anyone make a performance programmer
Discussion in 'Performance and Tuning' started by URBIKESUCKS, Jan 1, 2009.
  1. Jan 1, 2009 at 6:41 AM
    URBIKESUCKS
    URBIKESUCKS [OP] Well-Known Member
    Ron
    Prescott AZ
    2014 DCSB TRD OR
    New to TW first Toyo does anyone make a performance programmer?
  2. Jan 1, 2009 at 6:42 AM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    check out urdusa.com..........................they make the maf calibrator. it is spoken of very highly by lots of folks.
  3. Jan 1, 2009 at 6:57 AM
    jaxchrisfla
    jaxchrisfla Well-Known Member
    flooriduh
    lots
    there are no plug and play programmers like your superchips or hypertech and such for us. although you can get the maf cal, mapecu2 and apr x-1 all in plug and play format, but it will require a laptop to tune these things instead of just plugging the programmer in and pushin a couple buttons to change tune.
  4. Jan 1, 2009 at 3:49 PM
    URBIKESUCKS
    Ron
    Prescott AZ
    2014 DCSB TRD OR
    That sucks....Maybe someone will take notice and make one???
    I know w/ my Trade in Jeep JK it took a little while but they are making them now.
  5. Jan 2, 2009 at 5:04 AM
    XrunnIT
    XrunnIT Well-Known Member
    Austin, TX
    1GR-GZE X-Runner
    Built Motor by LC Engineering Boosted by TRD
    Won't happen. The APR X-1 is plug and play, and you can get the Map ECU2 or MAF Cal with a plug and play kit.
    Between the X-1 and the ME2, there is no room for anymore competition. They are able to do everything that is need for engine management.
  6. Jan 10, 2009 at 7:02 PM
    Alaskaflyer
    Alaskaflyer My other ride Hovers
    Cape Cod, MA
    08 Prerunner DC TRD Off Road
    OME 885 AAL, 2.5* shim, Light Racing UCA's. BFG AT KO 285/75/16, Spidertrax spacers, OME Shocks up front, Bilstein 5100 Shocks in back.
    What I liked about the programmers on other trucks I've had is the ability to make corrections for tire size and non stock gear ratio.
  7. Jan 11, 2009 at 6:20 PM
    jaxchrisfla
    flooriduh
    lots
    you can do this with the x-1 as well. well i know you can adjust for gear ratio, but not sure about tire.
  8. Nov 13, 2009 at 12:40 AM
    jerris
    jerris Well-Known Member
    jerris
    utah
    07 double cab, 6 inch fabtech 35 duratrac
    6 inch lift, 35 inch duratrac's
    if you re program for the after market gears would that do anything to mpg's
