Anyone recommend a backup camera?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Cutter_, Sep 28, 2020.
  1. Sep 29, 2020 at 1:02 PM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    Yeah, I wasn't advocating that one I linked to, just a random one I found to kinda see whats out there.
    I still like the idea of a separate camera like the ones you posted. I guess I can just see getting a whole new lock/handle, and the dumb handle breaking.
    Cutter_[QUOTED][OP] likes this.
  2. Sep 29, 2020 at 1:05 PM
    Cutter_
    Cutter_ [OP] I probably could have googled this
    2002 Super Air Nautique Build
    Old Man Emu lift, 2 10" JL subs
    If you find a proper camera, please link it. I believe taking a pop-lock and dremel-ing a hole for a camera is the cleanest and cheapest way to go. Now, we just need to solve the 180-degree camera issue and find one that can spot both taillights at that mounting position.
    The pop lock in that Amazon link just slides under the OEM handle.
  3. Sep 29, 2020 at 1:38 PM
    RysiuM
    RysiuM Well-Known Member
    Rysiu
    Was Golden State, now Poland EU
    1995 4x4 LX Ext Cab, I4 2.7, MT, 335K miles
    DD Deck+backup camera, LED DRL, All LED except H4 Hella
    Surly will do. I already killed one esky camera mounted in my trailer receiver - road dust "polished" the lens to the point of "I see nothing" :). Here is the comparison of the camera after 3 years of use and the new one.
    and the sample picture taken
  4. Sep 29, 2020 at 10:32 PM
    locutus43
    locutus43 Active Member
    i have a cheap one that came with a android head unit has a light it works good speaically for the trd trucks just put it under where the licnese plate is run a screw through the bottom bolt hole so no one sees your camera still sees good
  5. Sep 29, 2020 at 11:15 PM
    reallifeonhold
    reallifeonhold Well-Known Member
    Travis
    2004 4WD 5MT
    Cutter_[OP] and Hamer95USA like this.
  6. Jul 10, 2022 at 8:27 PM
    taco bout it
    taco bout it Well-Known Member
    Los Angeles, CA
    2003 DC Tacoma PreRunner V6 Limited TRD
    the wireless backup cameras i got from Amazon are so bad. barely can see anything.
  7. Jul 10, 2022 at 9:30 PM
    jmag310
    jmag310 Member
    2004 Tacoma 4x4 5 speed
    Overland under budget did a cool video of how he set up two cameras, one for front and one for rear. He says he used the front one for arching steep hills without a spotter. It’s on YouTube
  8. Jul 11, 2022 at 2:51 PM
    wesb1023
    wesb1023 Well-Known Member
    Westley
    Eastern NC
    04 Double Cab
    I currently have a Garmin backup camera that is wirelessly connected to my gps. The gps is the monitor of course… it’s hardwired to the reverse lights for power but is wireless to the gps. I personally wouldn’t recommend this setup as it doesn’t show a very clear picture. Garmin also makes a battery powered one, but I don’t think that would be worth the money. The only positive thing I can say about the garmin unit is you can have multiple cameras, one one your truck, and one on your trailer or whatever. Sometimes it takes as long as 5~10 seconds to connect to the camera and an image to appear, by that time I’m already driving forwards.
    I would personally choose a wired system of some type if I had it to do again. I’m running my factory radio, and really feel awkward looking down at it while backing up….I’ve had one before.
    I would probably recommend getting one built into your rear view mirror, that is hardwired. Not gonna be cheap though. I also had a rydeen gps rear view mirror with camera. It was a small display, and I’d probably still be using it if I could figure out how to update the maps on it.
    It had the best day/night camera picture, but the display was very small.
    Tuluk likes this.
