Anyone run 14v/16v battery's?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Minnetacoma, Apr 25, 2015.
  1. Apr 28, 2015 at 3:20 PM
    #41
    Minnetacoma
    Minnetacoma [OP] Well-Known Member
    Elliott
    Minnesota
    96 tacoma sr5 with oe sunroof
    3.5 fabtech suspension lift with dirt logic shocks, Wheelers Alcon 8 pack rear leafs with extended brake line All pro rock sliders Cbi DIY front bumper with m8000 winch Cbi bushmaster 1.0 non swing arm 33x10.5 BFG mud terrains Skid row front skid plate Trs headlight retro fit fxr 2.5in projectors with rbg halos Audio/electrical upgrades K2 73ah lithium battery Big 4 upgrade 300a Ohio generator alt Alpine type r 6.5 coaxials in front Alpine type s 6.5 coaxials in back Alpine double din touchscreen Digital designs z3 15” subwoofer Digital designs m4 amp Alpine ktp 445u behind the dash amp for speakers 152db
    Sounds like I'm gonna have to put a hold off on a new audio build still gonna get a ho alternator for both my Tacoma and my Sierra but as of more than that I'll be waiting to see what the oil prices does sounds like my company just dished out my second pay cut of over 20k dollars a year.... Meaning over 40k a year less going into my bank account
  2. May 3, 2015 at 6:30 AM
    #42
    Shadetree
    Shadetree Well-Known Member
    BiLL
    Bozeman, Montana
    2011 Access Cab 4x2
    Locking Tailgate & Gas Cap and extra bed D-rings
    I agree with Bill and ecoterragaia. A wet 14 volt (7 cell) and 16 volt (8 cell) battery requires a minimum of 2.4 volts per cell to fully recharge it, so at 77 degrees F your charging system would have to produce a minimum of 16.8 volts or 19.2 volts, respectively. Your 14 VDC vehicle's electrical system (using a 12 VDC (6 cell) battery) and appliances are designed for a maximum of 16 VDC. There are at least two workarounds if you want to increase the voltage. The simplest solution is using a DC to DC converter. The second alternative is using a dual power system similar to the new 42/14 VDC "Start-Stop" electrical systems. I serious doubt that most audio equipment designed for 14 VDC power systems would be operate in the 18.6 or 21.3 VDC range.
  3. May 6, 2015 at 5:39 AM
    #43
    Minnetacoma
    Elliott
    Minnesota
    The audio system I would be putting in would be far from most audio equipment... Keep in mind the second power bank would be only to power an amplifier and subwoofers... And when it comes to quality competition grade equipment these amps are good up to 19v some even over 19v
