Anyone running BFG AT 265/70/17 load range "E"
Discussion in 'Wheels & Tires' started by aww1970, Sep 7, 2008.
  1. Sep 7, 2008 at 12:05 AM
    aww1970
    aww1970 [OP] Well-Known Member
    2009 Tacoma TRD Long Box
    Are any of you guys running these tires? I have a 2009 DC SB w/ 6 speed and I am considering these tires. I believe the load "E" are 10 ply w/ thicker side walls. I am worried that the heavier tire will kill my mileage?
    As well with the 1" bigger tires I am curious if my rpm's will drop noticeably?
    Thanks in advance.
  2. Sep 7, 2008 at 12:11 AM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
  3. Sep 7, 2008 at 12:14 AM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. URD -3° exhaust cam gears, .5" XTP Intake spacer. Custom dents.
    I'm not running that tire but can tell you that it is heavy, you shouldn't notice almost any difference in rpms. This tire is 31.6" tall. I am running the Same type but 285/70/17 32.7" tall they call it a 33 really measures on truck 32.4, any way I haven't noticed a difference in my rpms.
  4. Sep 7, 2008 at 11:29 AM
    SongDog
    SongDog Active Member
    DFW, TX
    SR54x4 Sport
    Tint, Husky floor liners, UWS low profile toolbox, 2.5 lift, 265/70/17 BFG A/T, Moto Metal 951 17X9
    I have BFG A/T265/70/17 "C" w/2.5" lift. I have not experienced any drastic change in MPG. Maybe 1 to 1.5. IMO there is no need for a load range "E" on our trucks. The carrying capacity of the truck is not enough for an "E" and the additional plys do not give you enough puncture resistence to worry about. You will also notice a considerable reduction is ride quality and will feel every pebble in the road. I am very pleased with my "C" range.
  5. Sep 7, 2008 at 11:31 AM
    RealSouthernPride
    RealSouthernPride Well-Known Member
    seems like it should to me!
  6. Sep 7, 2008 at 3:55 PM
    TroutBum
    TroutBum Well-Known Member
    Michigan
    06 SR5 AC 4x4 Sold, 17 Sport 6MT DCSB, 2020 OR DCSB
    Leer 100R
    Thanks for the info SongDog. I've had good look with the BFG's in the past (over 70,000 miles on my Dodge and still going) but was worried about the added weight when compared to the stock Dunlops.
  7. Sep 7, 2008 at 7:33 PM
    aww1970
    Thanks for the replies. I am getting great mileage out of a new truck so I will probably stick with the load range c.
  8. Sep 7, 2008 at 7:40 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    Good call.
  9. Sep 7, 2008 at 10:02 PM
    ultraman69
    ultraman69 Member
    calgary alberta canada
    08 tacoma dbl cab trd
    on the same page here......can i run 285/70/r17 bfg tko's with a 2.5" lift with out any rubbing???
  10. Sep 7, 2008 at 10:04 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    im pretty sure that with the 285', and not having a full 3 inch lift, there will be some rubbing. im not 100% sure, but thats what im thinking. hopefully, someone will answer for sure shortly.
  11. Sep 7, 2008 at 11:29 PM
    MyTaco
    MyTaco Well-Known Member
    Az
    08 Prerunner
    BLHM, Grillcraft grill, painted grill and eyelids. 285/70/17 BFG's on 17x9 Pro Comps 5100's all corners
    You will encounter some rubbing...a little trimming on the mud flaps is all I experienced with mine...
  12. Sep 8, 2008 at 7:21 AM
    ultraman69
    ultraman69 Member
    what if i just take the mud flaps out in the front.........is there anything else taht would rub
  13. Sep 8, 2008 at 7:38 AM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    I have the full 3" lift and those same tires and I had some rubbing. They won't fit without some trimming. IMHO.
  14. Sep 8, 2008 at 8:30 AM
    MyTaco
    Az
    08 Prerunner
    Also depends on the wheels....what are you going to use?
  15. Sep 8, 2008 at 11:02 AM
    ultraman69
    ultraman69 Member
    i got some 17x8 rims...............what did you trim??? (sorry new to this, haven't got the tires on the rims yet decide which size to go with)
    would you rather put bfg tko's or pro comp a/t...........any inputs please if there are other tires in the same price range tha's just as good
  16. Sep 8, 2008 at 9:28 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    This is in the front you can see the zip tie I put to keep the plastic held back.
    This is the big black plastic knob, or was.
    This is near the pass. door, very little cut here.
    As for the tires I have only had these, so I have no advise for you.
  17. Sep 8, 2008 at 9:36 PM
    ultraman69
    ultraman69 Member
    thanx luk
