Anyone know how to remove fenders??
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Gincoma, Jan 9, 2011.
  1. Jan 9, 2011 at 3:27 PM
    Gincoma
    Gincoma [OP] Special Edition Member
    Salt Lake City UT
    RIPieces 2005 Tacoma, adios 2011 :'(
    Factory Monster Truck Package with reverse gear.
    Need help removing them...I did my due diligence and searched but came up with nothing....
  2. Jan 9, 2011 at 4:03 PM
    Mxpatriot
    Mxpatriot Well-Known Member
    '06 4x4 AP LT and Locked
    Just dig into it. Remove the inner plastic fender well, pop the hood, and open the door.
    There are several bolts (and/or plastic rivets, I don't remember) in each of these locations.
    Once you've removed everything you can see, start yanking on it, and figuring out where it is still being held on by.
  3. Jan 9, 2011 at 4:04 PM
    JDMcQ
    JDMcQ Well-Known Member
    The Mushroom Capital of the World
  4. Jan 9, 2011 at 6:58 PM
    Dadic 78
    Dadic 78 Well-Known Member
    Fil
    Edmonton, AB CANADA
    08 Double cab TRD
    Just start checking which bolts are holding it on, and start removing them. You'll need to remove your inner fender liner, and possibly even your flares. The flares are held on with clips that break every time you remove them. They're cheap though...
  5. Jan 9, 2011 at 7:05 PM
    ToyoFreak08
    ToyoFreak08 always changin...never satisfied!!!
    Shawn
    Crestview FL
    08 4x4 Black Access SR5 4.0
    levelin kit, 17" XD wheels, bull bar, headers, chip, volcano intake, borla exhaust, viper security
    guys....all he needs to get off is the fender flares....dont take the whole fender off....once you take the screws out of the flares in the fender well the flares will slide up or down to come off the clips...then pull the clips out of the body and ur done...
    danielsthomas57 likes this.
  6. Jan 9, 2011 at 10:04 PM
    Gincoma
    Salt Lake City UT
    Thanks Toyo....Im doing the best I can to preserve your fenders lol....The first one was a bitch..hear from ya tomorrow
  7. Jan 10, 2011 at 12:36 AM
    drewskie
    drewskie Well-Known Member
    Drew
    Burbank, CA.
    08 Prerunner 4 banger
    Ive done this 3 times. The plastic on the flares that hold on the clips are very easy to break, so be careful. They are part of the flare too, so cannot be replaced. Just remove all the bolts, about 5 per flare i believe, and pull the flare off. I think its best to pull kind of upwards, because straight out will make it much harder. If you can, remove the liner and get behind the actual fender where the clips are, and use pliers to pop them out from the fender. Much less chance of breakage.
  8. Jan 10, 2011 at 12:44 AM
    drewskie
    Drew
    Burbank, CA.
    Read slergios post here, it makes the most sense. also, I noticed that if you remove the plastic boxes in the bed, 8 torx screws, you can access the back of the flare along the bedside. Trust me, you want to remove the plastic clips with the flare. Also, when you install the bushwackers, youll want the bed boxes off. The hardest pice to remove is the front bumper flare piece. If you have specific questions let me know.
    http://www.toyotanation.com/forum/showthread.php?t=191481
  9. Sep 13, 2022 at 7:45 PM
    Slvr14tacoma
    Slvr14tacoma Well-Known Member
    Mid travel
    Anyone remove a fender without removing the bumper? Wanted to mock a fiberglass fender on one side just to see if thats the direction i wanted to go vs. just cutting the oe fenders up.
    Im sure its probably more trouble than its worth but thought id ask
  10. Sep 14, 2022 at 8:51 AM
    drewskie
    Drew
    Burbank, CA.
    I'm not sure how you would since the bumper is covering two bolts. Should only take you 30 minutes to get the bumper off and that's going slow. I think it's a few plastic clips and four bolts.
  11. Sep 14, 2022 at 11:06 AM
    Slvr14tacoma
    Mid travel
    Thanks. Stupid question but i have an hour between work and the other work everyday lol every second counts. Thanks
