Anyone know how to change halos?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bigstik, Mar 4, 2011.
  1. Mar 4, 2011 at 9:07 PM
    bigstik
    bigstik [OP] Well-Known Member
    Tanner
    Terry, MT
    08 PreRunner Debadged, Silver
    Smoked fog and tail lights, blue map and dome lights, gauge color change, stereo color change, aftermarket headlights (halos) (HID upgrade), satoshi grille mod, WickedFlow Max 13sc250 muffler, ultragauge. 3" rear 2.5" frnt lift/level kit.
    So I noticed that one of my halos is getting ready to fail. Is it possible to change just the halo ring itself, and if so how do I do it?..
  2. Mar 4, 2011 at 9:17 PM
    snowgod06
    snowgod06 UG legend wannabe
    Rob
    A farm field, OREGON
    06 Access Cab
    crap bolted and welded together....
    the ring IIRC is just 1-3 leds that send the light around it. I'd have to dig my old ones out, but i think in order to change those you have to take the headlight apart. Give me like 5 minutes and ill look at my old ones.
    EDIT:
    Just checked, if you pull your headlight out their should be a rubber plug on the bottom of the housing below each light. Pull that plug and you can see the LED and pull it right out.
  3. Mar 4, 2011 at 10:07 PM
    bigstik
    Tanner
    Terry, MT
    Alright, I'll check that out... Thanks man
