Anyone run the Rubicon or Fordyce in their 2nd gen
Discussion in 'Off-Roading & Trails' started by 92LandCruiser, Aug 17, 2011.
  1. Aug 17, 2011 at 6:26 PM
    92LandCruiser
    92LandCruiser [OP] Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    If so, what spares did you take? How did you do? Did anything break?
    I'm thinking tie rod ends, u-joints, and all the regulars. I want to run the 14th annual Rubicon scramble, but not sure I should without a spare half shaft and a spare third.
  2. Aug 17, 2011 at 6:34 PM
    jandrews
    '09 FourDubDee TRD OR
    Not yet, but there's some tentative plans for a run around this time next year. Stay tuned?
  3. Aug 17, 2011 at 6:39 PM
    ian408
    ian408 Well-Known Member
    Ian
    Santa Clara, CA
    09 Tacoma
    I think there are spots you won't physically fit on the trail. Either because you're too wide or too long.
  4. Aug 17, 2011 at 6:43 PM
    jandrews
    Wyatt has basically said 2gens will need end to end armor and spare parts because there WILL be mechanical failures.
    Not really surprising.
  5. Aug 17, 2011 at 6:43 PM
    rsbmg
    rsbmg Well-Known Member
    Rob
    Vista,CA
    2011 Tacoma Doublecab TRD Offroad
    Front Aluminum bumper by Relentless Fab. Smittybuilt Winch Complete set of skids by ATO TC UCA's Fox Ext. Travel Front Reservoirs.
    You could tow a jeep to the event probably plenty of spares amoungst the participants:D
  6. Aug 17, 2011 at 6:44 PM
    92LandCruiser
    Nevada
    Cummins, tons, 40s
    I know rigs wider than me can fit. And long, yeah I might drag occasionally, and might have a hard time turning occasionally.
    I guess I'm more worried about breaking shit and not having the parts I need to get off the trail. I don't want to be that guy. I'm alright with having to pull cable or take a strap.
  7. Aug 17, 2011 at 6:46 PM
    92LandCruiser
    Nevada
    Cummins, tons, 40s
    This is very true. I know a lot of jeeps going locally. :D
  8. Aug 17, 2011 at 6:47 PM
    92LandCruiser
    Nevada
    Cummins, tons, 40s
    I'm just wondering of what sort. I've done a few rock gardens and such with the 35s and haven't broke anything but they weren't very long. I suppose I need to get some new gears and then find an extra third and half shaft. That would alleviate most of my worries.
  9. Aug 17, 2011 at 6:50 PM
    rsbmg
    Rob
    Vista,CA
    I have not been through myself but I think excessive use of pride breaks more parts than anything. Sounds like your cool with the cable and strap, not quite as fun but will probably save you having to wrench on the trail.
  10. Aug 17, 2011 at 6:52 PM
    92LandCruiser
    Nevada
    Cummins, tons, 40s
    Yeah, I definitely agree, and I'd much rather take a strap than break shit.
    Also, if I were to find a stock third, had 4.56s, blew my rear, swapped thirds, it would be "okay" to run on the trail right? I'd rather have a spare third set up with 4.56s but that's a big cost.
  11. Aug 17, 2011 at 6:54 PM
    jandrews
    Driveshaft, CV axle or two, spare third member, two spare tires, spare tie rods, spare belts and hoses would be my list. All needed tools, fluids, and gaskets/seals/etc. goes without saying.
  12. Aug 17, 2011 at 6:55 PM
    cameronlane
    cameronlane Well-Known Member
    cameron
    Anywhere but there
    2014 Dbl Cab TRD OR 4x4
    I would think youd want spare cv's, a third, possible rear drive shaft. And if you dont get new tires and front locker and LOW gears you will have a much more frustrating trip. I do those trails in my 85 runner and even with 5.29's and marlin crawler duals I wish I could go slower off some of the ledges.
  13. Aug 17, 2011 at 6:55 PM
    jandrews
    ...not really. It'll definitely HELP you break shit faster, but some stuff is just hard. I've been present for plenty of carnage when the driver was taking it nice and easy.
    Vehicles are designed to work on roads. When you're off them, it's hard on them.
  14. Aug 17, 2011 at 7:04 PM
    92LandCruiser
    Nevada
    Cummins, tons, 40s
    Alright. Wont' be running it this year. :( Thanks guys. Pretty much what I figured. Probably stick to deer valley, slick rock, barney riley, and the local trails near Reno.
    Also, I've gone through the blown rear end thread on ttora a couple times in the past. Can't seem to remember, has anyone blown a rear with aftermarket gears?
  15. Aug 17, 2011 at 7:13 PM
    SACTOWN
    SACTOWN Well-Known Member
    Greg
    You can go threw the rubicon with a stock truck. No problem. There are ways around all the heavy spots. Easy.
    Not sure about the other trail. Never done it
  16. Aug 17, 2011 at 7:14 PM
    jandrews
    You can blow just about any rear end in the right situation. Aftermarket gears are much less prone than the stock toyota stuff.
  17. Aug 17, 2011 at 8:03 PM
    92LandCruiser
    Nevada
    Cummins, tons, 40s
    Certainly, I do understand that. :) Doesn't seem to be much of an issue with aftermarket gears though as I understand it. Or am I mistaken?
  18. Aug 17, 2011 at 8:15 PM
    rsbmg
    Rob
    Vista,CA
    My point being simply if you take a moderate approach to gettign through with copius use of assistance you will be far less likely to break anything than if you say "that doesn't look so hard I think I can make it"
    And as was pointed out, there are easier ways around obstacles you think might possibly leave you broken.
    Of course none of that is more fun than making it through unassisted but easier trails and assistance are more fun than laying in the dirt wrenching on your truck (after your broke) Makes for good stories later though.
  19. Aug 17, 2011 at 9:57 PM
    ian408
    Ian
    Santa Clara, CA
    09 Tacoma
    Sorry to hear you won't be running this year. I'm still interested in hearing how it goes when you do.
  20. Aug 18, 2011 at 8:22 PM
    92LandCruiser
    Nevada
    Cummins, tons, 40s
