Anyone know factory rake for 1st gen?
Discussion in '1st Gen. Tacomas (1995-2004)' started by mmiller001, Mar 18, 2016.
  1. Mar 18, 2016 at 5:51 PM
    mmiller001
    mmiller001 [OP] Member
    1999 Taco + Northstar Truck Camper
    None yet!
    looking for the factory rake for a first gen - meaning what is the difference between the height of the front wheel well center arch and the rear?
    Details - 1999 Tacoma 4x4 v6 extended cab (2 door). Stockish tires about 31".
  2. Mar 18, 2016 at 6:02 PM
    Tinmann
    Tinmann Well-Known Member
    NorCal
    My best guess would be a 1"-2" difference.
  3. Mar 18, 2016 at 7:38 PM
    alphabravo
    alphabravo Well-Known Member
    Christopher
    Canada via FL
    2003 Tacoma TRD
    Supercharger AntiDark Hood Light Redline Tuning Hood Struts Morimoto Projectors Grey Wire Mod Tundra 13WL Brake Conversion EBC ED Pads and GD Rotors Mean Green Starter DC Power 250A Alternator Odyssey PC2150 Battery, Artec Cage ADS shocks Total Chaos UCA ComeUp Winch, Factor 55 Splicer Relentless bumpers OTRATTW Switches, Bussman 15304-2-2-4 RTMR, Paranoid Fabrication switch brackets Jensen JHD3630BT Morimoto XB LED Fogs Deaver Custom Springs Ivan Stewart TRD Wheels, Pro Series TRD Wheels
    I don't understand what you are measuring to. What is wheel center arch?
  4. Mar 18, 2016 at 9:16 PM
    bry838
    bry838 Well-Known Member
    oregon
    '00 tacoma 2.7 4x4 reg cab 5speed x's 2. '01 T4R 3.4 5 speed
    I think it was 1.5" off the lot.
  5. Mar 22, 2016 at 2:02 PM
    mmiller001
    None yet!
    @Tinmann and @bry838 I suspect your guesses are close.
    @alphabravo I have been measuring from the ground to the wheel well (A). Although I see elsewhere in forums they measure from wheel center to wheel well (B).
    Basically I want to know the measurements of (B) and (D) so I can calculate the difference between them and compare with my current setup. You could call it factory lift, factory rake, etc.
    Hotrodroxie likes this.
  6. Mar 22, 2016 at 2:06 PM
    alphabravo
    Christopher
    Canada via FL
    2003 Tacoma TRD
    Yeah I've been measuring A and C but I can see why B/D is better since it isn't affected by the flat spot in the tire due to air pressure.
  7. Mar 22, 2016 at 2:08 PM
    mmiller001
    None yet!
    @alphabravo exactly, and different tire sizes would effect A/C too.
  8. Mar 22, 2016 at 2:16 PM
    alphabravo
    Christopher
    Canada via FL
    2003 Tacoma TRD
    The only stock measurements I have is A/C at about 36" but that is with fender flares which might affect it slightly and the rear springs were pretty flat at that point.
  9. Dec 11, 2021 at 7:52 AM
    Hotrodroxie
    Hotrodroxie Active Member
    NEO
    08 Tacoma dbl 4x4, poor girl stock
    You have to measure it LOADED (by a jack) and at rest on ground.
    Everyone thinks about this incorrectly IF your actually planning to do ANYthing off-road, or even just drive in dips regularly ‍♀️
    If your pavement princess gets a [strictly cosmetic] lift in order to technically ‘fit’ bigger tires and look cool, than that’s fine- but don’t plan to have the functionality on anything other than a flat surface You still won’t have the travel height needed.
    There’s a good video explaining this...Lmc if I can find it...
    https://youtu.be/33VewJFda1Q
    SpokeWench likes this.
