Anyone Roll their 2nd Gen Offroading?
Discussion in 'Off-Roading & Trails' started by especk, Mar 22, 2012.
  1. Mar 22, 2012 at 7:30 PM
    especk
    especk [OP] Nothin' Special
    Erik
    Redding, CA
    2010 Tacoma Reg Cab 4x4
    3" OME lift with 885 coils on nitrocharger 90000 shocks with 5mm trim packer on driver's side, TC UCAs, Rear OME Dakar leafs with nitrocharger shocks, All-pro U-bolt flip kit and 3* Toytec shims, extended rear brakelines, 16" Raceline Rockcrusher 887 wheels with 3.6" backspacking, BFG KM2 305/70/16 tires, Doug Thorley header, Doug Thorley catback exhaust, Volant CAI with ram air, Weathertech floor mats, Kicker 12" sub, Kenwood 500W RMS amp, Relentless Fab front and rear bumpers, 4.88 gears, custom flatbed with swing out tire carrier
    Just curious to see if anyone has rolled their 2nd gen while offroading. I've heard of a couple people rolling their tacos by going too fast around turns etc, but has anyone rolled their 2ng gen while rock crawiling/trail riding, like in 4wd-lo? And if so, what were you doing and how high of a lift did you have on your truck? I ask because these trucks can get into some pretty gnarly situations but I've never heard of or seen one topple over.
    Thanks guys.
  2. Mar 22, 2012 at 7:35 PM
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig... 4-link long travel
    we had a florida member flip a 2nd gen at an offroad park, but it was due to a drift. when wheeling at speed, it's a whole different monster than off camber rollovers.
  3. Mar 22, 2012 at 7:41 PM
    saundern
    saundern Swerve for nothing
    Nick
    Simpsonville, SC
    2005 TRD Sport
    wasn't there a video of that floating around here at one point?
  4. Mar 22, 2012 at 7:47 PM
    AZBACKCOUNTRY
    AZBACKCOUNTRY Well-Known Member
    Doug
    AZ-between the hammer and the anvil
    11' AC TRD OFF-ROAD 4x4
    Pelfreybilt front aluminum bumper,AVID off road weld on sliders, RCI Offroad IFS & transmission Skid (steel), RCI LCA skids (aluminum),upper grillcraft, relentless hi clearance bumper,OEM color matched front grill color, ARE MX camper shell, wet Okole realtree seat covers,pelfreybuilt hi lift mounts,ICON 2.5 Coil-overs extended,, ICON tubular UCA's. Allpro expo leafs, SS extended brake lines.Bilstein 110 extended rear shocks.prinsu Cabrac.dwreck pod mounts OKLED 18w cubes.Baja Designs Squadron-R Sport, LED Wide Cornering, Ambers fog/driving 20" IGGY LED Single Row bar.tepui awning,rotopax 2 gallon, TREDs and mount , 100 watt renogy solar panel.victron 20 amp Bluetooth charge controller,Pro comp wheels - cooper st maxx 285/75/16 tires. Skygear bussman fuse relay smart box. ARB 12v plug hard wired for ARB fridge. Pelfreybilt gas tank skid. Smittybilt X2O 10K winch
  5. Mar 22, 2012 at 7:49 PM
    saundern
    Nick
    Simpsonville, SC
    2005 TRD Sport
  6. Mar 22, 2012 at 7:49 PM
    especk
    Erik
    Redding, CA
    ya i remember that one. I'm still looking for a slow roll-over going less than 5mph or so.
  7. Mar 22, 2012 at 7:51 PM
    saundern
    Nick
    Simpsonville, SC
    2005 TRD Sport
    hell, that one is good too!
  8. Mar 22, 2012 at 7:51 PM
    especk
    Erik
    Redding, CA
  9. Mar 22, 2012 at 7:54 PM
    especk
    Erik
    Redding, CA
    haha well those are the situations where I've felt like I was going to roll. I would really like to see a vid of this just to see how much off-camber our trucks can get
  10. Mar 22, 2012 at 8:02 PM
    joes06tacoma
    Joe
    Central Coast, CA
  11. Apr 2, 2012 at 12:33 PM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    3" lifted reg cab is pretty stable in this regard.
    Higher rigs and flexier suspensions encourage the rollover thing.
    I had my F150 std cab 30 degrees off camber as measured by an inclinometer.
    I had my Tacoma slid down inside the "crack" at Hollister Hills (as a result of an "unintended approach line"), no inclinometer handy, but felt like a gnarlier angle than even that. I still have the "Skid marks on the driver seat" from that day. :p
  12. Apr 2, 2012 at 12:38 PM
    macgyver
    macgyver Well-Known Member
    Brad
    Canton, GA
    '13 Tundra double cab SR5 4x4
  13. Apr 2, 2012 at 2:01 PM
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    Next time, please don't put your arm out the window. Hold tight to that steering wheel.
  14. Apr 2, 2012 at 2:26 PM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    great line there lol
  15. Apr 2, 2012 at 4:04 PM
    macgyver
    Brad
    Canton, GA
    I had my arm resting on the door panel, it slipped then gravity took over. It was pretty hard to stay in the seat at that angle.
  16. Apr 2, 2012 at 4:24 PM
    ink junky
    ink junky I love tacos too!!!
    TACO LOVER
    TEXAS
    2010 4x4 trd off road DC,
    Aero turbine 2525, Snorkel, AFE pro dry drop in filter, BFG 33s, spydertraxwheel spacers :/. Debadged, rebadged black, TW sticker :D, bed lights, rod holders, OEM roof rack, Complete OME lift, bed lined fenders. Armor Tech Off road wrap around HC rear bumper w/ tire carrier swing out. Relentless front aluminum bumper. Le Devil Horns (_)
    tsk! stop lying, you know your first reaction was to stick your arm out to keep the truck from rolling over. It's a good thing your "survival instinct" told you to stick your arm back in the truck before it turned into an ungodly sight!
    :p
    j/k
    I literally inhaled and held my breath when I saw your arm stick out the window. haha
  17. Apr 2, 2012 at 4:26 PM
    ink junky
    TACO LOVER
    TEXAS
    oh, and by the way, good on you for showing others how not to approach!
    :p:D
  18. Apr 2, 2012 at 5:22 PM
    Night
    Night Well-Known Member
    Canada
    '11 TRD OR AC MagGrey
    Banks Monster Exhaust, aFe ProGuard 7, 3M Film, UnderCoating, alpine 920 headunit, alpine 6.5 components, 20% tint all around, JL Stealthbox, PDX-V9 Amp, Avid Lightbar, Avid Sliders, Full Metal JackRabbit Tonneau, TRD S/C
    But he is Mcgyver!
  19. Apr 2, 2012 at 7:53 PM
    macgyver
    Brad
    Canton, GA
    No problem, any time.
  20. Apr 4, 2012 at 12:45 PM
    BAMFTACO
    BAMFTACO Another day another beer
    Juan
    Woodlandland hills , CA
    2007 Tacoma AC Prerunner
    Kings bruh
