Anyone know how to correctly assemble component LEDs?
Discussion in 'Lighting' started by iTz IAN, Apr 4, 2013.
  1. Apr 4, 2013 at 7:40 PM
    iTz IAN
    iTz IAN [OP] Well-Known Member
    Ian
    Santa Barbara,CA
    4x4 TRD FTW
    It seems as tho one could save a ton of money by making their own LED lights,
    I'm looking for a How to writeup, on how to do this (heatsinks,resisters, entire process....etc.)
    check out the top 2 LEDs in this link, the first puts out 2700lumens and the 2nd one puts out 750, is there a cost effective way to assemble and use these.
    http://www.superbrightleds.com/cat/high-powered/
  2. Apr 5, 2013 at 1:07 PM
    iTz IAN
    Ian
    Santa Barbara,CA
    4x4 TRD FTW
  3. Apr 5, 2013 at 1:13 PM
    mutilatedjak
    mutilatedjak n00b waffle
    WA
    11 DC SB TRD Sport 6spd
    BP-51s, Dakar leafs, ARB bumper, 4xinnovations rear HC, 3x trail camera, pure android, lightforce 170s, Dick Cepek 255 85s extreme terrain.
    What's your objective? Custom led light bars like Rigid or something? I've built custom component led projects before for fun. The problem with building your own light bar style light is that creating the proper reflector contour is a pain in the ass. Sure those leds throw a ton of light, but it just goes everywhere. You need a good reflector and lens to get that light to project to any use able distance.
    There was a thread somewhere where someone built their own light bar, aluminum extrusion for the body and so forth... I'll have to see if I can find it
  4. Apr 5, 2013 at 1:15 PM
    mutilatedjak
    WA
    You might also need a power puck thing to properly power the leds from the trucks 12v system
  5. Apr 5, 2013 at 3:47 PM
    PreRunnerSeth
    PreRunnerSeth Well-Known Member
    Apex, NC
    16 Super White Limited 4x4
    There is a LOT to consider to do this. One is optics. They can be had. Little reflectors that clip onto the LEDs. Then the Power supplies. These are high power LEDs and cannot simply be run with a resistor to control current. they need a switching DC-DC power supply. This is a complicated design to say the least. The last and I think the most difficult thing in making your own is heat sinking. These LEDs generate tons of heat and need good heat sinking to draw the heat out of them or they will simply blow out. I have made some smaller round LED lights with these kind of LEDs and the optics but still had issues with heat as i couldn't find a suitable off the shelf heat sink that worked in my application. It can be done and someone on this board has, but its really not practical. Better off just buying a made bar.
    My Credentials on the subject:
    I'm an applications engineer for the company that makes the led driver chip in the Rigid bars.
  6. Apr 5, 2013 at 8:05 PM
    iTz IAN
    Ian
    Santa Barbara,CA
    4x4 TRD FTW
    Any How To DIYs?
  7. Apr 5, 2013 at 8:10 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Been there done that.
    By the time you buy all of the parts you need, you're going to be close to the cost of a commercial unit.
    Now add in days of labor, and you end up with something that looks like a science project that doesn't work as well as the commercial units.
    There's a reason things are mass produced. It's much cheaper than building a one-off.
  8. Apr 5, 2013 at 8:15 PM
    ImplicitlyAlberta
    ImplicitlyAlberta VA6DCO
    David
    edmonton
    06 SR5 Trail Rated, 16 Tundra CM TRD
    TC Uni Uppers, TC race lowers, TC shock tower gusset/ secondary shock hoop, Modified Pelfrey rear shock relocate, ATO shackle flip,radflo hydro bumps front and rear, Radflo 2.0 CO/ 14" rear, Arb rear air locker, ARB front bump/m8000, Road armor rear bump/m8000, FJ TransCase/ Twin sticks....other shit.
    ^^what he said. Ive built some hidious monsters with spare boards and leds and all that fun stuff. Just not worth the effort and time.
    Not knocking your adventure. By all means giver shit and when she turns out better than expected, Ill have the kudos here for ya.:thumbsup:
  9. Apr 5, 2013 at 10:33 PM
    mutilatedjak
    WA
