Anyone not happy after installing the 1/4" lean spacer?
Discussion in 'Suspension' started by maxpower29, Aug 17, 2012.
  1. Aug 17, 2012 at 4:10 PM
    maxpower29
    maxpower29 [OP] Well-Known Member
    Jordan
    Nova Scotia, Canada
    2011 Tacoma 4x4 2.7 5 speed SWB
    All season mats, 2nd filter delete, DT header, Jardine cat-back, URD shifter, Bilstein 5100's all around at .85 front with Eibachs + .25 passenger/.5 drivers spacers and 1.5 AAL, 0w20 synthetic, Scanguage II, extra D rings, OEM backup camera+Mirror, bed mat, Extang Solid Fold, Popnlock 5300, Pro Comp 7089's 4.5bs 285/70/17 Revo 2s, De-badged
    Im debating on getting one to fix the rear lean, but I, not sure I should. I have a perfect front hight both sides, just the rear that sags. Im worried I will see a gain in the front thus making it lean to the drivers side. Anyone?
  2. Aug 17, 2012 at 4:14 PM
    SVHANC
    SVHANC Kermit
    Sam
    Knoxville, TN
    '10 4x4 5sp 4cyl Access Cab
    Weathertech Floor Liners, Scangauge 2, Tailgate Hose Clamp, Rear Seat Headrests Removed
    so don't change...
  3. Aug 17, 2012 at 4:29 PM
    maxpower29
    Jordan
    Nova Scotia, Canada
    some people are saying it will help the rear though. Thats why im asking
  4. Aug 17, 2012 at 5:08 PM
    rmcclurg1
    rmcclurg1 Member
    Russ
    Chandler, AZ.
    2006 Prerunner TRD_OR
    5100's at .85, 2012 4x4 coils and 2012TRDsport 4 leaf springs.The rest is stock for now.
    I did not know there was one for the rear. I asked Toytec about it when I bought the front spacer, they said there was not one available.
  5. Aug 17, 2012 at 5:16 PM
    maxpower29
    Jordan
    Nova Scotia, Canada
    ya it is for the front, but people said it helps the rear too
  6. Aug 17, 2012 at 5:20 PM
    rmcclurg1
    rmcclurg1 Member
    Russ
    Chandler, AZ.
    I got that exact same story out of Toytec, I need to measure mine again to see if it made any difference in the rear, I don't think it did.
  7. Aug 17, 2012 at 5:20 PM
    BassMaster06
    BassMaster06 Well-Known Member
    Dan
    Lady's Island, SC
    3" OME w/ Dakars, LR UCAs, 285/75/16 Duratracs, SS extended brake lines, UWS low pro, torn CV boots
    I thought the 1/4" lean spacer is used to correct the driver's side lean? AKA the trim spacer? I installed a "trim" spacer on my drivers side up front and I'm very happy with it...from what I can tell my truck sits level in the front, driver vs. passenger. I don't know how it would help the rear.... :notsure:
    EDIT: Sorry for the confusion, I installed the 1/4" spacers on both sides up front, but also installed the 10mm trim spacer on the drivers side only to correct the drivers side lean.
  8. Aug 17, 2012 at 5:22 PM
    maxpower29
    Jordan
    Nova Scotia, Canada
    ya i know. i hope its not just something fucked up in the rear because it definitely sits a good 1/2 lower on the drivers side
  9. Aug 17, 2012 at 5:23 PM
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    In all seriousness if your questioning the installation and it rides good now who really cares if it leans? I never fret the small stuff like that. I'm sure I have a bad lean. No one has ever caught it and said dam that trucks not level.
    Just park in uneven surfaces and you'll be fine :D
  10. Aug 17, 2012 at 5:24 PM
    ae111black
    ae111black Well-Known Member
    Kimo
    Hilo Hawaii
    10 TRD off road doublecab 4x4 silver
    plenty
    You can have one made. 1/4"x3 3/8" x5" aluminum bar, Drilled to accept a center bolt. And a longer center bolt. Problem solved.....
  11. Aug 17, 2012 at 5:30 PM
    maxpower29
    Jordan
    Nova Scotia, Canada
    well Im not even buying one, i will be making it at work. Im just not sure what I want to do yet. I. really just trying to get everything done at once so I dont waste money.
  12. Aug 17, 2012 at 6:52 PM
    ae111black
    Kimo
    Hilo Hawaii
    plenty
    I made mine too...... But their not for "lean"
