Anyone Running Air bags with their leaf springs?
Discussion in 'Suspension' started by Tacomamoose, Dec 17, 2010.
  1. Dec 17, 2010 at 10:32 AM
    Tacomamoose
    Tacomamoose [OP] Well-Known Member
    Austin
    Fort Collins, CO
    06 trd sport doublecab debadged
    debadged Tinted windows
    Hey I have been towing a lot lately and someone told me that I should look at getting air bags and an onboard air compressor for my truck what do you think??? Please give me some thoughts
  2. Jan 12, 2011 at 3:48 PM
    mustangwilly
    mustangwilly Well-Known Member
    IL
    2017 DCSB OR Quicksand MT
    I have the firestone ride right system and it works great. I installed it because I wasn't happy with the back end squatting when pulling my boat, hauling stuff, etc. The tsb just wasn't enough for me.
  3. Jan 12, 2011 at 4:16 PM
    Pugga
    Massachusetts
    '13 Ford F-150 SCREW
    F-150 Mod
    They work well for hauling/towing but they slightly limit you of you off road. You don't necessarily need a dedicated on-board air set-up. They can get expensive and an aftermarket 12v air compressor that you plug into your cigarette lighter would do the trick. If I recall correctly they carry about 5-8 psi unloaded and up to 20-25 psi loaded so it doesn't take an overly powerful compressor to load the air bags.
  4. Jan 12, 2011 at 4:41 PM
    mustangwilly
    IL
    I keep mine at 5 psi all the time I have never needed to go over 20psi so you're right on. As far as the compressor goes, you can actually just use a bicycle tire hand pump. I went with the onboard compressor though:D
  5. Jan 12, 2011 at 4:43 PM
    Tim A
    Tim A Well-Known Member
    Montana
    2011 TRD Offroad 6 spd Double Cab
    I would imagine that everyone running air bags also has leaf springs. If your rig is nose high after hooking up the trailer then you might get Firestone airbags to level it out.
  6. Jan 12, 2011 at 4:54 PM
    mustangwilly
    IL
    Yes to the leaf springs. The air bags basically replace the bumpstops, but are attached to the axle and frame. You can acheive quite a bit of lift to level the truck out when hauling something heavy, and you never have to worry about bouncing your truck off the bump stops again.
  7. Jan 12, 2011 at 4:56 PM
    Cogge89
    Cogge89 Well-Known Member
    Justin
    Saint John, NB
    09 Tacoma TRD Sport
    Pioneer AVH-P4100DVD, Kicker ZX400.1 Amp, Kicker CVT 10" Sub. Light Racing UCAs, Front OME Shocks with 885x Coils, Rear OME Shocks with Dakar Leaf Pack, Engine Cover Paint Job, 265/70/17 Duratracs.
    I have the Firestone Ride-Rite system as well.. Absolutely love it.
  8. Jan 12, 2011 at 5:00 PM
    Tim A
    Montana
    The sarcasm must have been too subtle, my bad.
  9. Jan 12, 2011 at 5:03 PM
    mustangwilly
    IL
    Is this sarcasm as well? LOL
  10. Jan 12, 2011 at 5:04 PM
    Tim A
    Montana
    No it's me being apologetic for being sarcastic
