anyone know if theres a trick to taking off hood protector?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by pattrick70, Nov 24, 2010.
  1. Nov 24, 2010 at 8:41 AM
    pattrick70
    pattrick70 [OP] Member
    patrick
    cape cod
    2011 tacoma tx pro
    have a 2011 with factory hood protector and decided to take it off for obvious reasons. the catch is its a company car so I will have to put it back on when i turn it in so I dont want to ruin it. The screws just turn and dont do anything, does anyone know if there is a trick to this?
  2. Nov 24, 2010 at 8:53 AM
    NicksRig
    NicksRig Well-Known Member
    Kenora, Ontario
    07 Tacoma DC TRD Sport
    Blacked out Skid plate, block heater, bug deflector, blacked out headlights, tinted fronts, OME 3" lift, Toytec AAL, Revenge-Fab Sliders, K&N Air Filter
    Are you talking about the bug gaurd on the the hood? If so just loosen all the screws, then all the little clamps should just pop open. Once off however you will have serval spots with clear tape and 3 clear bubble that you will have to remove off the hood. Just took mine off a few weeks ago.
  3. Nov 24, 2010 at 8:58 AM
    steviestyles
    steviestyles The "Search" tab is your friend!!
    Colorado Springs
    07 DC 4x4 TRD Off Road
    Bone Stock
    If it's a company car why don't you just leave it on? THey must of put it on there for a reason.
  4. Nov 24, 2010 at 9:00 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Sounds like the screws were stripped going in. I wouldn't mess with it seeing that it's a company car.
  5. Nov 24, 2010 at 9:02 AM
    NicksRig
    Kenora, Ontario
    On a side note. When you go to put it back on you will have to get some of those clear spacers again from the stealership and some clear tape to go under the clamps.
  6. Nov 24, 2010 at 9:18 AM
    pattrick70
    patrick
    cape cod
    2011 tacoma tx pro
    The screws just spin that's the problem . They have plastic washers around them so wasn't sure if they snapped somehow
  7. Nov 24, 2010 at 9:23 AM
    Pugga
    Massachusetts
    Got a pic of the attachment? They should be standard metal screws and if they're just spinning, they were stripped when the bug guard was installed. Try to get a flathead under the washer to apply the outward pressure while unscrewing. You might be able to get the threads to catch so you can remove them. You might have to go a little larger on the screws when you reinstall though.
  8. Nov 24, 2010 at 9:34 AM
    senna
    senna Well-Known Member
    San Jose CA.
    09 DBL CAB TRD-OR OME shocks 885 and AAL
    It could be those plastic molly type screws, pry between the screw and washer to get the thread to catch. Then, some times you have to hold the washer as you back out the screw.
  9. Nov 24, 2010 at 10:02 AM
    pattrick70
    patrick
    cape cod
    2011 tacoma tx pro
    Called the dealer and the service tech said they have to be drilled out. Why have a screw head if you can't unscrew it.
  10. Nov 24, 2010 at 10:06 AM
    Pugga
    Massachusetts
    wow, didn't see that coming... that sucks! Is it a rivet?
  11. Nov 24, 2010 at 10:06 AM
    Mark C.
    Mark C. If you want it bad, you usually get it bad!
    Mark
    Connecticut
    2010 MGM SR5 4WD AC
    LED Dome, Reed Switched LEDs in Glove Box and Center Console, Bumper Fogs, Tailgate anti-theft, LEDs over Cig lighter, Back-up camera anytime, Outside Temp add-on, Hidden GPS power, Sockmonkey 3rd Brakelight decal, 4X4 switch illumination, reed switch controlled engine compartment Flood LEDs, Elite Hitch Cover, Plasti-dipped cupholders and door switch control panels, Elite Hitch Cover.
    ^^^^^X2 That's what I did. Not hard at all.
  12. Nov 24, 2010 at 10:13 AM
    pattrick70
    patrick
    cape cod
    2011 tacoma tx pro
    Ill try that first thanks
  13. Nov 24, 2010 at 12:04 PM
    toyotatacomaTRD
    toyotatacomaTRD Senior Member
    I just took mine off last week. it had 4 screws.. 3 of them came right off, I had one that wouldn't come off, I thought it was stripped. I kept working at it, using one hand to keep the bug shield tight against the underneath of the hood. It finally came off. The screw that was the hardest to get off, ended up being 3 times longer than any of the others. May be worth a try for you.
    On a side note, the clips on the end of the bug shield scratched the hood worse than any rock chips it ever could have saved.. Picking up some touch up paint now..
