anyone running 235/85/16's?
Discussion in '4 Cylinder' started by singlecoil, Mar 4, 2013.
  1. Mar 4, 2013 at 8:59 AM
    singlecoil
    singlecoil [OP] New Member
    tacoma 4x4
    stock 4 clyclinder 5 speed manual
    Hello all, I've got a 2009 4x4 access cab 4 cylinder 5 speed.. I decided to leave it stock until it was paid for and now is the time to start upgrading. First thing is tires. I'm thinking that taller but narrow is the way to go with the 4 banger fuel economy and power wise and I want some advice on if this size will fit a stock suspension without any issues? Also if you are using this size which tire are you using? I hunt regularly but also use this truck as my everyday driver so I'm looking for a lighter load range tire as most of these I've found are LT's e range and I'd like to keep somewhat of the ride it has now. Maybe a c range tire? I also plan to put billy 5100 shocks on but probably set at 0. Any suggestions and advice will be much appreciated.
  2. Mar 4, 2013 at 9:02 AM
    Large
    Large Red
    Sounds good, I'm fairly certain you could fit a 235/85 on stock, but why not go with a 255/75? You'll lose an inch but it won't look bad at all IMO. I've never seen a 235/85 on a taco btw.
    The 5100s are a good choice, lots of members running them without issues. If you wanted more of a front lift, all you would have to do is bump up the retaining ring up a notch.
  3. Mar 4, 2013 at 9:15 AM
    OZ-T
    OZ-T You are going backwards
    Peter North
    British Columbia
    Check the similar threads in the bottom left side of the screen
    V
    V
    V
    V
    V
    V
    V
    V
  4. Mar 9, 2013 at 9:51 PM
    Tommy27
    Tommy27 Well-Known Member
    Tommy
    Boise,ID
    White 09 AC 4x4 2.7 5spd SR5
    Leer shell, Bed mat, Grill Guard
    I have 235 85 Cooper AT3s and I love the tire and the size. Able to keep up with my buddys 4Runner with duratracs. And they are much quieter on the highway. They hurt your gas milage in the city about 2mpg. On the highway (60mph) I get 25mpg!! Im running those tires in my sig pic.
  5. Mar 10, 2013 at 10:26 AM
    singlecoil
    tacoma 4x4
    Thanks for posting the pics guys, I think they look great! Now I'm looking at the BFG Rugged Terrains as they are the lightest 235/85/r16 LT rated I can find. Right at 40lbs and supposedly not too much road noise and good hwy and off road manners! What do you guys think?
  6. Mar 10, 2013 at 10:37 AM
    TacoTony
    TacoTony Well-Known Member
    tony
    san antonio
    single cab rado
    Maxtrac spindles
    I think those are a good tires, I was thinking about getting some but in a 285
  7. Mar 10, 2013 at 2:03 PM
    EatMyTacomaDust
    EatMyTacomaDust Well-Known Member
    2014 "Black Beauty" Baja DC 4x4
    ICON 3" LIFT, Console Vault, Tailgate Security Clamp MOD, SuperBumper Crash Attenuator, TRD Front Skid Plate, Wet Okoles - 1/2 Piped, Undercover SE Tonneau
    Looks Great! Thinking about running this size tire. Love your location of your CB antenna.
    Thanks for the pics.
  8. Mar 26, 2013 at 6:15 AM
    RogerRZ
    RogerRZ Well-Known Member
    New Brunswick, Canada
    White '14 DCLB TRD Sport
    In the white season, I run Michelin Winter LTX, in the tall and skinny size:
    The next set of Summer tires I put on will be in that size also.
