Anyone running 295/65 18s ?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Laplataninja, Mar 15, 2014.
  1. Mar 15, 2014 at 10:26 AM
    Laplataninja
    Laplataninja [OP] Well-Known Member
    Laplata md
    2012 Tacoma trd sport
    3 in ome Lift kit, Westin bull bar , rbp side steps, mb tko wheels
    I have a 3 inch ome lift with 885s , xd cranks 18x9 +00 offset running 285 60 TGs . Will I rub on the stock uca's ? And what trimming will I have to do ?
  2. Mar 15, 2014 at 2:04 PM
    Wattapunk
    Wattapunk Stay lifted my friends !
    Uncle K
    TX
    2005 DCLB 4WD
    The major trimming is on your wallet. In all seriously, tires in that rare size are very limited in availability and manufacturers along with a ridiculous price tag. To answer your question, there's a great chance you will not only hit the UCAs but more than likely need a cab mount chop. Rubbing the UCAs is the easier of the 2 fix by wheel spacers but then that would increase the radius to hit the cab mount. Stick with 285/65/18's. Those should clear with minor plastic trimming.
  3. Mar 15, 2014 at 4:59 PM
    Laplataninja
    Laplata md
    Thanks !! What about 275 70 18 ?
  4. Mar 16, 2014 at 7:56 AM
    Wattapunk
    Uncle K
    TX
    2005 DCLB 4WD
    That's a better tire size choice since there's more tire options. You should clear the UCAs but there's a minor possibly you may hit the cab mount at full lock or flex. You can always have the tire shop do a test fit the front but alot also depends on the tire manufacturer and A/T vs. MT.
  5. Mar 16, 2014 at 9:26 AM
    Laplataninja
    Laplata md
    i was thinking trail grapplers 275 70 18 . does it help i have a cbi front plated bumper? less trimming?
  6. Mar 16, 2014 at 1:16 PM
    Wattapunk
    Uncle K
    TX
    2005 DCLB 4WD
    yes. Usually having the plate bumper, you have already modified the inner front plastic so you have eliminated the front plastic rub. I think you are fine with that tire size. Even worse case, minor cab mount chop is really no big deal.
  7. Mar 16, 2014 at 1:32 PM
    Mainmoe02
    Mainmoe02 Well-Known Member
    Moe
    Austin, Texas
    01 Gold tacoma SR5 TRD
    3" lift EIBACH coils w/ 5100's front, OME/ Dakar leaf springs w/ toytec adjustable shackles at 1.5" and 5125's out back. 33x10.5x15 KM2's Relentless DIY steel bumper.
    I doubt you'll need a cab mount chop because 33's fit nicely with a little hammering. Since you have 0 offset on your wheels I'm guessing the backspace is right at 4.5" which means you'll probably need wheel spacers no keep from hitting the UCA's
    A 295/65/18 tire is like having a 33x11.50 and there are lots of guys who run 33x12.50 without a cab mount chop, unless you want to do it but it shouldn't be needed.
  8. Mar 16, 2014 at 2:14 PM
    Laplataninja
    Laplata md
    Thanks for all the info I will be deciding by the end of this week !
