Anyone into R/C?
Discussion in 'Sports, Hobbies & Interests' started by A.D., Feb 7, 2009.
  1. Jan 10, 2025 at 4:33 PM
    Strictlytoyz
    Strictlytoyz Well-Known Member
    Charles
    HA\/\/AII
    07 Shitbox
    That would be the only reason I would go stainless. Less sliding resistance. Been wanting to get one of those mini 4 corner scale systems so I can really get into weight distribution and what not on this thing. When I get home from work I'll shoot you over the weights though
    Kwikvette[QUOTED] likes this.
  2. Jan 10, 2025 at 4:38 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Nice thanks!
    Yeah I've seen capecrawler or whatever his name is use it often.
    I really dig the indoor course he's got setup too.
  3. Jan 10, 2025 at 4:56 PM
    Strictlytoyz
    Charles
    HA\/\/AII
    07 Shitbox
    Ah, yeah I've seen his channel. Was really going through his stuff when I was deciding on a first rc. Pretty sure he also has a review of the cheat code chassis
    lowmower likes this.
  4. Jan 10, 2025 at 4:57 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    He does, although I don't think his video pushed me to buy it.
    He did say good things about the Prosteer axles though and he actually installed them on a GX470 of all things. That's why I got mine.
    Strictlytoyz[QUOTED] likes this.
  5. Jan 10, 2025 at 5:27 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    I couldn't help myself :laughing:
    Now just have to do the front...but it'll get tricky with the plastic parts and servo.
  6. Jan 10, 2025 at 6:17 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    New set is really beefed up compared to stock
    Front done, although I'm sure I have the screw done oddly for the steering horn which I'll address when I replace the servo
    lowmower, Roody, Bikinaz and 3 others like this.
  7. Jan 10, 2025 at 6:31 PM
    Deathbysnusnu
    Deathbysnusnu Work is just a daily detour to happy hour.
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    Squishy. These may require the silicone, which is equally squishy.
    Bikinaz and Kwikvette like this.
  8. Jan 10, 2025 at 6:38 PM
    Strictlytoyz
    Charles
    HA\/\/AII
    07 Shitbox
    @Kwikvette
    Front links: 8.5g
    Rear links: 14.5g
    Total: 23g
    Kwikvette likes this.
  9. Jan 10, 2025 at 6:47 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    I'll try and remember to quote this when mine come in
  10. Jan 10, 2025 at 7:10 PM
    Strictlytoyz
    Charles
    HA\/\/AII
    07 Shitbox
    155mm wheel base
  11. Jan 10, 2025 at 7:11 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Yeah you went Gladiator links right?
    I remember I was specifically going to buy links for the Gladiator wheelbase only to be recommended otherwise :rofl:
  12. Jan 10, 2025 at 7:47 PM
    Strictlytoyz
    Charles
    HA\/\/AII
    07 Shitbox
    Yeah gladiator wheel base, ended up going with the boss body which is gladiator wheelbase. May change but that's where I'm at
  13. Jan 10, 2025 at 7:58 PM
    odomandr
    odomandr Well-Known Member
    Andy
    Fort Collins, CO
    2010 DCSBTRDOR silver streak mica 2023 T4R Ltd blizzard pearl
    Icon, SPC,, ARB, BAMF, Warfab, SCS, Michelin, Leer Stock
    A longer wheelbase will have improved climbing. A shorter wheelbase has better turning and less sidehill washout. Keeping the skid upfront helps with break over when apexing a climb but has sacrificed some weight bias that helps elsewhere. It is all give and take.
    @Deathbysnusnu I was seriously impressed with the Injora silicone inserts that I got with their tires. I don't love that even vented they could cover the vent. I may pull them back apart and try to put together baby powder or corn starch in them to keep from sticking to the tire though.
    Deathbysnusnu and Strictlytoyz like this.
  14. Jan 10, 2025 at 8:08 PM
    Deathbysnusnu
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    These are the softest tire ever. I too was disappoint that any vent holes would be covered, but it doesn't seem to make a difference. I mounted one with no insert and it's too floppy to stand under it's own weight.
    Monkeying around with the second, I used a thin film of grease to get the tire to rotate on the rim. They are sticky. It looks better filled out with the silicone. The squish is about perfect.
    Baby powder is a good idea, I'll try that on the next one.
  15. Jan 10, 2025 at 8:10 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    So.....for people like @Strictlytoyz and I wanting to make these comp builds, foam or silicone for 1/24 scale?
    odomandr[QUOTED] likes this.
  16. Jan 10, 2025 at 8:15 PM
    Deathbysnusnu
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    My first go with silicone, haven't even ran them yet. But so far very much impressed with the look and feel. Tires are so sticky I can already hear the plastic ring and pinion singing the song of a ratchet.
    Different tire compounds are going to be the deciding factor on the silicone compound or foam density if they are used. I know that once foams get wet they are pretty much done. You guys are in for a boatload of experimentation and a rack full of tires. :p
  17. Jan 10, 2025 at 8:23 PM
    Strictlytoyz
    Charles
    HA\/\/AII
    07 Shitbox
    @Kwikvette I've been super pleased with injoras yellow silicone inserts. I have a few extra sets in different sizes I'm going to be trying out. There's huge rave about the flubrc inserts as well.
    Kwikvette and odomandr like this.
  18. Jan 10, 2025 at 8:24 PM
    Strictlytoyz
    Charles
    HA\/\/AII
    07 Shitbox
    Ascent 18 going on the shelf for a bit while the comp build begins
    lowmower, Rodarbal, Bikinaz and 3 others like this.
  19. Jan 10, 2025 at 8:42 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Seems like you're not gonna need those wheels then.
    I'll send you a pre-paid label shortly :burp:
  20. Jan 10, 2025 at 8:44 PM
    odomandr
    Andy
    Fort Collins, CO
    I have always run crawler innovations dual stage foams for my comp and trail crawlers. In heavier/faster rigs I use their single stage foams. I have their 24th scale foams cut in half in my deadbolt. The silicone yellow Injora came with the Injora tires. I don't have enough experience with the 24th scale stuff yet to say. I've been running stock foams for the longest time with most of the tires I have tried in this scale.
    I should probably reach out to CI as the calculator does not have 1.0 information. They have always been easy to communicate with. One reason I have a corner weight scale is to tell them what a rig weighs so they can recommend foams.
    I'll put both of mine on them tomorrow and see. I typically fine tune drift cars with it as crawlers end up with stuff where it fits most the time.
