Anyone running a dsp with oem entune unit?
Discussion in 'Audio & Video' started by Revelations, Sep 14, 2015.
  1. Sep 14, 2015 at 8:55 AM
    Revelations
    Revelations [OP] Well-Known Member
    2014 MGM DCSB
    I've got the audiocontrol lc7i, but haven't installed it yet since I have yet to install my aftermarket equipment. I've been reading more about the oem noise floor issue and am thinking about using a dsp Instead of the loc.
    If you have a dsp instead of a loc, which one are you using and do you get any hiss from your system?
    Also, I'm looking at the Helix dsp.
  2. Sep 14, 2015 at 7:45 PM
    manethon
    manethon TTAS
    Steven
    Unknow
    Many
    Allot of hising and line noise is coming from grounding issues mostly and can be solved but not in all situations is it from grounding
  3. Sep 14, 2015 at 8:09 PM
    Revelations
    2014 MGM DCSB
    it's proven that the factory hu has a high noise floor. I know about ground loop noise and that's not what I'm talking about. Thanks for your suggestion though.
  4. Sep 14, 2015 at 9:23 PM
    manethon
    manethon TTAS
    Steven
    Unknow
    Many
    Regrounding the head unit has reduced any high freq floor noises that i got using even a basic loc... why i brought it up, I'm not referring to ground loop noises associated with alternator and other tone generating issues.... but anyways i know some Loc's can also be grounded to reduce the noise problem
  5. Sep 14, 2015 at 9:25 PM
    Revelations
    2014 MGM DCSB
    thanks. that makes more sense than your first post.:cheers:
