anyone running the ready lift?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jeeezy, Apr 13, 2011.
  1. Apr 13, 2011 at 5:11 PM
    jeeezy
    jeeezy [OP] jeeezy
    Jesse
    Timmins
    07 dbc long box speedway blue
    custom cold air intake 4 inch tubing, MBRP dual catback exhaust, readylift leveling kit with 265/75-17 on eagle alloy rims
    is anyone here running the 3'' ready lift spacer kit? if so does anyone run 285's with this kit on the stock 16'' rims..... looking for pictures to of any cutting required for this setup
  2. Apr 13, 2011 at 10:08 PM
    jeeezy
    jeeezy [OP] jeeezy
    Jesse
    Timmins
  3. Apr 13, 2011 at 10:16 PM
    StandingCow
    StandingCow Well-Known Member
    NJ
    09 SR5 4x4 V6 access cab
    You aren't gonna see many positive responses about a spacer lift... you should do it right and get the OME lift kit or at least save until you can afford it.
    Even with a 3 inch lift, you are going to have to trim for 285's.
  4. Apr 13, 2011 at 10:20 PM
    wolfdog2314
    wolfdog2314 Well-Known Member
    Brush Prairie
    2011 Tacoma 4x4 Sport
    Eibach coils. 5100's all around. AAL. WickedFlow
    There's a lot better options than the spacer lift u mentioned.
    Search for bilstein 5100's, eibach springs, or OME.
    If you do choose to go with the ready lift, or any other 3 inch lift and 285 tires you will need wheel spacers for stock wheels. Or new wheels with a backspacing of 4.5 or less.
    Even then you'll probably need to do some trimming.
    Also consider new upper control arms. When lifting to 3 inches new UCAs are highly recommended to Get properly aligned.
