Anyone running MB TKO black wheels?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Aggiesdm, May 31, 2012.
  1. May 9, 2013 at 6:58 PM
    #41
    nizzmont
    nizzmont Well-Known Member
    Brian
    S.E WA state
    2015 doublecab TRD sport
    in progress
    i just went looking for wheels 2day,16 inch is fading out it seems lol,found some i liked in the book but not in the store so that does me no good.need a 16 inch black wheel thread lol
  2. May 11, 2013 at 3:06 PM
    #42
    Fiend13
    Fiend13 Well-Known Member
    Chad
    Waddell/Phoenix area
    08 TRD O/R DC Prerunner
    What did y'all pay for these? I know the price ain't that bad at DT but they do price match.
  3. Jul 28, 2013 at 7:55 AM
    #43
    scott83
    scott83 scott83
    Scott
    Schuylkill County, PA
    18 sr dcsb mgm
    extang trifecta, predator steps, rek gen mudflaps
    I just put a set of 16" black tkos on my 08 dc, i got them from discountiredirect and i think the weights they stick to the wheel for balancing are slightly rubbing the caliper on the front passenger side, there is a consistent noise with each roll of the tire. The weights are still there, didnt get knocked off. Any solutions to this? Grind the caliper? Or can the tires be balanced with weights on the edge of the rim toward the inside of the truck?
    Other than that, the tko wheels look awesome with hankook dynapro atm tires!
  4. Jul 28, 2013 at 8:00 AM
    #44
    Jetlander
    Jetlander Just trying to measure up...
    Jonathan (aka MOAB)
    Depends on the day.
    2010 Tacoma DCSB 4x4 SR5
    TKO Wheel w/ 35" BFG KM2, Volant CAI, Safari Snorkel, 3" lift, All-Pro Full Skid Underarmor, Chopped/Re-Routed FlowMaster Exhaust, CBI Moab 2.0 Front Bumper, DerpWerx High Clearance Rear Bumper, Rear Tire Swing Out, BAMF Sliders w/Kickouts, King Resi w/700# Coilovers on front, Total Chaos UCA's, King Long Travel with Resi's, Shock Hoops and King 2.5 Bump Stops, OME Dakar Leaf Springs mounted on All-Pro Shackle Flip w/ U-Bolt Flip, extended SS Brake Lines, DerpWerx Bedrack, 10# C02 Tank, Black Badges, Dual Optima Red Top's, Blue Sea 12 Fuse Block on custom Block mount, SuperWinch 9.5iSR Talon w/synthetic line, Prolink Thimble, 20" Rigid Dual Row LED Light Bar, Rigid Dually Floods, OTRATTW Switches, Cab Mount Chop, Cobra CB w/ 4' Firestik, Center Counsel Glock 23 mount (with plenty o' ammo!), Weathertechs, and plenty more mods to come!
    I've got a set as well. The nice thing about them is they are flat black, and therefore don't show they are dirty too badly. I like them a lot and you can't beat them for the price.
  5. Jul 28, 2013 at 8:01 AM
    #45
    Jetlander
    Jonathan (aka MOAB)
    Depends on the day.
    Are you sure it isn't a bad bearing? The weights are pretty thin and shouldn't be rubbing anything. Do they show scoring on them? Personally I think you may have a different problem...
  6. Jul 28, 2013 at 10:19 AM
    #46
    scott83
    scott83 scott83
    Scott
    18 sr dcsb mgm
    Its the weights, i checked this morning by putting a piece of masking tape over them and taking a ride around the block. They barely touch but it is just enough to make a sound. Thanks for your quick reply, I appreciate it!
  7. Aug 22, 2013 at 6:56 PM
    #47
    itzyoboipaul
    itzyoboipaul Well-Known Member
    Paul
    PFville, TX
    2020 TRD OR Cement
    17s with the shorter center caps and black lug nuts . discount tires hooked it up . got the center caps for free and running a $75 visa card rebate :)
    asuchemist likes this.
  8. Sep 13, 2013 at 8:04 AM
    #48
    Columbian Taco
    Columbian Taco Member
    Columbia
    2012 Tacoma 2wd Base 5Lug
    1" rear drop. Currently sits 34.5" in the front and 35.0" in the rear.
    Thank you so much for posting that setup. I have been looking for that combo everywhere because that is the wheel/tire combo that I want for my 5 lug with 16's.
  9. Oct 14, 2013 at 11:38 AM
    #49
    beeesmitty
    beeesmitty Well-Known Member
    NC
    11' SR5 DC BSP 4X4
    265/75/16 Cooper ATP, TRD FJ Trails, 5100's @ 2.75, ReadyLift 2" Blocks
    Mine below. 16 inch
  10. Oct 14, 2013 at 3:38 PM
    #50
    MikeyMcFly
    MikeyMcFly This is heavy, Doc.
