Anyone know what "SMD" stands for?
Discussion in 'Garage / Workshop' started by Pster, Dec 13, 2009.
  1. Dec 13, 2009 at 4:23 PM
    Pster
    Pster [OP] Well-Known Member
    Charlotte, NC
    2006 Tacoma 4x4
    Bak Flip bed cover, shorty antenna, Peripheral iPod interface, Garmin 750 mount, add'l bed tie down rings, Westin nerf bars, hitch safe, tailgate lock, Ideal 1 3/4" turn-key clamp to secure tailgate from removal, Spare tire security cable, spare tire stainless air hose extender, Fumoto oil drain valve, Amp Research Bed X-Tender w/Schlage Cable Lock, bed mat, Redline hood struts
    Curious...what does "Unlimited Licensed" mean for an Electrician?
  2. Dec 13, 2009 at 4:35 PM
    98tacoma27
    98tacoma27 is gooder 'en chicken Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    200 AMPS has to be for another service somewhere. Maybe a garage or workshop?
  3. Dec 13, 2009 at 4:43 PM
    BLKTRD6SP
    BLKTRD6SP Well-Known Member
    Tim
    Crane Lake Alberta
    09 Black TRD 6 Speed
    2 way remote start,3M rockguard
    For N.C. it means:
    There are 10 different classifications of electrical contracting licenses. Each license has a specific scope and limitation of work allowed. The Limited (L), Intermediate (I), and Unlimited (U) classifications allow a licensee to perform residential, commercial and industrial work. The Residential dwelling license (SP-SFD) permits electrical contracting projects pertaining to single-family detached residential dwellings. There are also six (6) special restricted electrical contracting classifications which allow only a limited phase of electrical contracting work: Low Voltage (SP-LV), Elevator (SP-EL), Plumbing, Heating, and Air Conditioning (SP-PH), Groundwater pump (SP-WP), Electric Sign (SP-ES), Swimming Pool (SP-SP).
    200 amps is lots, you must have a big house...... or a grow op! :D
  4. Dec 13, 2009 at 4:44 PM
    Pster
    Charlotte, NC
    2006 Tacoma 4x4
    Thanks for the info! Hell, in St. Louis all the homes are built with 400 amps service!
  5. Dec 13, 2009 at 4:50 PM
    Pster
    Charlotte, NC
    2006 Tacoma 4x4
    200 amps is not much...can't add a hot tub for instance...it's the bare amount needed.
  6. Dec 13, 2009 at 4:55 PM
    paintdiddy
    paintdiddy Machine gun shits
    shithead
    nj and not from "the jersey shore"
    silver bullet
    turn that bitch off and see if the house fades to black. in jersey the main breaker has to be close to the meter.if not you must put a dissconnect near the meter.where is your meter and breaker panel?any pics
  7. Dec 13, 2009 at 5:38 PM
    BLKTRD6SP
    Tim
    Crane Lake Alberta
    Minimum around here is usually a 100 Amp panel. Panel size is determined by square footage and demand. Sure it would be possible to trip the main but 99.99% of people would never have enough appliances/heaters running at one time to do so.
    Do they use electric heat in St Louis? 400amps :eek:
  8. Dec 13, 2009 at 5:40 PM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    400 amps is like the American Standard
  9. Dec 13, 2009 at 5:46 PM
    BLKTRD6SP
    Tim
    Crane Lake Alberta
    400 amps seems like overkill for a house, I couldn't imagine many houses would pull half that amount of amperage.
    But overkill is good!
  10. Dec 13, 2009 at 5:49 PM
    HBMurphy
    HBMurphy Ban Pending
    Paul
    So California Coast
    09 Off Road Delete Model
    None
    Ask Al Gore! ;)
  11. Dec 13, 2009 at 5:51 PM
    paintdiddy
    shithead
    silver bullet
    most houses are (older)100 amps to (newer) are 200 amps. i dont how big the houses you guys are living in but 400 amps is way way too big for a house unless its 15,000 sp ft.
    maybe like blktrd6spd said.maybe if your house as all electric heat,stove,and hot water you will need more than 200 amp service
  12. Dec 13, 2009 at 5:54 PM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    Hmmm..........pretty sure that is what new houses here get. I will have to ask some construction buddies
  13. Dec 13, 2009 at 6:03 PM
    JeffRock
    JeffRock Well-Known Member
    Capital region, NY
    09 Tacoma accesscab 4x4 SR5 2.7L
    Toyota all weather floor mats. Mag light that clunks around in the jack compartment. Dog hair. Dog drool on the windows.
    Is he saying the panel is 200amps, or the circuit in question? Is it in the on or off position? Could it be a generator that feeds back to the breaker box?
  14. Dec 13, 2009 at 6:04 PM
    JeffRock
    Capital region, NY
    My house which is 100 Y/O has 150Amp tricord from the pole. But i have two 100 amp panels (Two family house).
  15. Dec 13, 2009 at 6:21 PM
    #35
    Yoytoda
    Yoytoda The Little Truck That Could
    Roland
    Big Bear,CA / Upstate NY(Saratoga)
    2010 Tacoma Regular Cab 4x4
    completely stock
    You can add a hot tub. A typical hot tub wired 220 only draws 50amps.
    just make sure your not running electric heat or washer, dryer, stove, fridge, microwave, water heater at the same time...
    400 is really convenient. especially for having a loaded garage...
