design.
    Bikinaz likes this.
  17. Dec 10, 2024 at 7:20 AM
    odomandr
    Andy
    Fort Collins, CO
    None of my vanquish nor Axial portals have much slop id actually say I felt the 10.2 and capra portals were way tight almost too much without break in. The origin started to have great tolerances and the pinion gear shimming helped them all a bit. I haven't had any fcx yet but that is a bummer to hear
    NABeast likes this.
  18. Dec 10, 2024 at 7:50 AM
    Bikinaz
    Hey You!
    Phoenix, AZ
    Ah, there's the key difference! I'm running on a budget rig.
    I wish I had a Vanquish VRD, but that's not going to pass the appropriate approval from the CFO/Wife. I do have $250 of fun money saved for that dream rig already though! Hopefully nothing expensive breaks on my daily crawler before I get to $600.
  19. Dec 10, 2024 at 8:57 AM
    a2lowvw
    a2lowvw Well-Known Member
    Justin
    Bothell, Wa
    2019 DCSB Limited
    Stuff and things
    The fcx portals definitely leave some things to be desired. I have one of the first generation Furitek caymans and have debated for a while if I should either axle swap it or just pull all the electronics and move on to another chassis.
  20. Dec 10, 2024 at 11:54 AM
    Roody
    Ross
    SW CT
    GX460
    Kiddo + RC is the best
    Just wait until you start upgrading that thing (the RC, not the kid)... they can climb stuff you'd never expect them to be able to
