Anyone replace their cab bushings?
Discussion in 'Suspension' started by MeFryRice, Aug 28, 2016.
  1. Aug 28, 2016 at 3:14 PM
    MeFryRice
    MeFryRice [OP] Well-Known Member
    Marietta, Ga
    '16 QS Tacoma DCOR4x4
    I currently have a set of the @allpro Heavy Duty rock sliders on my '16 DCSB and when enjoying the trails, it sounds like someone is constantly knocking on the door. The cab and slider only hits on the rear most section. I know All-Pro calls to have the pinch weld cut to allow for room but was curious if any of you have replaced the cab bushing with a urethane piece? I'm sure replacement of the bushing is more labor intensive but I'd be willing to travel down that road if it allowed me to not cut the truck.
    For those that have experienced this, did you guys automatically cut the pinch weld or find another resolution?
  2. Sep 6, 2016 at 1:23 AM
    Clay7160
    Clay7160 Well-Known Member
    2018 MGM TRDOR DCLB 4x4
    GYEON ceramic coating
    what about unbolting cab mount, and sliding in a piece of thin rubber, or material they use between leaf springs that will take lots of wear from rubbing, then tighten cab mount down again. or notching the sliders, they would still be plenty of strong enough if the notch was boxed in.
  3. Oct 14, 2017 at 12:30 PM
    KevC
    KevC Well-Known Member
    I don't mean to dig up an old thread but can you explain the sound it makes?
    Everytime my front end dips.. I hear almost a clicking sound. Sounds like a rusty bolt is getting loosened?
    Someone told me it may be my can mount
