Anyone make the hoodscoop functional?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by S7ICKlVlAN, Mar 11, 2012.
Thread Status:
Not open for further replies.
  1. Mar 16, 2012 at 12:26 PM
    #61
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    It IS in fact, a negative pressure area. I have checked this numerous times, and had friends do the same. The most simple way to tell, is to spray water on the hood, and see how fast you have to go before it blows off. I could get to 40 mph, and the water drops would just sit there and quivver. In this pic, you can see how air flows over a truck:
    In this pic of a Dodge RAM, arguably one of the more areodynamic pick ups, you can see that high pressure is dictated by the darker colors, while low pressure is described by the lighter colors. You can once again see the hood area, all of it, resides in a low pressure area.
  2. Mar 16, 2012 at 12:28 PM
    #62
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    In this pic useing Smoke as the visual aid, you can see the smoke doesnt come into contact of the hood at all. Only hitting the truck at the windshield, and roof line.
  3. Mar 16, 2012 at 12:33 PM
    #63
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    Bethel Park, PA. Burb of da Burgh.
    2010 MGM Mostly Stock Off-Road 4x4
    TRD Cat-back Exhaust. Semi-Debadged. Trimmed down stock Antenna. Weathertech vent visors. TRD FJ Cruiser Center Cap Wheel Mod. 265/75/16 Firestone Destination A/T,s . Inverter tapped into for outlet in cab. Tacomaworld sticker which adds 5 hp.
    What if I mod my hood, so it sits higher. I'll call a hood lift. 3 inch hood lift and so on. Seems legit, right? :eek:
  4. Mar 16, 2012 at 12:34 PM
    #64
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Sure. Putting it in the stream of high pressure air would allow the scoop to be functional, at the cost of decreased forward visability.
  5. Mar 16, 2012 at 12:36 PM
    #65
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    Meh, who needs to see.
  6. Mar 16, 2012 at 12:37 PM
    #66
    Fightnfire
    Fightnfire Recklessly tired
    Marysville, WA
    2021 GMC Sierra 1500 AT4 (Prev 09 Access Cab V6 4X4)
    Starting over with a new GMC AT4 Satin Steel Metallic Softopper, Bilstein 5100's @ 1.75 in the front, TSB Rear, 17x8.5 Lvl 8 Guardians, 265/70-17 Falken Wildpeak AT3W, Scooped, Anytime fog mod, Osram Nightbreakers, LED Interior lights, Debadged, Painted valance, Removed rear head rests, De-flapped, Hidden Hitch installed, Weather Techs, Flyzeye'd A/W/A, Cover Kings.
    Which is of course minor, forward visibility, in the grand scheme of things. ;)
  7. Mar 16, 2012 at 12:40 PM
    #67
    Fightnfire
    Marysville, WA
    If you mod a nose like this onto your truck, and made a functional hood scoop... that might work ... it should reduce the negative area on the hood and direct air into the scoop.
  8. Mar 16, 2012 at 12:57 PM
    #68
    Bryan139
    Bryan139 I have a spectacular aura
    NJ
    '09 Sport
    I cut some wires here. Added some wires there.
  9. Mar 16, 2012 at 12:59 PM
    #69
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    You can "want" physics to not work all you want, and ask who ever you want, until you get the answer you like......Its doent mean the result will be different. And its "Bernoulli" :)
  10. Mar 16, 2012 at 1:04 PM
    #70
    jdmdcfan
    jdmdcfan Well-Known Member
    east WA
    dcsb
    Making your hood scoop functional to justify its ricey-ness...................priceless. :rofl:
  11. Mar 16, 2012 at 1:14 PM
    #71
    Bryan139
    NJ
    '09 Sport
    This is how I understood Bernoulli's principal
    You're telling me if you stick our scoop on there that the wind would continue to go up and over the scoop as well?
  12. Mar 16, 2012 at 1:17 PM
    #72
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    The hood scoop is less than 2" tall. Now....by your logic, being as the scoop is closed off, dont you think it would creat drag in its location, if it was in the airstream? Now....Comparing the hood on a Pick up, to the wing of an aircraft, is silly. DOnt you think?
  13. Mar 16, 2012 at 1:26 PM
    #73
    Bryan139
    NJ
    '09 Sport
    It's a Japanese truck, nobody has to justify anything. It's got a Toyota emblem on the front and metric bolts holding the tailgate together. If the door sticker says USA, Mexico, Canada, or Uganda, it's a Japanese truck.
  14. Mar 16, 2012 at 1:26 PM
    #74
    friction
    friction Well-Known Member
    Charleston, SC
    '08 4X4 RC SR5
    Now would be a good time for me to start drinking.
  15. Mar 16, 2012 at 1:29 PM
    #75
    Bryan139
    NJ
    '09 Sport
    Comparing a non-scooped hood in a wind tunnel test to a scooped hood in a theoretical test is silly. And yes! I think it would create drag. I think that has something to do with it. I think water sits on the hood because of what's happening in front of it. Are you agreeing that a closed scoop creates drag? Because open or closed, if it's in a low pressure area that works like you say, then either way it shouldn't be effected.
    It's funny, I 100% took your word for it when I ripped the entire front of my truck apart to do my 5100's. Never did anything beyond plugs and oil changes before that. Didn't even think twice. Printed out the write up and knocked it out.
    But you're lying to me now. I know it. :p
  16. Mar 16, 2012 at 1:35 PM
    #76
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    First, calling me a lier is gonna piss me off. Now, as for the hood issue, all Im doing is telling you how it is, as many people on here have already done. You can argue all you want, but its not going to change how the air works on your truck.
  17. Mar 16, 2012 at 1:40 PM
    #77
    Bryan139
    NJ
    '09 Sport
    I was kidding, my bad. I thought the smiley with the tongue out would kinda give it away. I was actually giving you props. Being sarcastic about you lying means you're really not. Didn't come out the way I planned. I apologize.
    Weather it works or not, I don't plan on doing it, so it's not really worth beefing over. I just wanted to better understand it.
  18. Mar 16, 2012 at 1:44 PM
    #78
    Brunes
    Brunes abides.
    Rotorhead
    Around
    Julie won't let him play with his "cannon" anymore....He's grumpy :(
  19. Mar 16, 2012 at 1:45 PM
    #79
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Im not sure how else to help understand it, than whats already been posted. To help wrap your head around it, spray some water on your hood, and drive in a straight line. See how fast you have to go to get it to blow off. Also, Look at the design of vehicles that have actual functioning hood scoops. The WRX for example, has a lanted nose (more so than the Tacoma), and the scoop sits up quite a bit. Not only that, the a scoop in the center of the hood, even "if" in the air stream, is a horrible location for one. The Crysler "Air Induction" of the later 60's and on, was a good idea. The scoop faced backwards, and was at the base of the windshield. This is because the air over the hood, was found to "swirl" in a clockwise direction, and the base of the windshield was were the air (high pressure) came back into contact with the vehicle. My Honda has a factory air intake scoop on it. Its mounted at the top of the radiator, and gets its air right from the grill at the fron of the car. Just as in the pics I posted, that is a nice high pressure area.
  20. Mar 16, 2012 at 1:47 PM
    #80
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    BUILD!!! I am BUILDING a cannon!!!
Thread Status:
