Anyone know about S-10's?
Discussion in 'General Automotive' started by theGastone, Apr 22, 2012.
  1. Apr 22, 2012 at 11:25 PM
    theGastone
    theGastone [OP] New vehicle/Tacoma *****
    Ian
    Leesburg, VA
    '97 Standard
    My buddy has been without his truck for months now (it's a 2002 Chevy S10 Xtreme with a 4.3L Vortec v6), he finally gets it fixed, gets tags and stuff renewed as well as his license and 3 days later (being today) it's dead in the water. When he puts the key in the ignition and tries to turn it over, there's a POP. We checked all the fuses related to the ignition and they're all fine. But the vehicle is getting literally no electricity, because I plugged in my ODB-II and it wouldn't come on. I originally suspected the battery, we'd even hooked it up to my Taco with jumpers, to no avail.
    Do any of yall have any experience with these trucks? Or have any idea as to what the problem could be? Also do you think that there's a place where we could just borrow a battery to see if that actually is the problem?
  2. Apr 23, 2012 at 1:52 AM
    Highland Logan
    Highland Logan UBIQUE
    Frank
    Nova Scotia, Canada
    2011 Black AC TRD Off Road w/ factory tow pkg
    Icon Stage 2 w/ overload left in, SPC LR UCA, 265/75 16 BFG KO2, front and rear Weathertech floor liners, OEM (Extang) solid fold tonneau, OEM bed mat, OEM front skid plate, OEM billet oil cap, "TOYOYA" tailgate decal
    Try here this link.
    Frank
  3. Apr 23, 2012 at 1:54 AM
    BulletToothTony
    BulletToothTony Im only a dick 90% of the time
    You can call me Susan if it makes you happy.
  4. Apr 23, 2012 at 2:31 AM
    F75gunslinger
    F75gunslinger Ka like a wheel
    Christian
    Rochester,NY
    SWB '10 Doublecab TRD Sport 4x4
    Cluster and Radio LED swap,Westin bull bar,2nd set of bed tie downs,URD SS,K&N filter,weathertechs
  5. Apr 23, 2012 at 5:26 AM
    Pugga
    Massachusetts
    '13 Ford F-150 SCREW
    F-150 Mod
    If you tried jumping it and still got nothing from the S-10, it's probably not the battery. I'm guessing you got that loud pop once which would indicate an electrical short somewhere. If all the fuses are good (replace them, don't just inspect them visually) and you're getting absolutely nothing, you'll need to start trouble shooting the vehicles electrical system. Hopefully you didn't fry the ECU (if that's even possible with the S-10).
  6. Apr 23, 2012 at 6:21 AM
    theGastone
    Ian
    Leesburg, VA
    '97 Standard
    You really think I didn't try that first? Obviously I'd come to a Tacoma forum as a last resort for a Chevy. You don't have to be a smart ass.
  7. Apr 23, 2012 at 6:28 AM
    JDMcQ
    JDMcQ Well-Known Member
    The Mushroom Capital of the World
    2006 Toyota 4Runner SR5 V8
    Did you check the main fuses? Not the ones under the dash, but the big ones under the hood. Like was said above, check ALL of the fuses to make sure something didn't blow.
  8. Apr 23, 2012 at 8:12 AM
    theGastone
    Ian
    Leesburg, VA
    '97 Standard
    I'll check the ones under the dash because we only checked the ones under the hood. At least I only checked those. Not sure if he did.
  9. Apr 23, 2012 at 8:14 AM
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    I think you should just call it a total loss and let me have the leaf springs to give to Doug :-D
  10. Apr 23, 2012 at 8:15 AM
    Pugga
    Massachusetts
    F-150 Mod
    Find a NEW fuse of each amperage, pull the first fuse, replace with new, try it, then take that old fuse and replace the next one of the same amperage and so on. That's kind of a cheap way to check your fuse situation and how I do it if I don't know what's blown out (assuming it's a fuse).
