Anyone know what this bar is? Under pass. seat.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by xfactor, Jan 12, 2010.
  1. Jan 12, 2010 at 8:21 PM
    xfactor
    xfactor [OP] Well-Known Member
    Ray
    Texas
    2010 BSP PreRunner Sport
    Hey All,
    Trying to install my amps under the seats (2010 Access Cab). Drivers seat- amp fits fine. Passenger seat - there's a cross bar near the rear of the seat. It's really in the way.
    Anyone know what it is? Support? Does it work with the seat flip lever?
    Anyone remove it? Rework it? I really need to put the amp under there and probably gonna cut it :confused:
    [​IMG][​IMG][​IMG][​IMG]
  2. Jan 12, 2010 at 8:26 PM
    EquinsuOcha
    EquinsuOcha Bourbon
    Casey
    Ft Worth, TX
    07 PreRunner
    AFE Drop-in filter, Wet Okole seat covers, Hifonics 6.5" components in front, MA Audio midbasses in rear, Kicker 8", RE Audio 2 channel for components, Elemental Designs bridged 2-channel for sub, CB, Devil Horns, Rancho QuickLift, Rancho RS9000XL rear shocks, Toytec AAL, stickers, things and stuff.
    I removed mine. Odds are it's for seat stability in a crash. It just takes a proper sized torx bit (unless the 2010s are welded) and it comes right out. I've had no problems in the 20K+ miles that I've had mine out.
  3. Jan 12, 2010 at 8:27 PM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    ehh don't worry about it its just the passenger seat;)
  4. Jan 12, 2010 at 8:32 PM
    xfactor
    Ray
    Texas
    I'm almost gonna have to remove it. No where else to put the amp for the mains.
    Weird that it's only on the passenger side, you would think there'd be one on both seats.
    Either way, it's gettin' ripped out tomorrow.
    Thanks again,
    Ray
  5. Jan 12, 2010 at 8:44 PM
    EquinsuOcha
    EquinsuOcha Bourbon
    Casey
    Ft Worth, TX
    07 PreRunner
    Go ahead and do it. Like I said, I've had zero problems.*
    *By stating this I in no way take responsibility of the well-being of any passengers in your vehicle, only in mine.
  6. Jan 13, 2010 at 3:48 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    AHA!! That's what the handle for the fold flat action looks like, lol. Mine was missing when the truck was purchased & never have seen it. Thanks for the pic......................
  7. Jan 13, 2010 at 6:13 AM
    xfactor
    Ray
    Texas
    As per Mr Marv; Marv Rocks
    Hey Ray,
    Common situation here with an easy solution. If you remove the plastic cover at the end of that bar you will find a bolt there. Loosen the bolt, rotate the bar up out of the way, tighten the bolt back down and you'll be set! BTW, you may be able to do it without removing the seat however I have always had them out to make the wiring easier so I'm not positive.
    Marv's Place Custom Built Home/Auto Subwoofer Enclosures Etc
    1-831-383-0308 7AM-8PM PST Mon-Sat
    Speaker Baffles/Adapters/Rings/Amp Racks/DIY Kits
    Installation and numerous lines of Car Audio Equipment also available Authorized Hybrid Audio Technologies Dealer www.hybrid-audio.com
    Specializing in 2005-2009 Toyota Tacoma Pickups
    www.MrMarv.com
    http://s29.photobucket.com/albums/c258/MrMarv/?
  8. Jan 13, 2010 at 6:34 AM
    JDCPA
    JDCPA Well-Known Member
    Jim
    SW FL
    09 5 Lug Access Cab SR5
    Curt Hitch and etrailer.com wiring harness.
    I think that is the bar that actuates the release for the fold flat function of the passenger seat.
  9. Jan 28, 2010 at 8:47 PM
    xfactor
    Ray
    Texas
    The bar is only a support. I took Mr Marv's advice and just rotated it up out of the way, but...
    There's tabs on each end of the bar that keeps it locked to the seat rail, had to cut off both side on each end.
    Tab cut off.
    Re-installed
    Up out of the way.
