Anyone out there with a 2011 or 2012 4x4 Tacoma with a 3" lift
Discussion in 'Suspension' started by blazer190, Jun 1, 2012.
  1. Jun 1, 2012 at 7:43 AM
    blazer190
    blazer190 [OP] Active Member
    Walker Louisiana
    TRD offroad 4X4
    I am looking at putting a 3" suspension lift on my 2011 4x4 Tacoma. Is there anyone out there that has lifted a 2011 or newer Tacoma. I am getting conflicting advise from the 4x4 shops in my area. One shop tells me a 3" is no problem another shop tells me not to go over 2 1/2" or I won't be able to align it. I have even called the different manufactures ready lift states the 2011 2012 tacomas front end geometry has Ben changed and a 3" lift would require new after market upper control arms. Rough country says that's not true they have not had any issues with alignment with their 3" suspension lift. I would like to here from anyone out there with the model years 2011 and 2012.
  2. Jun 1, 2012 at 7:50 AM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
  3. Jun 1, 2012 at 7:54 AM
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    Yep, I'm running about 2 1/2 with no aftermarket UCA's just fine...2011 Prerunner
  4. Jun 1, 2012 at 9:15 AM
    2009tacomav6
    2009tacomav6 Well-Known Member
    phx AZ
    2012 4x4
    TRD SC TRD Cat Back KMC 17x9 Addicts
    i use to run without UCA's. However, after adding them the truck helps handling a lot!
  5. Jun 1, 2012 at 9:30 AM
    DevL
    DevL Well-Known Member
    You will have shitty handling at over 2.5" of lift and no UCA. With 33" tires and new UCA you will need a cab mount chop and caster over 3.0 which is over Toyora max caster spec to get the wheel to fit without rubbing... plus lots of trimming and hammering.
  6. Jun 1, 2012 at 10:12 AM
    VolcomTacoma
    Jeff
    NorCal
