anyone know the biggest block you can put in the rear on stock suspension?
Discussion in 'Suspension' started by 263857839273, Apr 15, 2025.
  1. Apr 15, 2025 at 4:14 PM
    263857839273 [OP] Member
    Trying to lift the back of my truck more, anyone know ?
  2. Apr 15, 2025 at 4:18 PM
    fxntime
    fxntime Well-Known Member
    2015 Tacoma off road TRD and 2014 FJC
    None, they already have issues with axle wrap. A proper set of springs with the additional lift is what you need. Not as cheap but not that expensive.
  3. Apr 15, 2025 at 4:22 PM
    Strictlytoyz
    Strictlytoyz Well-Known Member
    Charles
    HA\/\/AII
    07 Shitbox
    I wouldn't go more than 2" on oem shocks. You'll be topping out the shocks
    263857839273[OP] likes this.
  4. Apr 15, 2025 at 4:23 PM
    Bishop84
    Bishop84 Well-Known Member
    2” works but can have issues based on driveline.
    1” is best and has fewest issues.
    if you’re sagging consider new springs, take a look to see if they are broken or inverted
  5. Apr 16, 2025 at 9:57 PM
    Mach
    Mach Well-Known Member
    2022 Lunar Rock DCLB TRD Off-Road
    Toyota seems to think a 1in block is fine as they use them in their lift kit. TRD Pro's come with a 1/2in block. You really want longer shocks to go with it though and need to extend the e-brake mount. Anything more than 1in I would get new springs. The OEM 1in blocks are actually really cheap. So are the TRD Lift Kit shocks which are longer to go with it.
