Anyone rockin 15" rims?
Discussion in 'Wheels & Tires' started by GunNut, May 11, 2011.
  1. May 11, 2011 at 9:50 PM
    GunNut
    GunNut [OP] Member
    So Cal
    00 PreRunner SR5 & 89 4Runner SR5 4x4
    None
    Hi all,
    I'm new to the tacoma world, I'm a recent transplant from Yotatech.com to here. Prior to this, I've had an old school Toyota pickup (22R) and a 1st gen 4runner (3VZ). My typical set up had always been, 15" Rims, with 33x12.5's.
    I recently had the opportunity to purchase a buddy's 00' Tacoma PreRunner and wasn't sure what rim size would work. I've always seen 16s on Tacos and the stock rims on the PreRunner are 16s as well.
    So my question is, is there anyone running 15's on the 1st gen Tacoma? PreRunner or 4x4? Pros and Cons? Pics would be awesome!
    Thanks All!!!
  2. May 11, 2011 at 9:52 PM
    medic2230
    Murph
    Bama! Roll Tide
    I'm rockin 15's.....stockers on 31x10.5x15's FTMFW!!!!
  3. May 11, 2011 at 9:52 PM
    mikesdoublecab
    mikesdoublecab LT Chase Truck
    Mohawk Mike
    Glendale, CA
    01 Tacoma DoubleCab V6 Prerunner
    Engage Offroad long travel front and rear with some fat tires.
    i don't have pics, but a couple of my buddies with first gen tacos are running 15s just fine...
    gotta love that about the first gens...
  4. May 12, 2011 at 8:51 AM
    GunNut
    GunNut [OP] Member
    So Cal
    None
    Thanks for the replies!
    Good to hear 15s will work on the 2000 Tacoma. Oh BTW, for those that replied, and I'm not sure if it matters, but the Tacos you mentioned are 6 lug Tacos?? Again, not sure if it matters, but thought I'd ask. Thanks!
    Still hoping someone has pics? Anyone?
  5. May 12, 2011 at 8:54 AM
    malander
    malander Well-Known Member
    max
    01 limited trd 4x4
    deck plate mod,jba cat back,bilstein 5100's,ome 883 springs, Allpro expos, allpro U-bolt flip kit, 10" Bilstien 5150 shocks, custom lower shock mounts
    Jlee is running 15x10s and 33x12.5s maybe check out his build.
  6. May 12, 2011 at 8:57 AM
    BFA
    BFA Nuttier than squirrel shit.
    Brian
    Phoenix, AZ
    2003 3.4 4x4 5spd
    check out my build and i got plenty of pics of my truck with 15" steelies.. gotta run a small spacer on the back though to keep it from grinding the caliper which is the only drawback but i love them
  7. May 12, 2011 at 9:06 AM
    jblaze805
    jblaze805 Well-Known Member
    Ventura/Fresno, CA
    04 trd pre-runner
    2.5" king coilovers, caburg uca, magnaflow exhaust, aem intake
    im running 15" rims w/ 31X10.5
  8. May 12, 2011 at 11:43 AM
    Mescalero
    Mescalero Beretta Taco
    Anderson, SC
    '15 DCSB TRD PRO Mag Gray
    welcome to TW you'll love this site!
  9. May 12, 2011 at 11:45 AM
    medic2230
    Murph
    Bama! Roll Tide
    Mine is 6 lug 4x4
  10. May 12, 2011 at 5:07 PM
    GunNut
    GunNut [OP] Member
    So Cal
    None
    Thanks for the responses everyone!! This forum Rocks!!
  11. May 12, 2011 at 5:12 PM
    GunNut
    GunNut [OP] Member
    So Cal
    None
    How small of a spacer? How does it rub? Is it a question of backspace on your rims?
    Thanks BFA!
  12. May 12, 2011 at 5:16 PM
    BFA
    Brian
    Phoenix, AZ
    2003 3.4 4x4 5spd
    Mines got like 4.125 backspacing they need a 1/4 in spacer cause its not think enough where the rim mounts so it barely rubs the caliper.. I have 0 issues with them and they look good
  13. May 12, 2011 at 5:20 PM
    DanglingFury
    DanglingFury Creeper
    Keith
    Bowling Green, KY/Lake Cumberland, KY
    2006 4Runner 4x4
    Daystar 2.5"/1" lift-level BFGoodrich KO2's
    I'm running 235/75/15
    No issues at all . . . .. tehe!
  14. May 12, 2011 at 5:28 PM
    JLee
    JLee The Man! Vendor
    Jerry
    Grass valley CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    Yep build is below.
  15. May 12, 2011 at 7:32 PM
    GunNut
    GunNut [OP] Member
    So Cal
    None
    That's a SICK Taco JLee! :proposetoast:
    What back space does your 15x10s have? No spacers?
  16. May 12, 2011 at 7:45 PM
    bowhunter11199
    bowhunter11199 Well-Known Member
    hope this helps.... sorry this is the best pic of tires(33x12.5x15) (also i think they would look better with black 15's)
  17. May 12, 2011 at 9:22 PM
    ontarioyota
    ontarioyota Well-Known Member
    @scott777taco INSTAGRAM
    SW Ontario, Canada
    2001 Reg Cab 4x4
    Blacked out badges-rims OME lift with 881's & dakar pacs, summer tires=BFG 31x10.5x15 on 93 4runner rims,winter= 265 75 16 DURATRACS on stock steelies,Flowmaster exhaust, deck plate mod, ARB front bumper
    here is 93 4runner 15 inch rims I just restored and then mounted 31x10.5...on my 01 4x4017_f38fd0738dde267102d7e99a17f3bf1f654df037.jpg
