Anyone know anything about PWC's? HELP!
Discussion in 'Boating & Fishing' started by c.coulby, Sep 4, 2014.
  1. Sep 4, 2014 at 10:14 AM
    c.coulby
    c.coulby [OP] Well-Known Member
    Cameron
    Summerville, Georgia
    2009 TRD Sport
    I have a 08 Seadoo RXP 255. I have had it about 2 months now and last weekend I took it out on the lake. When I first put it in the water was running great, then all of a sudden the amount of propulsion was drastically reduced. It also, had this very violent vibration when you would give it throttle. I'm wondering if it is maybe the wear ring. First time I had it out on the lake I sucked up 3 microfiber towels.. But once extracted it seemed to be back to normal.
    Just want a second opinion before I start spending money.
  2. Sep 4, 2014 at 10:25 AM
    SnowroxKT
    SnowroxKT Well-Known Member
    Kyle
    Anchorage Alaska
    2008 TRD OR
    No clue, sorry! Bump!
  3. Sep 4, 2014 at 10:26 AM
    c.coulby
    Cameron
    2009 TRD Sport
    Haha thanks for the free bump!
  4. Sep 4, 2014 at 10:27 AM
    jake72
    jake72 Well-Known Member
    Jake
    N.E. PA
    2019 trd off-road dcsb mt
    bent propeller or shaft
  5. Sep 4, 2014 at 10:38 AM
    IPNPULZ
    IPNPULZ Well-Known Member
    Deeper in the South…….
    2023 TRD Off Road Premium 4R
    going to be fun!
    I know they have some speed sensors and rev limiters that will cause these types of problems.
    Could also be the wear ring and or bent/broken impeller vain.
    Is this supercharged? If so look at the bypass sensors to make sure they are functioning right.
  6. Sep 4, 2014 at 10:38 AM
    NCtaco914
    NCtaco914 MALLIN'CRAWLIN'
    NEIL
    NORTH CAROLINA
    17' DCSB TRD O/R
    Very unlikely..but, possible.
    Shine a flash light into the pump and take a look at the distance between the impeller and the wear ring. Shouldn't be any gap..If it looks okay, pull the pump and make sure the wear ring isnt spinning also. When you re-install the pump make sure the seal (black rubber seal) is also good between the hull and the pump..
    Here's a good link for wear ring inspection
    http://www.kingslandreachmarina.com/wear_ring.html
  7. Sep 4, 2014 at 10:39 AM
    NCtaco914
    NEIL
    NORTH CAROLINA
    17' DCSB TRD O/R
    RXP is superchared
  8. Sep 4, 2014 at 11:13 AM
    c.coulby
    Cameron
    2009 TRD Sport
    Okay I'm really hoping it is nothing more than the wear ring. I am going to try and look at it this weekend. I'll upload pictures if I'm not sure.
    Now that you say the wear ring might be spinning, that seems very possible. The way it vibrates it seems thats what it could be doing.
    Idk. First ski I have owned. I have loved it up until this point. Haha
  9. Sep 4, 2014 at 11:23 AM
    c.coulby
    Cameron
    2009 TRD Sport
    That is spot on with what it is doing. Revving a lot faster than it should considering the acceleration. Then the vibration. I think I am going to pull it out tonight and give it a look.
    Thanks for everyone's help. I love this place.
  10. Sep 4, 2014 at 11:37 AM
    NCtaco914
    NEIL
    NORTH CAROLINA
    17' DCSB TRD O/R
    If your unsure just post some pics of the pump. If you do need a wear ring I recommend putting the set screws in to keep it from spinning. That ski should have them though
  11. Sep 4, 2014 at 11:43 AM
    Large
    Large Red
    My Yamaha did this. Ended up losing an oil line and ran the motor on gas only (2 stroke), the craft new there was an issue so limited the rpms, didn't really help out the situation though. Had to get the motor rebuilt, lost PSI in cylinder 3, ran it back to shore (about 1/4 mile) then wouldn't start again.
  12. Sep 4, 2014 at 12:06 PM
    c.coulby
    Cameron
    2009 TRD Sport
    Well thankfully I'm fairly confident this isn't an issue with mine. Mine is a 4 stroke. Never been a big fan of 2 strokes for that reason.
    Thank you for your input.
  13. Sep 4, 2014 at 12:55 PM
    NCtaco914
    NEIL
    NORTH CAROLINA
    17' DCSB TRD O/R
    Block off plate and pre mix! :D
