Anyone rebuilt a chainsaw?
Discussion in 'Garage / Workshop' started by Ccrames2018, Mar 16, 2019.
  1. Mar 16, 2019 at 11:18 AM
    Ccrames2018
    Ccrames2018 [OP] Jack of some trades.
    Caden
    Nor Cal
    07 AC 4x4 V6 6MT
    -Bilstein 5100s @1.75" -16x8 SCS Ray10s with 305/70R16 General Grabber AT -CMC -URD Short Throw Shifter -Bed stiffeners -Bed mat -Aftermarket head unit -AFE Rebel exhaust -ME-SO Customs dome/map lights -Window tint with eyebrow -OEM LED 2015 tail lights -GTR Lighting headlight bulbs -Husky floor liners -Camper shell -Sumo Springs -Air intake -Aftermarket Volkswagen key fob -Aftermarket A/C knobs -Aftermarket LED license plate lights -Console organizer -JBA High Caster UCAs
    I'm ordering an OEM cylinder, piston, and rings to rebuild my grandma's little Stihl MS180C. She ran straight gas in it and scored the cylinder and piston. It still runs if you give it some gas and isn't seized up completely, but I haven't done this kind of repair before and was wondering if anyone has some tips for a newbie. I am mechanically inclined and will be taking my time, this is more of just a fun project for me but I also don't want to end up wasting my time and money, so any advice is appreciated. Thanks!
  2. Mar 16, 2019 at 11:20 AM
    Skrain
    Skrain Time is an illusion. Lunchtime doubly so.
    Monticello, Ky
    2009 F.J. Cruiser
    Westin 9 LED Driving Lights.
    rebuilding the carb at the same time?
    Running Board Man likes this.
  3. Mar 16, 2019 at 11:21 AM
    PintSize
    PintSize Crossthreaded & torqued down
    Texas
    2011 2.7L 5 spd RC 4x4
  4. Mar 16, 2019 at 11:32 AM
    onakat
    onakat Well-Known Member
    Canada
    2000 indestructaco!
    I do rebuild small tools like chainsaws, snowblowers, lawnmowers, weed wackers, trimmers, etc during my spare time.
    If the piston is scored, yes, replace it and the rings, but if there is damage to the cylinder itself, you have to replace it as well (or have it bored if it can be). Don't put a brand new piston in a damaged cylinder.
    then while the chainsaw is taken apart, it would be good to rebuild the carburetor and put new fuel lines
    Running Board Man and Wyoming09 like this.
  5. Mar 16, 2019 at 11:36 AM
    Ccrames2018
    Caden
    Nor Cal
    07 AC 4x4 V6 6MT
    Yeah the whole block is part of the kit with the piston and rings. I'll check that website @PintSize linked for the carb and fuel lines. Do I have to replace the carb if the saw only has about 5 hours of run time on it? It's a pretty new saw.
    PintSize likes this.
  6. Mar 16, 2019 at 11:42 AM
    onakat
    Canada
    2000 indestructaco!
    if the carburetor is not old, no need to rebuild it.
    If the saw did sit for a long time with gas inside, take it apart and clean it with some carb cleaner. Old gas often cause lacquer buildup in the carb or lines
  7. Mar 16, 2019 at 11:47 AM
    Ccrames2018
    Caden
    Nor Cal
    07 AC 4x4 V6 6MT
    It just sat for about a day or so with new gas (that was supposed to be used in her generator but the cans weren't marked...)
  8. Mar 16, 2019 at 12:19 PM
    onakat
    Canada
    2000 indestructaco!
    one day is ok. I meant more like a full season or even a year or two
  9. Mar 16, 2019 at 1:10 PM
    Ccrames2018
    Caden
    Nor Cal
    07 AC 4x4 V6 6MT
    Yeah I figured as much. I think I'll just start with the block, piston and rings and see how it runs after that. It'll be a nice $100 limbing saw if it works out! My dad already bought my grandma a new one and told her to label her cans haha
    wilcam47 likes this.
  10. Mar 16, 2019 at 1:16 PM
    jowybyo
    jowybyo Well-Known Member
    Joe
    Baltimore, MD
    '14 MGM DCSB Postrunner 4wd Conversion, Debadged
    What about crank bearings and the connecting rod bearings? The oil in the gas lubes all of those. Running straight gas probably messed them up as well.
  11. Mar 16, 2019 at 1:17 PM
    Ccrames2018
    Caden
    Nor Cal
    07 AC 4x4 V6 6MT
    I can check into those as well. I'll probably pull it all apart before I order the parts to see if there's anything else I need.
