Anyone ran a tender spring?
Discussion in 'Suspension' started by treyus30, Apr 9, 2024.
  1. Apr 9, 2024 at 3:30 PM
    treyus30
    treyus30 [OP] 70% complete 70% of the time
    Trey
    Mesa / AJ, AZ
    '99 5VZ-FE Twin K03s w/Haltech
    Historic plates and 2 bar
    My 1st gen has ADS coilovers with clickers & stiff 700lb springs (no extra weight up front). I tell people my ride gets real nice the faster I go. I'd like it to be nice all the time. Was looking at Eibach's offerings for another project and tender springs caught my eye.
    Has anyone done this on a lifted taco, and more specifically, what ratio or tender spring rate did you go with?
  2. Apr 9, 2024 at 3:56 PM
    Strictlytoyz
    Strictlytoyz Well-Known Member
    Charles
    HA\/\/AII
    07 Shitbox
    Tender springs are more so for applications that go into negative preload at full extension. What length are your current coils and how much preload are on your coils now at full extension?
  3. Apr 9, 2024 at 4:47 PM
    treyus30
    Trey
    Mesa / AJ, AZ
    I think you're referring to helper springs. Tenders are supposed to reduce effective spring rate until they bind, so soft for the road, hard once you hit something.
    I'd have to go measure to answer your questions, I let ADS set everything up on these, but the preload collar is only about 3/4-1" from the top
  4. Apr 9, 2024 at 5:36 PM
    Strictlytoyz
    Charles
    HA\/\/AII
    07 Shitbox
    I don't know anyone personally running tender/helper springs. However, I would think coil selection and shim stack tuning would be the better option albeit more tedious. 700# is pretty overkill. I've got a 2nd gen with full skids, bumpers, winch (way heavier than yours) and I'm only running 500# coils. Also, coil preload is measured at the coil and not by amount of threads showing on the collar. For example say you have a 14" coil. With the coil installed at full droop the coil measures 13" meaning you have 1" of preload.
  5. Apr 9, 2024 at 7:14 PM
    TMFF
    TMFF Well-Known Member
    Tim
    Thornton, CO
    01/02 DCLB
    Stuff and junk and things...
    There isn't enough space to run a tender spring and dual rate hardware on OEM coilovers. Dual rate springs are only able to be used on 10" and up stroke shocks.
    Go down to a 600 lbs spring and get the coilovers tuned, it will perform like you want.
  6. Apr 9, 2024 at 10:22 PM
    treyus30
    Trey
    Mesa / AJ, AZ
    I figured that's what you meant with preload, I'd have to measure.
    This doesn't sound correct...
    sure, it's possible the primary coil is too tall and would practically render the tender of little use but then the solution would be shortening the primary. I can't fathom a reason there'd be a shock length restriction...
    ya I wish I'd gotten a lower rate spring, but either way I'd be buying new hardware at this point so I'd be up for trying the tender in conjunction unless it was unilaterally established to be a bad idea for some reason. Again, my real question is where to start with the rate for a practical ride experience
  7. Apr 10, 2024 at 7:15 AM
    TMFF
    Tim
    Thornton, CO
    01/02 DCLB
    There isn't enough shock body space for the spring adjuster, coil divider and 2 coil springs. The tender spring your wanting to go with is such a low rate that it will never be used. They are there for 12-18" travel shocks to keep tension on the springs at full droop in a triple rate setup, not to support any actual vehicle weight. Dual rate is an awesome tuning tool but your stock width ET shocks do not have enough space to run it.
    A 14x600 coil spring will swap onto your shocks without any other hardware to purchase, go to SDHQ and get 2 -3x14x600 Eibach's and swap them on. It will ride 100x better than the 700's.
    https://sdhqoffroad.com/products/14-eibach-coilover-spring?variant=13617520541731
  8. Apr 10, 2024 at 3:03 PM
    treyus30
    Trey
    Mesa / AJ, AZ
    I just noticed Eibach only offers a 50lb/in in 3"ID with a block load of only 175lbs anyway, so I'd be going into plain dual springs terminology-wise.
    What's the front of the truck weigh? Like 2000lbs? Divide by 2, 4 inch height on secondary spring, let's aim for 50% compression stationary.. SR/(700lb/in+SR)=1000lb/2in => 762lb/in spring, at 365lb/in for ~1inch of travel after accounting for coil size..? Eibach catalog maxes at 650lb/in for 4x3" springs w/2.32" travel so doing it backwards => 337lb/in for 1-(650/(650+750)) = 52% of compressive load => 1000lbs*52%@650lb/in ~ 0.74" compression, leaving 1.58" of travel on it. 48% goes to 700lb/in spring ~ also 0.74"; the only thing done adversely is add 4.0-2.32"= 1.68" of preload (2nd spring 'blocked'), which I can partially mitigate by moving my collar up all the way (again roughly an inch), or leaving me with ~0.75" of extra preload + the collar, so ~1.0".... that's my understanding of the math anyway
    https://eibach.com/race-spring-search?diameter=3.00"+I.D.&length=4.00"&rate=&type=
    https://eibach.com/product/SPACER300
  9. Apr 10, 2024 at 6:01 PM
    TMFF
    Tim
    Thornton, CO
    01/02 DCLB
    Don't forget the coil spring divider.
    https://agm-products.com/products/suspension-sliders
    Give it a shot and let us know how it goes.
    Strictlytoyz likes this.
  10. Apr 11, 2024 at 6:56 AM
    AccuTune Offroad
    AccuTune Offroad Well-Known Member Vendor
    El Cajon, CA
    treyus30[OP] and Saskabush like this.
  11. Apr 11, 2024 at 8:15 PM
    treyus30
    Trey
    Mesa / AJ, AZ
    It would seem your definition of tender spring coincides more with Eibach's definition of a helper spring. https://eibach.com/products/helper-tender-springs
    In lieu of variable rate springs readily available for Tacos, I'm simply after that "luxury" feel on the road with full capability off-road the second I hit more than patched up asphalt... If possible, ya know
  12. Apr 11, 2024 at 8:18 PM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    I’d never heard the term “tender spring”. Thank you for teaching me something today.
    AccuTune Offroad likes this.
  13. Apr 12, 2024 at 6:58 AM
    AccuTune Offroad
    El Cajon, CA
    You are correct, tender/helper spring are same thing. If you are after luxury feel, then I would focus more on getting the shocks tuned professionally. Majority of the ride quality you are experiencing comes from the internal valving. I'm not too savvy with 1st gens, but 3rd gens we are very limited on spring rate options, however the tuning options are almost endless for these aftermarket & tunable shocks. This where we spend the majority of our time when tuning Fox/King shocks. Modifying pistons, valving etc. Don't get me wrong, having the correct spring is a must, but I would focus more of the attention on valving. Hopefully ADS can be helpful in this department and get you dialed in the way you would like.
    TVH475 likes this.
