Anyone into R/C?
Discussion in 'Sports, Hobbies & Interests' started by A.D., Feb 7, 2009.
  1. Jan 7, 2025 at 9:16 PM
    Strictlytoyz
    Strictlytoyz Well-Known Member
    Charles
    HA\/\/AII
    07 Shitbox
    I honestly could throw these into the comp build. I'm more than pleased with how it's been working on the Ascent. I'll see how fitment goes and go from there. Was leaning toward a lizard and komodo variant :notsure:
  2. Jan 7, 2025 at 9:19 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Oooh if you go Mini, you might be able to stick with the stock angled skid it comes with.
    I can't recall where I saw it, but the Mini solved the issue of the upper links hitting the motor when they were fully tucked.
    It's the main reason why I went with the Mini - I wanted minimal clearance issues.
    Strictlytoyz[QUOTED] likes this.
  3. Jan 7, 2025 at 9:24 PM
    Deathbysnusnu
    Deathbysnusnu Work is just a daily detour to happy hour.
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    :cool:
    And ended up with a longer wheelbase than when it started. I really didn't have a plan, just went with what I had on hand for materials. I think I'm gonna maybe shorten it.
    I added 7mm to the front, and shortened the rear by 5mm, so it's only 2mm.
  4. Jan 7, 2025 at 9:29 PM
    Strictlytoyz
    Charles
    HA\/\/AII
    07 Shitbox
    Mini was the plan. That's probably what I'll do and whichever motor I'm more comfortable with will stay in the motor. So long as there's no contact issues with the cedar
    Kwikvette[QUOTED] likes this.
  5. Jan 7, 2025 at 11:01 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    @Strictlytoyz
    Had a long chat via FB with Tyler (owns 828RC) as he is another member often recommended for custom links. I'll be ordering stainless steel links from him for the build.
    He sent me a pic of one of his own rigs here -
    But also, here he says what he does, and why -
    I will also recommend a single bend rear upper, and single bend front upper along with the double bent rear lower. Ill break down the reasoning next.
    Single bend front uppers on the ccv3 allow you to run the micro and mini komodo motors forward. The bend let's the link clear the motor.
    The single bend rear upper will allow the rear upper to clear the rear double bent lower if you are running your suspension fairly low.
    Bikinaz and Strictlytoyz like this.
  6. Jan 7, 2025 at 11:29 PM
    Strictlytoyz
    Charles
    HA\/\/AII
    07 Shitbox
    Interesting, thanks for sharing. Seems the only thing he changes is the rear upper then? I believe both upper and lower rears are double bent with Mazz's links. Are you getting offset rod ends as well with that or straight?
  7. Jan 7, 2025 at 11:31 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Compared to Mazz, yeah pretty much.
    I don't know if the ends are offset as I was basically just asking him to build me what I need for a performance-oriented rig using what I purchased - I sent him my whole build list.
    It was almost 2am for him when I posted so I didn't want to keep asking more questions. I can find out tomorrow.
  8. Jan 7, 2025 at 11:34 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    He did place emphasis on a straight link for the front lower though.
    Something I remember several commenters mentioning in a youtube video or two, probably not realizing the "catch" the skid creates.
    Stainless links being smooth would allow the truck to climb over an obstacle and not get bound up underneath.
    Then again you and I are both new to this so we're probably talking about an issue we can't yet consider :rofl: I'll just take better lines.
  9. Jan 8, 2025 at 7:43 AM
    Deathbysnusnu
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    Spider Pig.
    The flex potential is there. Needs longer shocks. :p This stupid thing is consuming way too much of my time.
    If I shorten the links front and rear by 5mm each, does that kill the flex? Knowing it has this much, and will never achieve it with current hardware, I think it prolly won't matter much.
  10. Jan 8, 2025 at 8:29 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    LOVE my lil Redcat Ascent 18. Ill have to take some pics of how i moved things around for lower cg, better flex etc (all for essentially free).
    The biggest upgrades I have done and really the only that are needed are links and driveshafts from injora. Stock tires are decent, but if you wanted a better softer tire with steel beadlocks these fit the truck great
    https://www.amazon.com/gp/product/B0BNB8WLKD?ie=UTF8&th=1
    Just make sure to drill the inner beadlock ring and inner rim half with a little hole to vent the tires.
    People upgrade the stock electronics and I dont know why, the stock motor, esc, servo, battery are all dang good, plenty of torque and speed and if you wanted more you can run it on 3s lipo.
  11. Jan 8, 2025 at 10:16 AM
    Strictlytoyz
    Charles
    HA\/\/AII
    07 Shitbox
    @Kwikvette
    My Super 8 axles are being delivered today. Also put an order in for Injora 40mm big bore shocks and their gladiator length driveshafts. Been happy with their stuff on the ascent.
    lowmower, Bikinaz and Kwikvette like this.
  12. Jan 8, 2025 at 10:34 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    What part number driveshaft?
    I ask because I forgot what lead me to buy mine, and I don't even recall why I chose the set I did.
    Think I went by their advertised lengths and compared them to Gladiator length driveshafts from another brand.
    Strictlytoyz[QUOTED] and Bikinaz like this.
  13. Jan 8, 2025 at 11:08 AM
    Strictlytoyz
    Charles
    HA\/\/AII
    07 Shitbox
    SKU: SCX24-74
  14. Jan 8, 2025 at 11:12 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Interesting I can't find that info anywhere in the ad or packaging.
    Just this -
    Suitable for 1/24 RC Crawler Axial SCX24 Gladiator AXI00005 RC Car.
  15. Jan 8, 2025 at 1:18 PM
    Strictlytoyz
    Charles
    HA\/\/AII
    07 Shitbox
    Now I'm a little worried because I'm finding 2 different options for holes and idk which one I'll need yet. There's d shape hole and round hole driveshafts
  16. Jan 8, 2025 at 1:19 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    I think the "D" opening is standard.
    Think it's 6mm?
    I haven't opened my transmission but the shaft has a D shaped shaft as well.
  17. Jan 8, 2025 at 1:30 PM
    Strictlytoyz
    Charles
    HA\/\/AII
    07 Shitbox
    Canceled my order for the driveshafts. Gonna wait till I get home to see what's on the super 8 axles
  18. Jan 8, 2025 at 1:40 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    That's smart.
    Since I already have mine, once I mock up the chassis I can tell ya if mine work or not since we're pretty much running the same wheelbase.
  19. Jan 8, 2025 at 1:43 PM
    Strictlytoyz
    Charles
    HA\/\/AII
    07 Shitbox
    Another weird thing is that in photos on lgrp's website it looks like inputs are "D" shape but all the photos of their driveshafts look to be "O" shape. :help:
    I'll just wait and see when I get home from work.
  20. Jan 8, 2025 at 3:50 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    @Strictlytoyz
    Not as fancy as your Flysky! But at least it's plenty quick and has just enough adjustment as I need
