Anyone know what nut this is??
Discussion in '1st Gen. Tacomas (1995-2004)' started by gacandido2010, Feb 25, 2012.
  1. Feb 25, 2012 at 1:40 PM
    gacandido2010
    gacandido2010 [OP] Well-Known Member
    Gabriel
    Inland Empire CA
    01 Prerunner TRD
    Bilstein 5100s, Eibach Coils, All Pro Baja Leaf Pack, Fox 2.5x16", All Pro 1.5 spacers, Deckplate Mod, K&N Filter, Magna-Flow Exhaust System, Cobra Ultra Cb with 3" Firestick, 2 Hella 500 HIDs, custom mesh grill, blacked out lettering, Limo Tint, Fog Light Mod
    found this out, think it came out when i got my alignment done
  2. Feb 25, 2012 at 1:45 PM
    Texoma
    Texoma IG: cwehlin
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    That is one of the four nuts that hold your lower ball joint to the spindle. Replace it quickly. I believe it is a metric thread. Remove the bolt from the opposite side for measurement purposes and head over to the local hardware store(in a different vehicle) and get a matching bolt to replace. Grade 8, equivilent, or higher will do just fine. I belive torque specs are around 65ftlbs.
  3. Feb 25, 2012 at 1:46 PM
    brutalguyracing
    brutalguyracing BIG DADDY
    F.U> GUYZ
    broken mods
    this.....
    that is very close to being a disaster for you...dont drive it
  4. Feb 25, 2012 at 1:51 PM
    gacandido2010
    Gabriel
    Inland Empire CA
    01 Prerunner TRD
    are all four nuts the same you know?
  5. Feb 25, 2012 at 1:53 PM
    crf69
    crf69 scraping my emblems off my plasti-dip
    Ohio
    06 TRD OR BSP cab'n 1/2
    ummm yeah
    Wow.
    makes me cringe.
  6. Feb 25, 2012 at 1:55 PM
    gacandido2010
    Gabriel
    Inland Empire CA
    01 Prerunner TRD
    ya kinda scared me when i saw it
  7. Feb 25, 2012 at 1:57 PM
    crf69
    Ohio
    ummm yeah
    i would have their ass!
  8. Feb 25, 2012 at 2:25 PM
    Tacomadude89
    Tacomadude89 Well-Known Member
    Austen
    California
    2002 Tacoma TRD SR5, 3.4, 5spd
    -Bilstein 5100 Series shocks on all 4 corners -Rancho HD lift coils -1/4" Toytec driverside top plate spacer -Toytec 1" diff drop -Wheelers 1.5" AAL's -Toytec 1" lift shackles -Revtek extended length BPV bracket -285/75/16 BFG KO T/A's -Pro Comp rims -ET Conical tyle lug nuts -Spidertrax 1.5" wheel Spacers -CV Boot slide mod -TRD skid plate -Magnaflow 14" round muffler -Shortened tailpipe hidden behind framerail -Toyota bug deflector -Weathertech floormats -Black leather seat covers -Valentine 1 Radar Detector
    I would quit driving it until you get a replacement, seriously.
  9. Feb 25, 2012 at 2:27 PM
    tostidos
    tostidos Well-Known Member
    Apple Valley, CA
    07 LT 6spd
    make sure you ask for a BOLT not a NUT.
  10. Feb 25, 2012 at 2:49 PM
    Texoma
    Texoma IG: cwehlin
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    No! They are all not the same bolts. The two protruding on the inner part of the bracket are a different length than the two not protruding on the outer part. Go to the other side of the vehicle and pull the bolt that is the mirror image of the one missing from the other side and use that as your reference for a new bolt. After you get a new bolt, I would check the torque on the rest of the bolts to be sure that they are tight. I doubt the alignment shop touched those bolts, because they have nothing to do with your alignment.
  11. Feb 25, 2012 at 2:52 PM
    TacoMX
    TacoMX TW's Official anti body-lift pundit
    Jonathan
    Deltona, Florida
    I dont know about you (your info says you have a second gen) but on my 97 all four of the bolts are the same.
    Torque spec is 59 ft/lbs per FSM
    also...IIRC when I had to take them out it looked like they had green thread locker on them from the factory. I would go ahead and use some red lock tight on them for good measure.
  12. Feb 25, 2012 at 3:09 PM
    Texoma
    Texoma IG: cwehlin
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    I had a 2000 Tundra that they were a different length. They may be the same length, but I wouldn't chance it.
  13. Feb 25, 2012 at 3:14 PM
    joes06tacoma
    Joe
    Central Coast, CA
    The alignment guy shouldn't have been anywhere near that bolt. I doubt very much that the alignment has anything to do with that bolt coming out. But they definitely should have seen it and said something to you.
  14. Feb 25, 2012 at 3:34 PM
    gacandido2010
    Gabriel
    Inland Empire CA
    01 Prerunner TRD
    got the nut and fixed it :cheers:
  15. Feb 25, 2012 at 3:41 PM
    Texoma
    Texoma IG: cwehlin
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    Sweet sweet:drunk: beer time it is
  16. Feb 25, 2012 at 4:17 PM
    brutalguyracing
    F.U> GUYZ
    broken mods
    fixed
    and :headbang::cheers:
  17. Feb 25, 2012 at 4:22 PM
    scocar
    scocar It's not rocket surgery
    Dick
    In close proximity to an undisclosed location
    2015 DCLB 4x4 SR5
    Mostly pallet racks loaded with very impressive boxes, and a smashed head unit
    Shit. Good catch. MT Girl had one of this hanging on by a thread (literally) after a long weekend, barely caught it in time.
    Everyone should inspect theirs just to be sure. Make a note to do it whenever you change the oil or after any offroading.
    Have you checked your VIN on toyotaownersonline.com to see if your truck was affected by the LBJ recall? (or call a Toyota dealer) This isn't necessarily related, but it reminds me of the horror stories of those coming apart at speed. Everyone with an 01-04 should check this.
  18. Feb 25, 2012 at 4:24 PM
    Snowman
    Snowman I have a problem for your solutionÂ…
    Craig
    Somewhere in Canada
    Check out my build
    Mine are all the same length too. The Moog balljoints I got came with 4 new bolts, all the same length.
  19. Feb 25, 2012 at 5:01 PM
    TacoMX
    Jonathan
    Deltona, Florida
    thats what I thought :thumbsup:
  20. Feb 25, 2012 at 5:06 PM
    186000mps
    186000mps ..Slingin' up mud and we're scarying off bunnies..
    Charles
    Wimberley, TX
    01 Tacoma V6 4WD
    Bilstein 5100's, Toytec front adjustable coilover kit, Exporear leafs, Fox resi rears, Slotted & Drilled front rotors, 33x12.50 BFG ATs on Outlaw II 15 x 10s, Bushwacker cutout flares, K&N cold air intake with aluminum sheathing water baffles, ARB bumper with XD9000 winch with wireless remote, IPF 900XS lights, Flowmaster cat-back exhaust, Rhino bed liner, UWS gullwing toolbox with tools and recovery gear. 48" Hi-Lift Jack secured under toolbox.
    ^^ Juan Hung Lo...mine too '01
