Anyone running 255/70R17?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 22Coma6MT, Jan 20, 2023.
  1. Jan 23, 2023 at 10:43 AM
    tbrownoutnabout
    tbrownoutnabout Active Member
    Todd
    Massachusetts
    2023 6MT DCSB TRD Sport 4x4 Black
    Hey Ryan, I'm considering A or B, did you notice much difference? I know consensus is 265/70/17 are just fine on stock suspension with no lift, but since you rode on both sizes I am curious of your opinion. My use case is weekends in the mountains, fire roads, and plenty of opportunities to drive in winter conditions. Thanks.
  2. Jan 23, 2023 at 10:55 AM
    atc250r
    atc250r Recovering Ram Owner
    Orange County, NY
    2022 Tacoma SR5 - DC/LB
    LED interior, license plate, and fog lights. More to come.
    @tbrownoutnabout 265/70/17 can rub pretty good at stock height depending on offset. I have 17x8.5 - 10mm offset and the tires rub even with mudflaps and air dam removed.
  3. Jan 23, 2023 at 12:08 PM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    Practically none. Handling and acceleration wise they were close to identical. I think I took a 0.5 MPG hit with the larger size. The biggest difference was looks - the larger size was just enough to fill out the rear fender and not make it look like a skateboard.
    I did not experience rubbing at stock +30 offset. :cookiemonster:
  4. Jan 23, 2023 at 4:14 PM
    atc250r
    Orange County, NY
  5. Jan 23, 2023 at 5:23 PM
    tbrownoutnabout
    Todd
    Massachusetts
    Why are you running a 10 offset, did you end up cutting?
    atc250r[QUOTED] likes this.
  6. Jan 23, 2023 at 5:31 PM
    ssd2k2
    ssd2k2 Well-Known Member
    Keith
    Minnesota
    2019 Tacoma TRD Sport M/T
    I've had Toyo Open Country AT3 255/70r17 with 0 offset for just over 40k miles.
    I went with this over 265/70 because they are lighter. I saw no lose in mileage, they are quiet on the road, and work great in the snow.
  7. Jan 23, 2023 at 6:41 PM
    tbrownoutnabout
    Todd
    Massachusetts
    @ssd2k2 I did not even consider going narrow, makes compromising sense.
  8. Jan 23, 2023 at 7:29 PM
    Hossleryota
    Hossleryota Well-Known Member
    What do they measure in height mounted? I've been on the fence about size lately and the 255 75 17 duratracs are now on my list.
  9. Jan 24, 2023 at 5:05 AM
    atc250r
    Orange County, NY
    The wheels I liked were available in that offset and I like the way a "flush" tire looks. If they were available in 0 offset I'd have probably gone that route. I could probably heat the plastic with a heat gun and make a little more room but I plan to do a 2 inch lift in the spring and I don't do any serious off roading so I'll see what happens after the lift.
  10. Jan 24, 2023 at 8:13 AM
    brian2sun
    brian2sun Well-Known Member
    California
    ‘21 TRD OR DCSB ‘17 4Runner Limited ‘97 4Runner SR5
    They’re a true 32 mounted. I think the 255/75/17 Duratracs run big too, because they look as big as lots of other brand’s 255/80/17s. I get minor rubbing on my mudflaps when I’m at full lock and the tire is stuffed (with +4mm TRD 4runner SEMA wheels).
  11. Jan 25, 2023 at 2:17 AM
    VaToy
    VaToy Life Long Member
    Parts Unknown
    2018 TRD DCLB Sport 4x4 Silver Sky
    Bilsteins 5100s on the top setting, 4runner Gray TRD Pro Sema wheels, 285/70/17 Toyo AT3s, Sumo Bump stops, TRD exhaust, ECGS Clamshell bushing, 1/4 shim for the lean and one inch rear block, OEM Pro grill and garnish OEM TRD Skid plate, TRD CAI, Demon Brackets, Rigid Industries Pro fog lights, OEM Trail Rails sidebars, Diode Dynamics LED SL1 high and low beam lights, OEM Roof racks, Clazzio leather heated seats, Remote Start, TRD Pro shift knob, tinted windows, Rockford Fosgate 4 channel amp for the headunit and sub and amp combo, OEM Puddle lights, OEM tailgate lock, OEM bed mat, LED interior lights, OEM blackout kit for letters, JLT catch can, upgraded 27F toyota True Start battery, Vleds led tail light kit with Pro tail lights, OEM Rave4 side mirrors with convex spotters,just to name a few mods.
    Alignment will help as I run 285/70/17s on 4runner SEMA wheels and no rubbing on my mud guards.
    Junkhead likes this.
  12. Feb 7, 2023 at 12:35 PM
    tbrownoutnabout
    Todd
    Massachusetts
    I went with option A, went to post the take off Toyo tires in the marketplace here, loaded pictures and went through the process before getting the warning that I need 50 posts before I can post items for sale - seems a little excessive but I'll play by the rules. Must be a lot of folks just using this forum as a distribution channel I guess.
