Anyone On Oahu Have TPMS Reset Tool?
Discussion in 'Hawaii' started by STOCKTRD, Oct 26, 2013.
  1. Oct 26, 2013 at 1:05 PM
    STOCKTRD
    STOCKTRD [OP] Well-Known Member
    In Traffic
    CustomTacos Mafia!
    Nachos, Lemon Heads, My Truck Is Stock!
    Anyone of Oahu have the TPMS reset tool that I can borrow. Might be swapping out a set of tires/rims with different sensors. Ill hook you up with a case of beer, lunch or rent it from you. PM if you have one. Mahalos.
  2. Oct 26, 2013 at 2:48 PM
    luka
    luka Well-Known Member
    Kailua, HI
    Prerunner -> 4WD Converted
    Pelfreybilt, Warn, BAMF, DTRL toggle on/off, FJ OEM Fog/Aux Light switches, 2012 lower center console swap, wired in auto-dimming rear view mirror, Wet-Okole inside, Weathertech , Rigid, Tint, Roto-Pax, Bestop, OME, Extended SS brake lines, TRD TX Pro/Baja Graphite 16" Rims
    I got one, it can scan what is currently on the truck ecu and can change it to another set that needs to be manually entered via laptop.
    If you have the new sensor IDs it'll take about 5min. There is a second tool that wirelessly scans each sensor if you don't know what it is, but I don't have that one.
    Dealership will charge an hour of labor or more to do it
  3. Oct 26, 2013 at 5:18 PM
    STOCKTRD
    In Traffic
    CustomTacos Mafia!
    This will be used on a Scion, would it still work?
    Ok, so I would have to know what the codes are and the only way to get the codes from the new sensors is to dismount the tires and get the ID numbers off of the new sensors? I really didn't want to take apart the new set.
  4. Oct 26, 2013 at 5:31 PM
    luka
    Kailua, HI
    it works for all cars with TPMS...
    either dismounting or buying the other scan tool that will pull the installed ID via a transmitter.
    if you want to chip into the cost, I could buy it. I've been looking to get the transmitter but haven't had an opportunity to use it yet.
  5. Oct 26, 2013 at 10:02 PM
    STOCKTRD
    In Traffic
    CustomTacos Mafia!
    Thanks, But my dad decided to just get new tires installed from Costco.
