Anyone know of a 2nd Gen Tacoma in a salvage yard?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by rjlem, Nov 12, 2011.
  1. Nov 12, 2011 at 8:48 AM
    rjlem
    rjlem [OP] Well-Known Member
    Rick
    Franksville, Wisconsin
    2011 Reg Cab 4WD 2.7 A/T Bought used
    Int. Wipers, OEM Cruise, Fiamm Horns, Access Cover, Bed Mat, WeatherTech Floor Mats,
    I cannot find anything around here.
    I am looking for the “S8” connector. It is in the steering column on the passenger side on the column next to the steering wheel.
    I need a replacement one since I messed mine up trying to get what turned out to be the wrong size pin into it for the cruise control I was installing.
    There may be a couple more wires in the plug depending on the year.
    If anyone can help me out, on this, please let me know. I’ll cover the cost of the part, shipping to get it to me and add something into the deal to cover some beer money.
    If you can find one, try to get as much of the wiring going into the harness as you are able.
    Please see the attached photo for location of the plug.
    Regards, Rick.
  2. Nov 12, 2011 at 10:33 AM
    Mr_Torque
    Mr_Torque Buy the Ticket take the Ride.....
    Perkasie,PA
    '07 Tacoma SR5 4WD V-6 6 Spd
    MBRP Exhaust, 17" FJ Steelies w/Firestone AT's, Truxedo Lopro ,Timbren SES, Pioneer FH-X720BT HU & TS-C720PRS Component Speakers, TRD Quickshifter, Bilstein 6112/5160, Light Racing UCA, and Icon Progressive add a leaf.
  3. Nov 12, 2011 at 10:24 PM
    Argenis83
    Argenis83 Well-Known Member
    Enrique
    San Diego
    06 tacoma double cab TRD offroad
    Engage Long Travel, 50t pack with 16" king triple bypass on rear, 4 Soltek lights, race walker evans wheels, 35" bfgoodrich KM2
  4. Nov 13, 2011 at 12:21 PM
    rjlem
    Rick
    I found http://www.alltoyotatrucksuvparts.com and I have sent them an email.
    Most of what I have run into, the salvage yard wants to sell the dash wiring harness intact or sell the whole dash.
    I was hoping someone might know of a “pick your own” where they might not mind a customer pulling a portion of the harness.
    A lot of the yards up here have cleared out a good portion of their stock in advance of winter.
    Any further help or suggestions will be greatly appreciated.
    Regards, Rick.
  5. Nov 13, 2011 at 1:55 PM
    fixer5000
    fixer5000 the logical one
    massachusetts
    2018 4runner limited in nautical blue
    can you pop that pin out and show us a picture of it? pins are replaceable if you know what it looks like...male or female? do you have the extraction tool?
  6. Nov 13, 2011 at 4:13 PM
    rjlem
    Rick
    I was supplied with the wrong sized pin, the tech line said that sometimes the pins go in tight and it may take some effort to get the pin into the connector.
    It ended up bending over and when I tried to straighten it, it broke.
    I ordered a pin extractor tool but the pins on the tool are too big. It looks like I need something in the order of 0.5 mm (0.020”).
    I though if I could easily find a new connector that it would be the low effort way of dealing with this.
    I plan to give the problem a rest for a bit and re-attack in a weekend or so.
    See attached pic for info.
  7. Nov 13, 2011 at 4:30 PM
    Sideways
    Sideways Well-Known Member
    Maryland
    05 TRD dbl cab
    RJ, I'm not sure if this is the right size pin connector you are lookin for but I used a pin connector from radio shack plug kit (PN 2740242) when I broke the original pin connector to my temp controls.
    It is a round end but slid right over the flat terminal and holds fine
  8. Nov 13, 2011 at 4:49 PM
    rjlem
    Rick
    Thanks - I'll check that out. RS may have the correct size extractor too.
  9. Nov 13, 2011 at 7:11 PM
    rjlem
    Rick
    The main problem is that I have a stuck pin and a broken pin in the cruise control wiring slots on a damaged connector.
    I either need to get the broken pins out or replace the connector out so I can get the cruise wiring pins into the correct slots.
    I figured the easiest thing to do would be to get a salvage yard connector and splice it in place.
