Anyone running Fox 2.0 performance series?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by truesol3, Apr 27, 2011.
  1. Apr 27, 2011 at 8:53 PM
    truesol3
    truesol3 [OP] Member
    Bay Area, CA
    09 PreRunner
    New to tacomaworld and bought an 09 tacoma with fox shox on it and i know nothing about them. Just wondering if anyone else is using these and I have some questions about them.
  2. Apr 27, 2011 at 8:55 PM
    08pretaco
    08pretaco Almost there
    Oliver
    az
    2014 Tundra 4x4 CM 5.7L SR5
    AFE pro dry s, Husky X-act Contour
  3. Apr 27, 2011 at 9:18 PM
    truesol3
    Bay Area, CA
    09 PreRunner
  4. Apr 29, 2011 at 5:11 PM
    FixedTRD
    FixedTRD Well-Known Member
    Will
    Alhambra, CA
    All pro LT, All pro front bumper,All pro rear fox, 1.5 full leaf and u bolt flip kit. KR sliders, bestop, high lift with custom mount, katskin leather, Hankook MT and atx artillery. DMZ SUA w/FOX triple bypass
    Are you referring to the rear shocks or the fronts?
  5. Apr 30, 2011 at 1:07 AM
    truesol3
    Bay Area, CA
    09 PreRunner
    I'm pretty sure both. Like I said I'm new to tacomaworld and a new Tacoma owner so I know nothing about trucks. So I'm trying to figure out what I have. They both say performance series on them.
  6. Apr 30, 2011 at 1:10 AM
    FixedTRD
    Will
    Alhambra, CA
    Can you take a picture of it?
  7. Apr 30, 2011 at 1:57 AM
    woody6047
    woody6047 McGrubber
    Beau
    Austin/ Waco Texas
    05 tacoma 4x4 dc
    100%stock, except for the exhaust leak and custom windshield crack mod
    Hmmm it has fox shocks already on it? are they on the front or back? I was going to use them for both but went a different route, they are definitely one of the higher rated shocks out there. With a 2.0 i think you would be fine unless you plan on doing some desert racing and working them pretty hard constantly. What other questions did you have about them?
    BTW welcome to TW
    Here is what the fronts might look like, with or without the reservoir
    Here is a picture of what the rear 2.0s might look like.
  8. Apr 30, 2011 at 10:18 PM
    truesol3
    Bay Area, CA
    09 PreRunner
    my front looks nothing like that there is no resovoir and they are not coilovers. and i will get some pictures of them tomorrow. i appreciate the help
  9. May 1, 2011 at 12:23 PM
    truesol3
    Bay Area, CA
    09 PreRunner
    [​IMG][/IMG]
    [​IMG][/IMG]
    front
    [​IMG][/IMG]
    rear
  10. May 1, 2011 at 8:55 PM
    woody6047
    woody6047 McGrubber
    Beau
    Austin/ Waco Texas
    05 tacoma 4x4 dc
    wow, im clueless on these. I hope someone else can chim in that might know something. Typically fox shocks are great.... how is the ride with these?
  11. May 1, 2011 at 10:24 PM
    truesol3
    Bay Area, CA
    09 PreRunner
    i guess my question is whether or not i would need to replace my suspension if i were to lift my truck 3" and if these shocks are adjustable?
    woody6047 the truck rides real smooth. my buddy has the trd off road with stock suspension and says mine rides much smoother
  12. May 1, 2011 at 10:30 PM
    ColtsTRD
    ColtsTRD .....
    Scott
    AZ
    2005 TRD DCSB
    The fronts seem to be adjustable....do you have the spanner wrench? Thats what you'd use to crank them up...if you look at the front you'll see that its threaded
  13. May 1, 2011 at 10:30 PM
    ColtsTRD
    ColtsTRD .....
    Scott
    AZ
    2005 TRD DCSB
    your shocks wont lift the rear...leaf springs do that :)
  14. May 1, 2011 at 10:33 PM
    woody6047
    woody6047 McGrubber
    Beau
    Austin/ Waco Texas
    05 tacoma 4x4 dc
    Hmmm, i would contact FOX themselves and send them pictures of the shocks. Try to find serial numbers on them. Maybe they can help you out... so the truck sits at stock height with those shocks? I bet it does ride pretty nice. Those coils also look like they could be 2.5's you might run into some UCA issues with lifting. Id definitely do some research, i havnet seen anything like it.
  15. May 1, 2011 at 10:59 PM
    truesol3
    Bay Area, CA
    09 PreRunner
    is it as easy as it sounds?
  16. May 26, 2011 at 8:35 AM
    Mytidawg
    Mytidawg Active Member
    Vince
    Bay Area, CA
    07 Tacoma 4x4 Sport
    ARB front bumper, side steps
  17. May 26, 2011 at 8:40 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    thread jack...
    OP, those ARE coilovers. coilovers = coil over the shock, which you have...
    and they are adjustable, just turn the spanner nutt on the bottom of the front coils and it will raise or lower your truck. just remember the higher you go the stiffer the ride will get.