  12. Mar 23, 2019 at 7:09 AM
    BarnBoy
    BarnBoy Well-Known Member
    96 Tacoma 2wd
    MS180C is a good saw, and parts can be had quite cheap. I've done crank seals on similar models before. For $100 you could probably have a new crank/rod, piston/rings, cylinder, crank bearings/seals, and have a brand new saw.
    One tip is USE THE RIGHT GASKET MAKER for the clamshell. I used Permatex Motoseal, gotta have something specifically designed for dealing with 2 strokes. Don't assume because it says safe for oil that it's safe for gas....and whatever you do DO NOT use black RTV. Get the right stuff, it will save a lot of trouble.
    Ccrames2018[OP] likes this.
  13. Mar 23, 2019 at 7:26 AM
    Ccrames2018
    Caden
    Nor Cal
    07 AC 4x4 V6 6MT
    Thanks for the heads up! I probably would have used the red high heat RTV I used for my URD short shifter. :facepalm:I'll have to see what it says, but better safe than sorry. I'll just go get a tube of that stuff you used.
  14. Mar 23, 2019 at 7:35 AM
    BarnBoy
    96 Tacoma 2wd
    No problem!! Glad I was in time. Here is a pic of it....couple bucks at O'Reilly's iirc.
  15. Mar 23, 2019 at 7:36 AM
    Red Baron
    Red Baron Let's call it livabetes, no more die
    Aaron
    Lost on a roundabout
    07 Radiant Red DCSB
    Things with metal, dog hair, more metal and lights
  16. Apr 8, 2019 at 4:46 AM
    ralfnjan
    ralfnjan Well-Known Member
    I've only done intake boots, impulse lines, carb kits. Not big hardware repairs needed so far.
    My 10yo Husky had fine sawdust IN THE CARB! It was getting hard to start. I'm trying to figure out how the fine dust got in. The air filter is ok, maybe an air leak where the cleaner boot mates with the carb?
  17. Apr 8, 2019 at 5:00 AM
    Captainskidmark
    Captainskidmark Well-Known Member
    Northern Illinois
    2015 4X4 TRD SPORT DCLB ~ Black
    ECGS 4.56 gears with Detroit True Trac in the rear. Camburg Ball Joint UCAs Dirt King LCA Dobinson IMS rear shocks Dobinson IMS w/ 352 coils DAKAR EL096 HD LEAFS AR172 17"x8" BAJA RIMS (5 wheel/tire rotation) GX470 Front Brake Upgrade SS extended brake lines Front and Rear (Toytec) 285/70/17 BFG A/T Toyota Roof Rack over Cab A.R.E. Z series CAP with Rhino Rack rooftop rails , -RED/WHITE LED BED LIGHTING -12V AUX POWER AND USB MAGNAFLOW CAT BACK RAAMmat Sound Abatement Pioneer AVH-2440NEX w/ Android Auto + Morel Speakers 120 VAC Block Heater Pelfreybilt Front/Mid Skids ATH Bed Braces ATH FRONT BUMPER - FULL LOOP BAJA DESIGNS FOGS HERETIC 20" LIGHT BAR ATH REAR BUMPER - STANDARD RIGID FLUSH MOUNT REVERSE LIGHTS Weathertech floor mats Rear Diff Breather Mod Wheeler's Super Bumps + Ubolt Flip Kit ABS Kill Switch Mod Northstar AGM Battery Pedal Commander Desert Does It Seat Spacers
    Buy Grandma the Stihl premix gas..... i wasn't a believer in it due to the cost, but it is nice picking up the saw in the spring after sitting all winter and having it start on 2 pulls..... At my Stihl dealership if you buy a gallon of the Stihl premix they will double the warranty.....
  18. Apr 8, 2019 at 6:05 AM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    If it was run on plain gas it didn't run long enough to damage anything other than the bore and piston I would wash it out with a fuel mix before you put it back together. Stihl did run a deal on oil but it was for a new saw it just extended the warranty. The 28" one of 3 is the last resort saw it's got to be pretty big to fire that one up the limbing saw is the fairly new MS171. IMHO there are two chain saws the ones that won't start when you need them the most and then the Stihl's
  19. May 23, 2019 at 7:46 AM
    Ccrames2018
    Caden
    Nor Cal
    07 AC 4x4 V6 6MT
    Well here's a little update, I finally got around to tearing this thing apart and got it done late last night. I haven't fired it up yet because I don't want to wake up the whole neighborhood lol. Thanks for all the suggestions!Snapchat-91639324.jpg IMG_20190523_000324.jpg
  20. Dec 30, 2019 at 11:57 PM
    Ccrames2018
    Caden
    Nor Cal
    07 AC 4x4 V6 6MT
    Well it's been a while since I rebuilt this saw, and from what I hear its still running well! Sold it to my dad for the cost of parts. Thanks for the tips guys!
    wilcam47 and teamhypoxia like this.
