Anyone Know How to Calculate Driveshaft RPMs?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by jboudreaux1965, Apr 22, 2024.
  1. Apr 22, 2024 at 5:37 AM
    jboudreaux1965
    jboudreaux1965 [OP] Ragin Cajun Fan
    Joseph
    Hub City
    2023 TRD Sport
    Anyone have the info on how to calculate the RPMs of the driveshaft on the 6 sp auto when you change the gear ratio in the rear axle?
  2. Apr 22, 2024 at 5:38 AM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission 5.29 R&P FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Bed Light Kit VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Customized 2WD Low Operable (Switched) Clutch Safety Bypass
    Use a calculator like GrimmJeeper and see what it shows engine rpm as in 4th. Or just drive in 4th if you want to see your current setup.
  3. Apr 22, 2024 at 5:46 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Typically the gear right before overdrive (D) is 1 to 1 ratio.
    So 4th gear on our trucks should be 1 to 1 ratio between engine and driveshaft..
  4. Apr 22, 2024 at 5:49 AM
    babylon5
    babylon5 Well-Known Member
    David
    2015 Tacoma Double Cab TRD Sport
    If you want the actual rpm you need
    engine rpm, gear ratio of transmission gear you are in
    Just divide engine rpm / transmission gear ratio.
    If say you are doing 1000 rpm and the gear you are in is 2.94 then driveshaft rpm is 340
    Now the RPM of the driveshaft doesn't change if you change rear axle ratio since the RPM is solely based on the ratios in the transmission.
    What does change is the speed you are going at that RPM (speed at which axles are turning changes , not driveshaft)
  5. Apr 22, 2024 at 6:04 AM
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    Actually, that’s backwards. You would divide that.
  6. Apr 22, 2024 at 6:06 AM
    babylon5
    David
    Yep, i did have that backwards.. I have corrected.. Has to be the way you mentioned for torque multiplication in lower gears...
  7. Apr 22, 2024 at 6:09 AM
    50Buck
    50Buck Living rent free Timmy the Tool's head
    3rd gens have 6 gears.
  8. Apr 22, 2024 at 6:13 AM
    babylon5
    David
    These are your gear ratios in the auto so as mentioned just divide engine rpm by the gear you are in.. And 4th is indeed 1:1
    First Gear Ratio 3.60
    Second Gear Ratio 2.09
    Third Gear Ratio 1.49
    Fourth Gear Ratio 1.00
    Fifth Gear Ratio 0.69
    Sixth Gear Ratio 0.58
  9. Apr 22, 2024 at 6:18 AM
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    Assuming the converter is locked up. Dunno how that's programmed in 3rd gens
  10. Apr 22, 2024 at 6:20 AM
    mosccat
    mosccat Well-Known Member
    Mark
    Currently in Bend, OR
    2020 OR
    Software like OBD fusion will give you real time lock up status.
  11. Apr 22, 2024 at 6:24 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Oh yea I forget Joseph bought a 3rd gen. He had a 2nd gen prerunner for a long time
    Looks like 3rd gens have 2 overdrive gears. So 4th is still 1 to 1
    BabyBilly and 50Buck[QUOTED] like this.
  12. Apr 22, 2024 at 6:28 AM
    BLtheP
    Plano, TX
    Pretty sure 4th can both partial lock and full lock, if you limit it to 4th and just cruise it should full lock. When I had the loaner I was able to accurately determine rpm.
    BabyBilly likes this.
  13. Apr 22, 2024 at 6:30 AM
    babylon5
    David
    Trade it in for a manual. Calculation will be easier... :rofl:
    Now if its the change in speed (actual vs indicated) going to a higher numerical (like 5.# vs 4.#) ratio rear axle will reduce your road speed by dividing new ratio/old but speedo will read higher than actual which is good in avoiding speeding tickets. But if you change tire diameters this also make a difference. A larger diameter tire will do the reverse since for every revolution you will travel a larger distance.
    I have some slightly large snow tires I gave to a friend. With original tires his GPS indicated speed was 97 kph when speedo indicated 100. With my snows installed it now indicates 103 when speedo shows 100
  14. Apr 22, 2024 at 6:37 AM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    All you need is the diameter of the tires, the speed, and the rear end ratio. Transmission doesn’t factor in at all.
  15. Apr 22, 2024 at 6:41 AM
    babylon5
    David
    He wants driveshaft RPM. This is solely a function of engine RPM and transmission ratios.If he is in 4th 1:1 the RPM of driveshaft will be exactly equal to engine RPM.
    Nothing will change that unless you change the transmission
    He didnt ask for speed or change in axle rpm which are a function of rear axle ratio change
  16. Apr 22, 2024 at 6:48 AM
    0xDEADBEEF
    he’s asking how it changes when you change the axle ratio - which has nothing to do with the engine or transmission.
    Or put another way, 1000 rpm at the engine with a. 1:1 ratio in the transmission will always be 1000 driveshaft rpm, no matter what axle ratio.
    The driveshaft rpm will change the same percentage as you change the axle ratio.
  17. Apr 22, 2024 at 6:50 AM
    BLtheP
    Plano, TX
    All of this discussion is exactly why I started by suggesting going to GrimmJeeper and entering the details and looking at 4th. If he wants to do a calculation to figure it out by entering different details, it is brain dead simple. Somewhere like GJ makes it easy to figure out when there are changes in tires in addition to ratio changes. Doing proportional math only works if one variable is being changed, unless you want to multiple for the gear ratio and then divide back for the added tire diameter. But that gets confusing.
    The only hard part about any of that is putting in the correct tire diameter. For a 35, that is not 35". More like 33.5" on most of them.
  18. Apr 22, 2024 at 6:51 AM
    ridefreak
    ridefreak Well-Known Member
    NM
    2006 DCSB TRD
    minor tweaks
    Speed, tire size and axle ratio, anything else has the unknown of the torque converter (in an auto) DS RPM will be directly related to tire size and speed and axle ratio.
    https://www.drive-lines.com/php10/dlrpm.php
  19. Apr 22, 2024 at 6:51 AM
    SR-71A
    Zack
    Southern Maine
    Its all the same... o_O
    True tire diameter (not advertised diameter) and speed working up through the ratios, or engine speed working down through the ratios. Same answer either way
  20. Apr 22, 2024 at 6:52 AM
    babylon5
    David
    You
    You are contradicting yourself
    Yes : Or put another way, 1000 rpm at the engine with a. 1:1 ratio in the transmission will always be 1000 driveshaft rpm, no matter what axle ratio.
    No :The driveshaft rpm will change the same percentage as you change the axle ratio
    The rear axle speed of rotation will change not the driveshaft at the same engine RPM and trans ratio
