Anyone know their stock axle ratio???
Discussion in '4 Cylinder' started by Soundwave, Jan 24, 2009.
  1. Jan 24, 2009 at 11:34 PM
    Soundwave
    Soundwave [OP] Well-Known Member
    B.C. Canada
    2013 TRD sport Double Cab 4x4
    OEM Roof rack
    http://www.toyota.com/compare/?modelCode=tacoma#h_overview
    I am confused? The link to the Toyota website lets you compare tacoma specs, and it shows that my 09 4x4 2.7L Accesscab should have the same 4.10 ratio as the Prerunner. But my axle code on the door ID sticker states my axle code is A02A, which according to several off raod sites is the 7.5" 3.58 open rear diff? Same as what the 2wd non-prerunner hould have. I am curious if any one has looked into thier axle codes and know what the ratio is on theyre truck? Id like to compare V6's versus 4 bangers, versus prerunners vs non prerunners ETC...Thanks!
  2. Jan 25, 2009 at 10:57 AM
    Soundwave
    B.C. Canada
    OEM Roof rack
    Thanks Tacoma Jake! Anyone checked into they're 05-+ 2nd gens?
  3. Feb 15, 2009 at 11:53 PM
    BenJammn5
    BenJammn5 RN
    San Jose
    09 TRD-Off Road PreRunner
    TRD cat-back with Spintech prostreet muffler, AFE Pro dry S intake, 16" SCS F-5, 3.5 BS, 305/70 GT Radial MT, King extended travel front/rear, 2" add-a-leaf, Maxtrack Spindles, Sway bar delete, DSM UCA, All Pro IFS skid, Cab mount chop, bed cab locks, Black badges, cali raised amber LED fogs, 6K FX-R Morimoto projectors with 55watt ballast, fog mod, cheap rear dust lamp from autozone, Hellas 500 behind grill, Color match Satoshi Grill, Hood scoop, rear bumper by BTF, color matched Glassworks bed caps, Wet Okole seat covers
    yea what's mine got? 09 TRD 6spd V6... my guess is 3.73:1??? ANybody know?
  4. Feb 16, 2009 at 1:03 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    If you have a Prerunner/4x4 with the V6, you have an 3:73 ratio
    If you have a Prerunner/4x4 with the 2.7, you have an 4:10 ratio
  5. Mar 9, 2009 at 3:04 AM
    roddy1
    roddy1 Active Member
    Hmm I'm curious to know what the 4cyl 4x4s have as well. 3.58 doesn't sound like enough gear
  6. Mar 9, 2009 at 7:04 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Did you read the post above yours???
    The 2.7's have a 4:10 ratio, on the 4x4's and PRerunners's.
    Firebird likes this.
  7. Mar 9, 2009 at 1:57 PM
    roddy1
    ^^^ thanks mr smart guy! And did you read the OP's post? He has 3.58 gears in his 08'
  8. Mar 9, 2009 at 2:37 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Not trying to be smart, just makeing sure you saw the post. He doesnt have 3:58's, he has 4:10's. And he has an 8.4" rear gear. :)
  9. Jun 30, 2009 at 9:03 AM
    Toyota Truck
    Toyota Truck Well-Known Member
    JT
    Texas
    2008 Prerunnner
    Magnaflow Muffler-TSB springs-Nuvi 265wt-aFe pro dry s filter-Husky Liners-Blue dome light-extra d-rings-OME 90000 sport struts-885 coils-N182 shocks-TSB AAL-LR UCAs-procomp black alloy rims- nitto terra grapplers-20% tint
    What's a good gear ratio for running 285/75/16?
    On a 08 prerunner V6
  10. Jun 30, 2009 at 9:05 AM
    DanGer
    DanGer Avatar approved by 98tacomav6
    Northern Virginia & Blacksburg
    07 Base 4Cyl 4x4 Manual
    White Head Light mod, White shorty antennae, Doug Thorley Long Tube headers, AFE Drop in air filter, Secondary Air Filter Removed,
    Use the tire size calculator
  11. Jun 30, 2009 at 9:10 AM
    drew02a
    drew02a Rocking your mom's world Since 1997
    San Antonio, TX
    2006 Regular Cab 2.7L 4x4
    4.10 or 4.30
  12. Jun 30, 2009 at 11:15 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    X2.
  13. Jun 30, 2009 at 11:28 AM
    drew02a
    San Antonio, TX
  14. Jun 30, 2009 at 7:34 PM
    jiles111
    jiles111 Well-Known Member
    Abilene, TX
    09 RegCab 4x4 Super White
    This is for the 09 4cyl models
    HTML:
                                Manual           Auto
    2.7-liter 4x2	          3.307	       3.583
    2.7-liter PreRunner/4x4	  4.100	       ---------
    Transmission Type
    Man                                                     Auto
    Gear Ratios
    1st	 3.95	                                           2.80
    2nd	 2.06	                                           1.53
    3rd	 1.44	                                           1.00
    4th	 1.00	                                           0.71
    5th	 0.81	                                            ---------
    6th	 ---------	                                    ---------
    Reverse	 4.22	                                    2.39
    4x4 Transfer Case Ratio (low) 2.57:1
  15. Jun 30, 2009 at 8:31 PM
    Toyota Truck
    JT
    Texas
    2008 Prerunnner
    Is there a big gas milage diffrence between the two? If i have the 285's and switch the gear ratio will my gas milage be back to stock as welll as power?
  16. Jun 30, 2009 at 9:39 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I found that when I re geared (one example is going from 30" tires and 3:55 gears, to 32" tires and 4:10's) my mpg improved by 2 mpg. Power was returned to stock, or better. :)
  17. Jul 1, 2009 at 5:56 AM
    Toyota Truck
    JT
    Texas
    2008 Prerunnner
    Really wow, can you recommend any good brands?
  18. Jul 1, 2009 at 6:01 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I have used Genuine Gear, and Yukon and have not had any issues. :)
  19. Jul 7, 2009 at 3:14 PM
    derekp
    derekp giddy up!
    Derek
    Grand Forks, ND
    2001 X-Cab 4x4 TRD V6 5Spd
    Deck plate, Flowmaster Delta-Flow 40 series, 265/75-16 Wrangler TDs, more to come...
    Please excuse my ignorance...which batch of codes do I look at? There are numbers/letters EVERYWHERE!?!?!?! :confused:
  20. Jul 7, 2009 at 3:25 PM
    NAAC3TACO
    NAAC3TACO Middle aged member
    Just east of crazy, NV
    2014 SR5 DCLB 4x4
    Color matched door handles, Weathertech floor liners, bed mat, Durafit seat covers, tailgate clamp, 2016 TRD Sport 17" wheels with Yokohama Geolander AT tires , Toyota exhaust tip, Toyota/Yakima bike rail mount, Toyota wheel locks, Toyota hitch cover, Redline hood struts, unifilter on air pump.
    I'm confused too. According to my door jam sticker I have code A02A which is a 3.58 ratio. According to Toyota's website in 2008, the only ratio available in a 2.7 4x4 is 4.10. What gives?
