Anyone know what this noise is ?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Jphillips, May 14, 2019.
  1. May 14, 2019 at 8:32 PM
    Jphillips
    Jphillips [OP] New Member
    Jacob
    2007 Toyota Tacoma SR5 Prerunner 2WD
    squealing noise when truck is sitting while running and accelerating. drive belt was replaced maybe 1500 miles ago. i think it could be a pulley but the noise is getting to much to stand anymore and i’m not 100% sure what it could be. open to any opinions and suggestions.
  2. May 14, 2019 at 8:35 PM
    Bishop84
    Bishop84 Well-Known Member
    Idler bearing, closest to the oil filter.
    Very common, you should check all of them and the drive belt accessories.
    Jphillips[OP] likes this.
  3. May 15, 2019 at 8:09 AM
    mikalcarbine
    mikalcarbine Well-Known Member
    Phoenix, AZ
    2015 AC TRD OR
    Squirt some wd40 on the idler pulley bearings while it's running, it might quiet the suspected one up, if so time to replace
  4. May 15, 2019 at 9:16 AM
    Squirrel1812
    Squirrel1812 Member
    TN
    2006 Tacoma 4x4 6spd manual 2.7L
    K&N air intake
    Mine does that too except when I push the clutch in the squeak goes away.
  5. May 17, 2019 at 10:31 PM
    Jphillips
    Jacob
    i tried the wd40 and i’m thinking it’s gonna be a belt tensioner with worn bearings. will i be able to buy just the pulley and avoid buying the whole assembly or no ?
  6. May 18, 2019 at 8:51 AM
    mikalcarbine
    Phoenix, AZ
    2015 AC TRD OR
    Just went through this with a buddy, you can remove the pulley and press in a new bearing with press or a hammer and socket. Check the bearing part before you buy a replacement, it should interchange with 5203-2NSL which can be found online (almost impossible to find locally). Unfortunately you can't buy a pulley and bearing together anywhere to my knowledge
