Anyone replace leaking power steering return line?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by nomad_archer, Apr 21, 2018.
  1. Apr 21, 2018 at 9:25 AM
    nomad_archer
    nomad_archer [OP] Well-Known Member
    Trevor
    Brickerville (Lititz), PA
    08 DC Tacoma V6 SR5
    I need to replace my return power steering line. I just ordered the part from autozone and am wondering if this is as easy as it looks? I appears there are 3 bolts that I can see and 2 hose clamps. I feel like I am missing something. Is this job easier on ramps or jack stands with the wheels removed? I any tips would be greatly appreciated.
    Here is the part that I ordered https://m.autozone.com/suspension-s...teering-return-hose/591064_686837_0?location=
    I almost fell over when the dealer told me $380 for the pressure and return hoses and they were only sold as an assembly. $35 from autozone feels a lot better than that.
    Any help is appreciated.
    Thanks - Nomad.
  2. Apr 21, 2018 at 10:55 AM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    The link is not working.
    You'll get a better deal on OEM parts from TW vendors, but nothing close to the aftermarket prices for parts made in China. Not that they are bad if quality control is kept to a high bar.
    Might as well replace the return hose from the reservoir to the metal line near the chassis. It's a pre-form hose, but I replaced it with a straight ATF hose. I think it was 3/8" ID, and you'll probably need new clamps if the OD is not the same as OEM.
  3. Apr 21, 2018 at 12:01 PM
    nomad_archer
    Trevor
    08 DC Tacoma V6 SR5
    Sorry I can't seem to get the link to work but the part I want to replace is the return from the rack to the reservoir.
    I haven't ordered yet but will take a look at the sponsors to see if anyone has the part.
  4. Apr 21, 2018 at 12:07 PM
    knottyrope
    knottyrope Well-Known Member
    Knotty
    Bahstun
    09 Taco CCLB 4x4 SR5 4.0
    Pads, rotors, ujoints, 5900K Super White Xenon HID Halogen Bulb Fog Light
    I bought my hose assy in eBay for 100.00 and you need a flare nut wrench .easier to loosen the rack for more room which I did since it was replaced.
  5. Apr 21, 2018 at 7:15 PM
    nomad_archer
    Trevor
    08 DC Tacoma V6 SR5
    I am going to try and replace just the return line. However if I need to replace the entire assembly what size flare nut wrench is needed?
  6. Apr 22, 2018 at 11:09 AM
    Chuy
    Lakeside, CA
    Silver Taco
    Both of the hoses on my reservoir are clamped on. The flared hoses are on the pump and rack/pinion.
  7. Apr 23, 2018 at 4:54 AM
    nomad_archer
    Trevor
    08 DC Tacoma V6 SR5
    I understand that. I'm considering just replacing the whole assembly from the pump to the rack and from the rack to the reservoir. I am trying to find out which size flared nut wrench I need to buy for remove the pressure line from the pump and rack.
  8. Apr 23, 2018 at 5:26 AM
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
    Use your open-end metric wrenches to determine proper flare-nut wrench size. If a 12mm open-end fits, then buy a 12mm flare-nut wrench, etc.
  9. Apr 23, 2018 at 5:53 AM
    knottyrope
    Knotty
    Bahstun
    harbor freight flare nut wrench set was worth it to buy
    I cut my line and used a combo wrench on it
    Once you see the hose assy, you will thank your self for replacing the whole thing instead of just the return line
  10. Apr 23, 2018 at 6:00 AM
    Radarninja
    Radarninja Safety 3rd
    Northern California
    06 taco
    Chromed out radiator cap
    Op. It's an easy job and as straight forward as you think. I just did it on my truck a couple weeks ago.
    Only problem I had was I could only get about a 1/16 of a turn at a time on the nut at the rack, so it took forever.
    I also took off the hose holding clamps near the bottom as that was in the way of my wrench.
    I bought my replacement from rockauto.
    Good luck
    nomad_archer[OP] likes this.
  11. Apr 23, 2018 at 6:11 AM
    Jckdnls
    Jckdnls Roads less explored
    Spicer, mn
    93 3.0 v6 sr5 5spd 08 ac or 6sp
    Dakar torsion bars
    But 2 flare wrenches one for breaking loose. Cut the handle off the second for more clearance quicker. Got alot if home modufues tools.
    970btu and nomad_archer[OP] like this.
  12. Apr 23, 2018 at 12:22 PM
    nomad_archer
    Trevor
    08 DC Tacoma V6 SR5
    Thanks everyone! I have the truck up on ramps and the skid plates off. I just ordered the whole assembly from rock auto. The price was so good and the pressure like looked ehhh so just made sense to replace it all. Now I just have to wait until the part gets here. I guess I will just keep sprayin the bolts with pb blaster to have them ready to come off. I'm in need of a harbor freight trip for the wrenches and I will be off to the races on this little project hopefully by friday.
  13. Apr 23, 2018 at 12:53 PM
    knottyrope
    Knotty
    Bahstun
    if you don't think you have enough room when working, drop the tranny mount to raise front of motor up
  14. Apr 23, 2018 at 1:12 PM
    nomad_archer
    Trevor
    08 DC Tacoma V6 SR5
    I doubt I have the proper equipment to pull that off.
  15. Apr 23, 2018 at 1:21 PM
    knottyrope
    Knotty
    Bahstun
    its four bolts to drop the tranny down and I used the jack in the truck to rest it on and raise back up
  16. Apr 24, 2018 at 4:00 AM
    nomad_archer
    Trevor
    08 DC Tacoma V6 SR5
    I will keep that as an option then. I didn't think it would be that easy. I learned something new. Thanks!
  17. Apr 24, 2018 at 6:00 AM
    knottyrope
    Knotty
    Bahstun
    working on a vehicle isn't that hard, you just have to do it and learn a bit
  18. Apr 24, 2018 at 7:28 AM
    nomad_archer
    Trevor
    08 DC Tacoma V6 SR5
    I've always done my maintenance work and minor things. Power steering lines are a new one for me but again it doesn't look too hard. It will probably take me an hour or two but it wont be a problem.
    Skyway likes this.
  19. Apr 24, 2018 at 7:33 AM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    It’s a easy job
    Make sure you actually use a flare nut wrench though
  20. Apr 24, 2018 at 7:55 AM
    knottyrope
    Knotty
    Bahstun
    soak the bolts in PBlaster a day or two before and it will be easier to remove
    my splash guard bolts broke and had to get speed nuts and bolts for it after grinding off the old nuts
