Anyone know of any other soft top camper shells besides Bestop?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Koopaduppa, Apr 9, 2019.
  1. Apr 11, 2019 at 8:08 AM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    Within the next 2 weeks I will have my RTT under the Softopper with still full use of the Softopper.
  2. Apr 11, 2019 at 8:48 AM
    Shellshock
    Iowa
    i called them up and they gave me a discount. I got the softopper plus solid front and rear panels.
  3. Apr 11, 2019 at 10:08 AM
    Flaco_G
    Flaco_G Member
    Flaco
    2017 Tacoma off road 4x4
    Anyone have pictures of quicksand 3rd gen. with the Tan softopper? trying to decide between the black or tan color.
  4. Apr 23, 2019 at 6:17 AM
    Stoked
    Stoked Not So Well-Known Member
    Jeff
    Celina, Tx
    2016 DCSB TRD OR
    Can you tell where the water is getting in, and is it something you can seal up with a little work? I was thinking about running a Soft Topper with a Decked system, and putting a sleeping platform on top of that. Just want to make sure I can stay dry.
  5. Apr 23, 2019 at 6:24 AM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    What type of discount did they give you? I'm thinking of replacing my Tan Softopper
    AxisCab likes this.
  6. Apr 23, 2019 at 6:24 AM
    transworldmoto
    transworldmoto Well-Known Member
    Ben
    California Coast
    2016 Access Cab TRD OR 4X4
    I put some silicone sealant between the gaps at the front of the bed, in the seams at the tailgate end of the bed, and used some adhesive gasketing on the tailgate gaps. Worked like a charm. No water intrusion at all.
    Definitely make sure you use the seam sealer ST provides on all the stitched seams when you first get the topper. That helps keep moisture from being drawn in and running down the straps.
    Stoked[QUOTED] likes this.
  7. Apr 23, 2019 at 6:26 AM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    Water will generally come in at the front corners as there is a gap there. I bought foam pipe insulation and put it over the whole front edge of the bed. No water and it makes it sealed so no mosquitos can get it either
  8. Apr 23, 2019 at 6:28 AM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    Correct and the only note I have on that is put the seam sealer on the inside stitching not on the outside. As the previous owner of mine put it on the outside so all you see is white sealer residue on the outside of my Topper.
  9. Apr 23, 2019 at 6:59 AM
    MadDaddy
    MadDaddy Pork Rind Extraordinaire
    53 Miles West of Venus
    Many & varied
    I didn't add the velcro strip on my tailgate so the bottom of the rear panel flaps. If I didn't pull the flap out after closing the tailgate, water could seep down. Think of it as untucking your shirt. Same deal. I found a little bit of water (droplets, no pooling) in the front corners of the bed after big downpours.
  10. Apr 23, 2019 at 7:19 AM
    Stoked
    Jeff
    Celina, Tx
    2016 DCSB TRD OR
    Thanks for the info! Definitely helps in my decision making!
  11. Apr 23, 2019 at 7:20 AM
    Shellshock
    Iowa
    it was like $50-100. I also got the solid front and rear panels since the windows are pretty worthless here in the midwest with the cold.
  12. Apr 23, 2019 at 7:27 AM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    That is nice to know as many members on here tried to get a Group Buy going and they said they didn't do discounts.
    AxisCab likes this.
  13. Apr 23, 2019 at 7:49 AM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    i dont have a picture, but I'm betting that you'd be happier with black. Always choose a contrasting color with the softopper, (with maybe one exception, black on black.) Trucks that are black, white, or a primary color can rock the tan. The grays and browns (SSM, MGM, QS) can pretty much only do black. I see others posting pictures that go against my opinion, yes your truck looks good, but I personally think it would look better in black. :boink::argue:
    So your quicksand really only looks good in black, but at least it looks really good with black.
  14. Apr 23, 2019 at 8:25 AM
    MadDaddy
    Many & varied
    Softopper makes a grey topper as well. Keep in mind if you're carrying anything that needs to stay cool or camping in warm weather, the black will be hotter.
  15. Apr 23, 2019 at 8:29 AM
    #35
    Zenoxious
    Zenoxious Dark Side
    Zeno
    Portland
    Black 2017 DCLB Off Road + Tech
    TRD PRO Grill
    Here is my softopper.
    AxisCab likes this.
  16. Apr 23, 2019 at 9:16 AM
    #36
    transworldmoto
    Ben
    California Coast
    Here's mine .it's actually for a second gen, but I grabbed it off a member here for $100 and purchased the front and rear panels separately for about $200, plus replaced a few straps. Works great and is in better condition now that I've washed and treated the outer shell.
    Edit: the pic shows the first try with the back window softopper sent me, which has now been swapped with the correct window. Bob at ST was awesome to work with and super patient.
    AxisCab likes this.
  17. Apr 23, 2019 at 9:41 AM
    #37
    deuceb
    deuceb Well-Known Member
    Denver | Austin
    2018 Taco BBPDCLBTRDOR | 2004 MB SL55 | 86 VW GTI
    Is the point of a soft top only for camping? Does anyone use them for anything else? I don't feel like you can do anything else with them cause people can slash them and steal whatever is in there. I've had my jeep top slashed (even though i left the doors open and nothing in there) and I would never get a soft top.
  18. Apr 23, 2019 at 11:19 AM
    #38
    MadDaddy
    Many & varied
    I use it for everything but a safety deposit box, so it's good.
    Camping, glamping, groceries, moving stuff, hauling stuff to the dump, family trips, hunting, moving product from work.
    AxisCab and transworldmoto like this.
  19. Apr 23, 2019 at 11:24 AM
    #39
    slowtacotruck
    slowtacotruck Well-Known Member
    17 offroad
    stuff
    I like mine. I have transported my dog in there, camped in the bed and it keeps stuff dry in the bed.
    I use 303 stuff on it to keep it new looking.
    CenCalYota, AxisCab and MadDaddy like this.
  20. Apr 23, 2019 at 11:42 AM
    #40
    lapoltba
    lapoltba Full Bridge Rectifier
    CT - 06076
    '17 Sport, ACLB, V6,MT, 04B14 OV-Tuned
    I'm way late to the party, but another vote 100% for the softopper. If you have the extra $$ and don't need it to fold the cannback (spelling?) is a good option too. I tried a bestop on my 2nd gen first and had it installed for less than 20 minutes. All the seams (even sealed), you could see light through all of the stitch holes. The mounting frame was flimsy and I could never get it to sit nicely.
    I got a softopper for my 2nd gen and ordered one for my 3rd gen before I even took it home from the dealer. I love the fact that in less than a minute I can have it folded up with open access to the bed with no height restrictions. In about a 1.25 min it is completely off the truck.
