Anyone replace the "overhead garage door opener" with the compass/temp module?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Larry, Aug 1, 2010.
  1. Aug 1, 2010 at 3:51 PM
    Larry
    Larry [OP] CARL
    CARL
    Is this mod possible?
    My SR5 has the garage door opener deal...I'd rather have the compass and outside temp feature.
    Can it be done?...who has done it?...will my dealer service dept do it?...Ideas on cost?...
    TIA
  2. Aug 1, 2010 at 3:54 PM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    lrgrnr did a swap w/ a guy. i want to swap my sunglass thing out w/ a garage door opener
  3. Aug 1, 2010 at 4:12 PM
    topgun155
    topgun155 Well-Known Member
    Zack
    Richmond, TX
    2018 F-150 5.0
    RIP to my 08 Prerunner DC
    The wiring is already there. IIRC the whole upper console needs to be replaced since the temp/compass doesn't fit into the hole right.
  4. Aug 1, 2010 at 4:16 PM
    Larry
    Larry [OP] CARL
    CARL
    Well that's a bummer. :(
    So...is the temp sensor already placed on the truck somewhere?
  5. Aug 1, 2010 at 4:37 PM
    topgun155
    Zack
    Richmond, TX
    2018 F-150 5.0
    I think there is a difference between the 09+ and the 05-08. There is a programming difference.
    Some have said that the wiring for the sensor is already there, but I cant find it on mine. Also if you don't have the sensor. It should be between the grill and radiator on the vertical support. You should see the holes for it.
  6. Aug 1, 2010 at 5:25 PM
    TacomaBuzz
    TacomaBuzz Well-Known Member
    CT
    2014 RegCab 4x4 TX Special Edition
    Sirius, Bugflector,back-rack, stepsides.
  7. Aug 1, 2010 at 8:01 PM
    JKD
    JKD Well-Known Member
    The 09+ isn't just a basic programming change, the whole system was changed. The signal for the temp sensor now comes from the A/C control logic over the vehicle bus.
  8. Aug 1, 2010 at 8:16 PM
    TacomaBuzz
    CT
    Correct , totally incompatible systems from 05-08
  9. Aug 2, 2010 at 11:41 AM
    Sky
    Sky Taco Member
    Brandon
    Redlands/Yucaipa
    05 V6 4x4 TRD Off-Road
    First of I painted my truck Satin flat black,.... well faded satin flat black lol, it has 5100s up front and J66's as well as billy 5150s in the rear, 285/ 75/16 Falcon wild peak A/T, Axis regulators painted satin black, with a tan rings! brush bar with 30 in led light bar , Custom rear Bumper, Straight Pipe. Led Hi/Low, and led fog lights, Flat Black Interior!
    well I have a question... how do you remove the overhead temp console thing...with out breaking it...lol?
  10. Aug 2, 2010 at 9:46 PM
    TacomaBuzz
    CT
    There is only 2 screws holding the console up and snaps, Remove the 2 screws and pull firmly but carefully down, then unclip the wire harness to prevent the wires from being stressed. 2 min job literally
  11. Aug 3, 2010 at 4:03 PM
    Sky
    Sky Taco Member
    Brandon
    Redlands/Yucaipa
    Thank you i know where one of the screws are... where the 2nd one at?
  12. Aug 3, 2010 at 9:50 PM
    TacomaBuzz
    CT
    the 2 screws are inside the sunglasses holder, you will see them when you open it and look up
  13. Aug 3, 2010 at 11:05 PM
    Sky
    Sky Taco Member
    Brandon
    Redlands/Yucaipa
    oh ok thank you!
  14. Aug 3, 2010 at 11:50 PM
    achirdo
    achirdo I Weld!
    Adam
    North DFW
    06 dodge ram 3500 5.9 cummins
    Subbed
  15. Jan 10, 2011 at 3:15 PM
    FASTK
    FASTK Well-Known Member
    Gregg
    Columbus
    2010 4dr 4x4 long bed
    Just called my local dealer to ask if I could replace my stock garage door opener/sunglass holder with the compass/temp gauge. he says "no" on my 2010 Dbl Cab.
    That does n't sound right but he says Toyota does not sell it as after-market part. is he right?
  16. Jan 10, 2011 at 3:46 PM
    jimmygle
    jimmygle Well-Known Member
    Jimmy
    Spokane, WA
    2011 Tacoma SR5 DC
    2011-01-06: Disabled seat belt beep -- 2011-01-12: Installed Aries Bull Bar -- 2011-01-28: WeatherTech Digitals Front & Back -- 2011-02-05: 30% Front Window Tint -- 2011-03-29: Wet Okole's Front Seats
  17. Jan 10, 2011 at 4:07 PM
    fortyniner
    fortyniner Active Member
    Seattle
    08 tacoma 4x4
    I bought a used 2008 and asked about having the temp/comp installed and they said it would cost around $400. My wife told me to just stick my head out the window to see how cold it was.
    jim1234 likes this.
  18. Jan 10, 2011 at 4:08 PM
    TerryS
    TerryS Well-Known Member
    Terry
    Cape Cod, Mass.
    '24 Celestial Silver DCLB SR5
    OEM cast aluminum running boards & tonneau cover.
    I bought a used '09 temp/compass console - Toyota calls it an "Accessory Meter" - and simply replaced my standard '10 overhead console with it. I believe there was just one screw in the console holding it in place and 2 latches by the windshield. Removal was quite easy. The wiring for the display is there, clipped into a "dead" socket on the back of the standard console. The temperature sensor was already installed in my engine compartment and located behind the vertical strut that's in front of the radiator. There are a few threads on this site describing how to switch the console out. I am not certain, but I believe you can buy the entire console from a dealer or on-line at one of the Toyota parts suppliers.
    I paid a whole lot of money for my used console, but I do use it and I don't regret it buying it.
    Good luck in your search; the '09+ are hard to find. I haven't seen another since I bought mine.
  19. Apr 21, 2012 at 9:32 AM
    tango down
    tango down Policy Ninja
    jeff
    peoples republik of IL
    12 Taco DCSB TRD Off Road
    LED interior, rail mounted ammo cans
    thanks, search button worked and i found this helpful info