    I'm a Masshole
    2016 TRD Off-Road 6MT / 2021 WRX STI
    Building a Broja
    I will be this winter. 16x8.5, -6mm offset with alternate caps, wrapped in 265/70-16 Hankook I-Pike RW11. I was going to stretch and run a 245, but after a bunch of deliberation (and Hankook's documentation saying run no wider than 8" wheels on that tire) to go with the stock tire size.
    It should be fun that my winter wheels are wider and stick out further than my summer wheels. It's also ironic that I have winter tires on a 4wd pickup, but considering how sketchy my BFGs can be with the Off-Road's teeth bashing brakes, it will be a welcome change.
  11. Jan 27, 2014 at 9:02 AM
    #51
    OmegaTacoma
    OmegaTacoma Member
    Mitchell
    Washington
    TRD Sport DCLB 4x4
    Nerf Bars
    I am looking to get these with a 285/70/17 Duratrac, and wanted to see if anyone else ran this specifically.
    Was the backspacing ok? Was there major trimming at all?
    Just waiting on my tax return and can finish up my lift, tires, and wheels :)
  12. Jan 30, 2014 at 7:42 PM
    #52
    nate08
    nate08 Well-Known Member
    Nate
    South Carolina
    Nate's '12 SR5
    All I have on my phone
  13. Mar 16, 2014 at 7:04 AM
    #53
    jfwalsh
    jfwalsh Well-Known Member
    southern california
    2014 Spruce Mica 4wd DCLB TRD Sport
    TRD Exhaust, Front Skid, Running Boards (black)
    added these to my sport DCLB... kept the tires that came factory.
    total out the door from discount/ america's tire was $559, with a $75 rebate (on line). They swapped out the caps for the "chaos" caps for free, the tko ones arent the greatest.
    Very happy with how they look and ride.
  14. Apr 17, 2014 at 7:23 PM
    #54
    TKOtoy
    TKOtoy New Member
    San Diego
    2010 5 lug Tacoma 5 speed
    Geolandar a/t 215/70/15 tire TKO mb 15 rims Shell
  15. Apr 27, 2014 at 7:31 AM
    #55
    J4m3z420
    J4m3z420 Active Member
    James
    Keystone, CO
    09 DCBS TRD Off-Road V6 4x4
    Front: OME 884x | 90021 | Light Racing UCA’s Rear: CS047R (minus top overload) | 60091 FN Six Shooter 17x8 6-139.7 (20lbs) BFG KO2: LT265 /70 R17 112S C1 RWL (45lbs) ECGS bushing front diff
    Just got mine put on a couple days ago.
    16X8.5 6-139.7 -6MTB
    265/70/R16 Goodyear Wrangler tires.
  16. Aug 18, 2014 at 9:58 PM
    #56
    Jturner
    Jturner Member
    WA
    14 DC PreRunner
    Window tint, wheels
    Got a set of 16" TKOs installed on mine today. Had them mounted with the factory tires. Only had 10,000 miles on them so couldn't justify new tires. Discount had to order the optional center caps as they didn't have any in stock. They provided them at no additional cost. IMO the saucer caps don't look to shabby but I like the other ones better. Will be installing those later this week when they arrive.
  17. Sep 1, 2014 at 6:03 PM
    #57
    TacomaPrime
    TacomaPrime Cybertronian Tacoma
    Gregory
    Illinois
    14 TRD sport 4x4 Barcelona Red
    Weathertech front floor liners, window vent visors. Custom bedside decals. OEM bed mat, tonneau covrew. Added D rings to bed.
    I think these are the wheels I am going to go with. My offroad ones are SO flaked. when I replace them, I'm gonna go with these.
  18. Sep 2, 2014 at 8:05 AM
    #58
    Jhunter
    Jhunter Well-Known Member
    Atlanta
    Black '14 TRD DCSB
    Just getting started
    JfWalsh - Nice clean look. Thanks for Pic
  19. Dec 28, 2014 at 4:17 PM
    #59
    wildwest
    wildwest Do you best and to Hell with the rest.
    Littleton, nc
    Tacoma
    Ome 887's, ome shocks, fj rims, cooper tires, dakars, TAG bumper, custom steps, LR UCAs, CARHARTT seat covers, husky liners
    Really thinking about getting these rims but not sure of the offset. Im running 17s so I have a choice of +25 or -6. Any input will help?
  20. Dec 28, 2014 at 5:43 PM
    #60
    V0X
    V0X Well-Known Member
    Eric
    Ooltewah, TN
    TRD Pro Grille, MB TKO Wheels, BFG TA KO 265 70R17, Pop and Lock (color matched), Undercover SE Tonneau.
    also would like to know if I could fit these wheels on my '15 TRD Sport AC without a lift or spacers..
